How do I change oil,trans,and primary fluids on 05 Electra Gide Classic harley
Just want to know where the drain plugs are and where to put fluids in
    Master:
  • 752 Answers
For oil change, see if this
http://www.ehow.co.uk/how_7684125_change-2005-harleydavidson-electra-glide.html
(also, more generally, http://www.ehow.com/facts_7792650_do-harley-davidson-primary-oil.html )
is any help.
Is this
http://www.ehow.com/video_2330188_change-motorcycle-primary-fluid.html
of any help ? I'm not sure he working on a Harley tho'
Also see youtube, for example this
http://www.youtube.com/watch?v=jLtZmTf-764
for the 08 model which may be similar. Along the right hand side you will see many other similar videos; if you are lucky there will be one for your exact model.
(For upwards of $10 you can download the complete manual e.g., at
http://www.repairloader.com/manual.php/67c4a3e#.U2ZK23lOUcA)
[obtained by searches of the internet on "oil,trans,and primary fluids on 05 Electra Gide Classic Harley" ]
Hope this lot helps !
4.May.2014
Posted on May 04, 2014
My 03 ultra classic is leaking trans fluid they say its a $1 dollar o ring that cost about $600 to fix?
First off, determine if it's transmission fluid, or primary chain case fluid.
I had the seal on the transmission main shaft go on me once (the seal under the transmission rear drive pulley, behind the inner primary cover).
This can be changed with the transmission still in the bike, but the entire primary needs to come apart, and the transmission sprocket/pulley removed to access it.
If it's primary fluid, it's probably the seal on the inner primary case that the transmission shaft runs through and that the clutch assembly bolts to.
Again, the entire primary needs to be torn down to access this.
Either way, the cost of the part isn't bad, but the labor is the killer, as it's a 6-10 hour job, if I remember the book's quote.
Mar 18, 2014 | 2003 Harley Davidson FLHTCUI Electra Glide...
I,ve got a 2008 Ultra classic, and want to change the fluids. It's got 8000 miles, and i dont have a owners manual. the oil, i can figure out , but the trans, and the primary I dont have an idea.
On the bottom of your transmission, there are two drain plugs, one for the transmission and one for the engine oil. The plug in the center is the transmission drain plug and the one toward the left front is the engine oil drain. The primary drain is a small pipe plug that takes a Torx wrench located at the bottom of the primary cover towards the rear of the bike.
Engine oil three quarts with filter. Then start the bike and let it run for a few minutes. Shut down the engine and check the oil level with the dipstick. The dipstick has two marks on it. "Full Cold" and "Full Hot". Fill to the full cold mark.
Transmission takes 20-24 ounces of oil and the primary takes 38-44 ounces of oil. Do not overfill the primary as it will cause your clutch to drag. All three sections take H-D Syn3 20W50 synthetic engine oil.
May 23, 2010 | 2005 Harley Davidson FLHTCUI Electra Glide...
How do I change all my fluids on a FLHTC 2005
There are three areas that you have to service, engine oil, primary oil, and transmission.
To change the engine oil, underneath the transmission, you'll find two drain plugs. The drain plug nearest the left side of the engine is the the engine oil drain. Warm the engine a bit and drain the oil. Change the oil filter. This is a messy job so put something down to catch the oil as it runs out of the filter. Replace drain plug and refill with oil.
The plug nearest the center of the transmission is the transmission drain. Remove the plug to drain the transmission. Once drained replace the plug and refill the transmission through the transmission fill hole in the chrome cover on the right side of the transmission.
To change the primary oil, underneath the primary outer cover very near the rear of this cover is a small drain plug. It takes a Torx wrench to get the plug out. Remove the plug to drain the oil from the primary. Remove the derby cover over the clutch. Refill with oil through the derby cover hole.
Your bike probably came with H-D Syn3 oil. You can replace the oil with this or any other oil as long as it carries a rating for use in a diesel engine. Here, it must have an API code of "C", example "SJ/CG4". Four quarts of engine oil, Add three quarts of oil and check. Fill to proper level with the fourth. Your dipstick is marked with a "Full Cold" and "Full Hot" mark. Fill to "Full Cold" mark and check again after warming up the engine.
Use Syn3 in the primary or 30 weight oil, 40-44 ounces. With the bike standing nearly straight up, the fluid level should be to the bottom of the clutch spring, large black disc in the center of the clutch. It's a diaphragm type spring.
Use Syn3 in the transmission, 20-24 fluid ounces. Check with the dip stick again with the bike standing straight up.
Nov 04, 2009 | 2005 Harley Davidson FLHTC - FLHTCI...
I JUST NEED THE OIL CAPACITIES AND TYPE FOR A 2002 FLHC ELECTRA GLIDE. ENGINE, TRANS., AND PRIMARY.
Oil change without filter 3.5 quarts
Oil change with flter change 4.0 quarts.
Primary 1 quart.
Transmission 20-24 oz.
Very important check your fluid levels afterwards refilling to make sure you have correct level of fluids. Hope this helps.
JP
Jul 03, 2009 | 2002 Harley Davidson FLHT Electra Glide...
Changin oil on a 2003 Ultra Classic
Are you sure you pulled the right plug. How much oil came out?
Jun 27, 2009 | 2003 Harley Davidson FLHTCUI Electra Glide...
Oil change 1999H D Electra glide
The plug ( 3/4 wrench ) under the trans when your looking at the trans cover ( right side of the bike ) is the trans. If you drained that replace it with 24 oz. of either HD trans fluid or I prefer Golden Spectro 75/140 ( much better shifting on a Harley ( trust me you'll never go back to HD trans fluid ) the drain for your motor oils is on the same pan ( on the bottom ) but it's the plug facing the front of the bike. Looks just like the trans plug. Both use a 11105 o ring which you should replace everytime ( just for piece of mind as well as leaks ) you need 4 quarts of 20/59 HD oil. Hope it helps.
Jun 24, 2009 | 2000 Harley Davidson FLHTCUI Electra Glide...
Changing fluids
Trans plug is under the Primary cover ( Left side ) and the Oil line is under the frame on the left side. Look for a oil line with a plug attatched to it. Run the bike up to operating temp. Primary and trans are the same thing ( Sport Trans fluid ) 1Qt in the primary ( fill throught the little cover on the side of the primary, and fill the oil through the oil tank. Put a little oil in the filter too, before installing, this will give the motor a little bit of oil until the rest of it makes it way through. You'll also need 1 p/n 11105 for the drain plug on the primary.
May 02, 2009 | Harley Davidson Harley-Davidson Motorcycle...
TRANSMISSION SERVICING
Most are using Syn3 oil in engine, tranny, and primary.
This simplifies this, and is a decent oil.
32oz of oil in primary.
20-24oz of oil in tranny
99851-05 primary case/ trans oil(Conv Oil)
there are other brands that surpass the syn3 oil but it takes some hunting around to find a supply.
Ammsol is one such brand and they recommend.
20w50 engine
15w40 primary
75w90 tranny
Hope this is of some assistance
Ed
Apr 20, 2009 | 2000 Harley Davidson FLHTCUI Electra Glide...
Engine oil plug
Another way to locate it, is with the bike on the kickstand, look underneath of it from the right (brake) side. The oil drain plug is on the front of the square looking pan under, and to the rear of the engine. The oil drain is the plug on the front of that pan, on the left (shifter) side of the bike. The trans drain is on that same square looking pan, but towards the right side, and faces down. It screws in and out vertically, whereas the oil drain is horizontal
Apr 13, 2009 | 2000 Harley Davidson FLHTCUI Electra Glide...
Gear Box oil change How do i do it??
Trans fluid and primary fluid are the same oil , The drain plug is under the laft side primary cover. 1 qt of oil goes in the inspection cover on the top side of the primary cover. The oil drain is a hose under the left side by the frame rail. Look for a oil line with a plug. fill with approx 3 qts through the oil tank. Make sure you get the bike up to operating temp before dropping the fluid.
Feb 22, 2009 | Harley Davidson Harley-Davidson Motorcycle...
Computers & Internet Logo
98 people viewed this question
David Payne
David Payne
