Question about Whirlpool GU2400XTP Built-in Dishwasher
Whirpool dwf 407 restart cicle
The washer restart again at the end of cicle
  • Sergio Poli Apr 02, 2014
    there is a solution in another post. which suggest to change the condensator on eletronic board
  • 44 Answers
I need more info but it sounds like the main contact or board relay is stuck or short together sound the unit is always powered.
Posted on Apr 01, 2014
    there is a solution in another post. which suggest to change the condensators on eletronic board
    thank you
DAEWOO WASHER DWF-800WPS machine the outer water is countune going out what is the problem
pump is running and not stopping, low water sensor is not working properly, replace part. it is behind control panel .
Jan 11, 2015 | Daewoo Washing Machines
Daewoo washer DWF 800WPS water drains before wash
Make sure the drain hose is about 1 metre high from ground. If drain hose is lower the water will keep draining.
May 27, 2013 | Washing Machines
Hello. My washer kemnore Mod. 110.29822800 NO WASH
Sounds like the timer is faulty and needs to be replaced.
Jul 16, 2010 | Kenmore Washing Machines
What is the code to open a Whirpool washer machine Duet HT
Switch on the washer. Press and hold "end of cycle" button for 3 seconds, on the right side of panel. This is the child lock feature, do it again & it locks.
If helped, pl rate me good!!
May 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool DWF 407 IKEA Dishwasher serious problem.
a worn film capacitor on the circuit board is the cause of the problem which often manifests itself after several years using the dwf 407. Replacing the film capacitor on the circuit board is the solution! Such a capacitor costs about GBP 2. The removal of the circuit board that is in the door is not very difficult, four torque screws along the inside top of the door (not the two for the door lock) a click system in which the print is stuck in the door. On the print are a few connectors with wires to loosen-take picture or mark them for reassembly purposes. There are several types of DWF 407, sometimes the print is slightly different. But the culprit is always the big gray block. The value that you must have is 250/275 V 1,5UF. Many electronics stores have them or can order them. Soldering you can do yourself if you have some experience or ask your local handyman. It is not very difficult, you have plenty of space on the board and only two feet soldering required. After that my dishwasher was as new at the fraction of the price
Oct 28, 2009 | Dishwashers
My washer machine model #2494230 elite only work
your machine need to hang out in better circles...only kidding...it sounds like your selector switch (timer switch) is defective and needs replacement.
Apr 01, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Reset the 'Conrol Lock' on a Whirpool Duet Washer?
press and hold the end of cycle signal button for 3-5 seconds
Mar 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washing machine stops working
I search in the internet on regards to the problems with the Whirpool Ultimate Care II and found out that many others had the same problem as I did. Some solved this issue replacing the switch, so i decided to do the same.
I opened the machine and saw that the switch was not working properly, it was not doing any contact, so whenever I open or closed the lid, nothing was happening. I did a house fixing, with some duck tape i was able to make the system work, and now the machine is washing everything again.
Nov 03, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpol duet
sounds like your door lock switch may not engage.try opening and closeing the door. unplug the unit wait a few minutes plug back in and see if you can open the door. check to see if the door lock lights up.. hope this helps..
Aug 25, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool GU2400XTP Built-in Dishwasher Logo
273 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
