Question about APC MGE GALAXY 4000 75KVA-3-PH OL UPS 208V (GLF75KF) UPS System
BP SS supply failure
After closing Q4S the static switch does not turn on and the alarm "AC BP SS supply fault" comes up right away. the SCRs and driver board are both ok. any ideas as to where my problem is? thanks
  • 21 Answers
You will have to check Power Supply Bd.
Posted on Jun 04, 2014
How do I diagnose a problem with my TV set?
Hi Gertha
Switch Mode Power Supply.
Either a PCB or a Metal Box. Usually the first place the AC wires go to internally. They fail usually because of Bad Electrolytic Capacitors. Look at the Electrolytic "Tin Can" Caps and see if they Bulge from the top or are leaking on top or bottom,
Replacing these with similar or better values does the trick.
Otherwise replace the whole Power Supply PCB Unit.
Good Luck
Mar 03, 2015 | Vizio VW42LF 42 in. LCD HDTV
Mge galaxy 4000 bp ss supply failed
Make sure that Bypass Phase Rotation is A-B-C. Check that Bypass voltage is within a tolerance of 208 +/-5%. Frequency tolerance is 60hz +/- 1hz.
Any condition not met, and Bypass will not be available
Apr 01, 2014 | APC MGE GALAXY 4000 75KVA-3-PH OL UPS 208V...
I have a MGE Galaxy UPS and it's giving me an intermittent alarm saying "INV. NOT. SYNC./ AC.BP".
Dear Yared,
The alarm is pretty clear about what is going on. It's a syncing issue between the inverter and your bypass supply.
What you can try is to go to the 'Command Screen' of the UPS and select Resynchronize AC BP.
Best regards,
Ron
Nov 13, 2012 | MGE UPS Galaxy 3000 UPS System
I need instructions for my timex clock
Hello
Here are the instructions for your clock-radio.
Installation
1* Remove unit and all packing materials from the carton. You should save packing
materials in case unit needs to be returned for service. If you do not wish to save the
materials, please dispose of them properly.
2* Place the unit on a stable, level surface, close to an AC outlet, out of direct sunlight,
and away from sources of dust, dirt, heat, water, moisture, vibration, or magnetic fields.
3* After installing the batteries (see below) and reading the Maintenance notes, plug the
AC cord into an outlet.
"Sure Alarm" Battery Backup Installation
It is strongly recommended that 2 "AA" batteries be installed into the unit, as directed below,
in order to activate this product's "Sure Alarm" Battery Backup feature. (The model should
come with two batteries already installed.) In the event that the AC power cord is disconnected
or a power failure or other interruption occurs, the "Sure Alarm" Battery Backup will maintain
clock and alarm settings for the life of the battery, ensuring that the alarm (buzzer only) will
sound at the set time. During any interruptions the time and alarm settings will be saved
and automatically restored when AC power is again active.
1* Gently turn the unit over and remove the battery
compartment door.
2. Install 2 "AA" batteries (alkaline is recommended for
longer life), while making sure that the + and - ends
match up with those inside the battery compartment.
3* Slide the battery compartment door back on, making
sure the door locks into place, and gently return the
unit to its upright position.
Aug 19, 2011 | Timex Auto-Set Dual Alarm Digital Clock...
I have an 02 impala Service traction control light comes on right away and when your driving down the road it makes a loud roaring sound when you turn to the left and goes away when you turn to the right....
Hi, your right front wheel bearing has failed. This induces vibration to the wheel speed sensor pickup that caused the traction control fault. Please let me know if you have more questions, and thanks for using FixYa.
Apr 30, 2011 | 2002 Chevrolet Impala
My 1000 watt inverter has stop from supplying AC power
Unless the set is checked into , it cannot be confirmed if the fault is due to :
Failure of the switching semiconductors- drivers- Mosfets
Failure of the transformer
Failure of the switching frequency generator-IC
Failure of the in voltage detect or relays.
Oct 11, 2010 | Statpower PORTAWATTZ 1000 Watt Power...
BMW 330i 2003 model... Recently, the alarm has been going off sporadically... doesn't always happen and doesn't happen at night.... Any ideas? Alternately, how can I disarm the system until I get it fixed
I would recommend checking the hood switch. Raise the hood and lock on the left or right strut tower area. You should see a small switch with a rod that sticks up.try disconnecting the switch and see if the problem goes away.If not you have an interior sensor on the headliner under a trim cover. The cover is clipped on.pull the cover down and try disconnecting the sensor to see if it fixes it.
May 21, 2010 | Anti-theft Alarm System 3 Series E90 E92...
When switch is turned on alarm sounds and there is no power
It could be a cmos battery boot it in bios and check for flagged components, if u do not find anything try it with another power supply as this could several different problems
Dec 18, 2008 | Powerline 200Watt DC to AC inverter...
Proscan 27" tv
it is due to power supply failure. 1 check for loose contact in power supply. 2 it might be due to plug or socket loose. 3 switching circuit failure in power supply. good luck.
Oct 07, 2007 | Proscan PS27500 27" TV
APC MGE GALAXY 4000 75KVA-3-PH OL UPS 208V (GLF75KF) UPS System Logo
69 people viewed this question
Top APC Computers & Internet Experts
Jax Planet
Jax Planet
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
