Question about Electrical Supplies
I need a wiring diagram for a newage stamford generator type sc534c
I am working on a 1970 model 225 kw newage stamford generator type sc534c and I need a wiring diagram
  • 42 Answers
SOURCE: wiring diagram for Generac engine on standby generator
here is a wiring diagram for that engine:
Posted on Mar 13, 2009
  • 153 Answers
SOURCE: electrical wiring for kohler engine
Perhaps you would enjoy the entire service manual. Here it is: http://www.asberry.net/files/TP-2379.pdf
Posted on Apr 29, 2009
protek480
  • 1714 Answers
SOURCE: i need the wiring diagram for the model 40026
Go here:
Champion Power Generators : http://www.cpeauto.com/techbulletin.php
Posted on Jul 08, 2009
  • 5603 Answers
SOURCE: kohler confidant 4 generator service manual and wiring diagram
First thing is to check oil level as low oil pressure will shut it down.
Posted on Aug 11, 2009
  • 7 Answers
SOURCE: Need a manual for honeywell generator model 6054 lpg
Can you please identify the problem you have with the 6054 generator. I may be able to assist.
Posted on Nov 23, 2011
1970 dodge truck ignition switch wiring diagram
Ed, 1970 dodge truck ignition switch wiring diagram. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.sweptline.com/tech/70_awire.jpg
http://www.sweptline.com/tech/70wire.jpg
1970 dodge truck ignition switch wiring diagram Google Search
Aug 23, 2016 | Dodge Cars & Trucks
I need the wiring diagram on a Honda generator model eu2000i for the front cover on the inside any the wire diagram
Type maker, model, user manual in computer search engine. It will bring up sites to get user manual. In the manual, there is a wiring diagram
Dec 13, 2015 | Honda Electrical Supplies
Have a newage stamford alternator c20a kva 15.625 bolted to a deutz model f2l912 engine and have tried to pull the 2 components apart but can only get the 2 parts about 1 inch apart anybody got the an
from what you are describing the generator is a 15 kva unit bolted to the back of a deutz engine
check the end of the alternator armature for a bolt head. it is possible that there is a long bolt going through the centre of the armature shaft and holding the armature to the crankshaft on a taper
some older units used 4 rubber blocks in the drive from the crank shaft and there is a plate to retain them in place ( They were a safety device to protect the unit from damage if the mains power come back on while the generator was running. The out of phasing would stop the armature and rip the rubber blocks up)
Dec 30, 2014 | Cars & Trucks
How to check exciter and need to feed point the portion of avr
What alternator does your model have? Marathon? Stamford Newage? You can download a generic service manual for Stamford here, http://www.advanced-power-technologies.com/mydocuments/fault_finding_manual_8.pdf It is basically the same. If you found the manual useful please leave Facebook feedback https://www.facebook.com/pages/Advanced-Power-Technologies-LLC/1446298015596760
Dec 08, 2013 | Taylor Skid Mount Diesel Generator Set 30...
Wiring diagram for onan 12.5 JC-3CR generator
Did you ever find a schematic? If not I can probably help you. Question is how do I get it to you :)
Mar 02, 2013 | Onan propane generator set, 15.6 kva, 12.5...
Drawings
generator starting working but the output voltage power supply is not working
Jan 17, 2012 | Taylor Skid Mount Diesel Generator Set 30...
I need a diagram to rebuild a 1970 Jeep CJ5 225 Slant 6 Carberater
these are not difficult to rebuild, the diagrams comes with the rebuild kit, just make sure you clean all the parts thoroughly,
Dec 04, 2009 | 1993 Jeep Grand Cherokee
I need a diagram to change a hawkersidley stamford 25kva generator from 240v to 415v
There should be a diagram inside on the wall of the unit where the jumper bars are, where you change voltage connections.
Sep 19, 2009 | Electrical Supplies
Need a diagram for this overcomplicated machine
Will probably bin it. Long experience shows that the ONLY alternators worth having are the British made Newage-Markon which IMHO are superior to both Sawafuji and Mecc-Alte. Voltage Dependent Resistors (VDRs) also known as Transorbs are essential if long term reliability is desired from small gensets. Haverhill Generators get around the voltage spike problem another way - 8 microfarads across the output but one Haverhill generator that I repaired had vibrated apart its control box wiring and fan. These little machines all leave a lot to be desired unfortunately and seem to give endless trouble.
Jul 30, 2009 | Office Equipment & Supplies
NEED A WIRING DIAGRAM FOR SS15MODEL91725381/1972MANUFACTURE CRAFTSMANTRACTOR OLD GENERATOR TYPE /CRAFTSMANTRACTORSS12BRIGGS ENGINE
Go to www.searspartsdirect.com and type in the model #. When you do that you'll see the link for the wiring diagram. You can open and print if needed.
Good luck
Ps.91725381 is the model number that you should type in.
Jul 08, 2009 | Craftsman Garden
Electrical Supplies Logo
53 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
