Question about Dahon 7 Speed Folding Bike
Handlebars loose I have a Dahon Vitesse, the handlebars are wobbly and when I tighten the allen key bits under the handlebars it either becomes too tight to clip in or clips in but continues to wobble.  If the handlebars are folded down its the bit underneath that causes the problem - the bit with 2 allen key holes in 2 screws. I have also tightened the allen key on the clip itself but this didnt help.
Construct shims from aluminum (soda / cola) cans with scissors. Be careful not to cut yourself, sheared aluminum is very sharp. After you have cut a wide strip of aluminum, wrap it around the handlebar and put it between the handlebar and the clamps. This will increase the diameter of the handlebar and allow your clips to exert more pressure on the handlebars making them tighter. Try not to leave any aluminum exposed after fixing it; it's sharp.
Posted on Jun 16, 2009
Break_2_fix seems to be addressing a different question. The original question is about the "wobble" at the handlebar fold joint. The question has nothing to do with the diameter of the handlebar.
Posted on Jun 27, 2010
  • 1 more comment
  • gdaeman Jun 27, 2010
    Short-term Fix: Building off the shim concept of break_2_fix, consider the following (it's working for me):
    Material: Get some heavy foil, just a little 3 x 3 square is fine... heavier the better, within reason.
    General Concept: Create a foil shim to mold over the locking mechanism to make it have a tighter lock. Warning: This is a bit crude, so use some good judgment in adopting this solution.
    Tools: scissors.
    Setting: Observe the part of the hinge attached to the bike frame. In the center is a silver metal
    pad that has the allen wrench screws on top and on one edge. This is the pad that moves to lock
    the handle bar. The part of the pad that is arch-shaped has a lip on
    it. That lip slips into a grove on the part of the hinge attached to the
    handelbars when locking.
    Process: Cut a 3" x 3" square of foil. Lightly press the foil over the "pad" referenced above to create an impression of the nearly square-shaped pad (square-shaped except for the arch along one edge).
    Use the scissors to trim the foil to within about 1/8-1/4-inch of the outline of the pad that is now molded into the foil.
    Carefully mold the remaining foil over the pad. Fold it down firmly on all edges taking particular care to fold under the part on the arched lip of the pad.
    Extra: You can use a blade of the scissors to carefully cut little half-moon slits in the two holes on top of the pad where the allen wrench screws are; carefully fold the edges of foil, at the slits, down into the holes to improve the foil's grip to the pad (I considered glue, but.. doesn't seem necessary).
    Trial: Carefully lock the handlebars into place. If it seems too tight, don't force it. If too loose, you could try two layers of foil or other refinements.
    My outcome seems to be just right. Locking it into place seemed, if anything, to make the foil better molded to the locking pad mechanism.
    Good Luck
    Minor errata in last post: The locking "pad," with allen key screws, is on the handlebar-side of the hinge.
  • EEyin Apr 26, 2011
    I have a vittesse and a dahon speed, the handlebars loosen all the time but I carry a 8mmm spanner. the single nut needs tightened towards the white nylon bush. dont touch the 2 allen screws on the flat plate.
How to raise handlebars
There is a black or gray rubber plug in the handlebar stem that you can pull out with your fingers. Use a #6 Allen wrench to loosen the stem wedge bolt (only loosen, do not remove!) this will enable you to lift the handlebars and stem up. When you have it at the desired height, tighten the bolt back up with the Allen wrench. Note: on the side of the stem is a "minimum insertion mark" do not raise the stem high enough to be able to read this, if you do then it is too high. The stem could break or come loose if you raise it above this mark and void any warranty.
Apr 06, 2016 | Electra Bicycle Company Townie 21
Raising handlebars
There is a single central connection to the handlebars This is called the "gooseneck". (Ther handlebars slide through the goosenect and then the gooseneck is tightened to hold the handlebars. The connector to tighten is in the front (so you do not get "injured" if you have a collison). Loosten the connector (it may be allen, or perhaps hex nut.). Raise or adjust the handlebars, then tighten. Make sure it is really tight (do not strip the threads). The handlebar has serrations to lock on to the gooseneck so the handlebar - gooseneck bolt will have to be loosened quite a bit to allow the serrations to "jump" to the next serration.
Sep 20, 2014 | Trek 7100
The stem is loose when im riding but i tightend the L key on the top tight as possible n neck still loost any idea?
There are typically two allen bolts that mount on the side of the handlebar stem. Those should be tightened. The top one should only be tightened to remove up and down play in the headset. If you tighten the top one too tight, steering will feel clunky. Only tighten the top one tight enough to remove the up/down play. Use the side bolts to keep the handlebars from turning relative to the wheel.
Feb 11, 2014 | Mongoose 29in Torment Mountain Bike -...
Handlebars allen
If you are asking what size Allen wrench you need to loosen/tighten the handlebars, you are most likely looking at a 5mm. In rare instances, it could be a 6mm or 4mm. As a cyclist, those three sizes are good to have as they correspond to 90% of the bolts on your bicycle.
Nov 10, 2013 | Cannondale F7 CO2 Feminine
Handlebars won't stay upright
The part that holds the handle bars on is called the Head-set this should have adjustment screw/screws they may have a small plastic cover over them to prevent rust. They are usually require an Allen wrench to tighten them. If they become loose again then get some locktight and use this on the handle bars and the threads of the bolts before you tighten them up.
Oct 31, 2013 | Specialized Crossroads
The handlebars on my daughters Jubilee seem to have fallen downward. She thinks a bolt securing it has fallen out, but it looks to me that if we tightened the middle with an allen wrench it would secure...
There are two sets of bolts here. The first one is straight up and down, is probably the one that takes and Allen wrench and is the one that tightens the handlebar stem - that's the pipe that goes down into the frae toward the front wheel. At the bottom of that bolt (inside the bike frame where you cannot see it) is a wedge-shaped nut that wedges the stem tight. If the stem is loose, then you will be able to stand in front of the bike with the front wheel between your knees and turn the handlebars side to side, and if it is loose enough you will be able to pull the whole stem right out of the bike. On the other hand, maybe you mean that the handlebars twisted down (so that the ends of the handlebars are pointed toward the ground - this would mean that the other bolt or set of bolts are loose. Some bikes have one bolt that clamps the top of the stem around the handlebars, and some have 4 smaller screws that do this. If this is where the problem is, then no, you don't need to buy the Allen wrench, but it sounds like you might need a bolt.
Aug 07, 2012 | Motobecane Jubilee Deluxe
I need to heighten handlebars
In the center right below the handlebars is and allen head screw. You will need an allen wrench, loosen the screw by turning it counter clockwise. Lift-up on the handlebars and adjust to the desired height and re-tighten the hex screw. Be carefull not to raise up beyond the lower adjoining yoke line on the goose neck.
Jul 11, 2011 | Specialized CrossTrail
I have a Dahon Mu Uno and when I turn the
The friction is headset pre load, and you need to find a balance. The haynes bike book has a full set up for excatly this. You can find it on Amazon
Jun 25, 2009 | Dahon Cycling
Problems with vitesse
Good bicycle shops carry extenders for just this purpose. They will be glad to help you fit your bicycle to your needs.
Jun 16, 2009 | Dahon 7 Speed Folding Bike
Dahon 7 Speed Folding Bike Logo
1,602 people viewed this question
Top Dahon Cycling Experts
Michial Gueffroy
dante
ray gallant
Are you a Dahon Cycling Expert? Answer questions, earn points and help others
