Air conditioning not working
Have an intertherm air handler. The fan on the inside unit wont turn on. Water is moving in the unit, it's cold, outside unit is working. In FL, 93 degrees and really hot........Any suggestions on what the problem could be and that could be easily and cheaply fixed?
  • 614 Answers
Turn fan to on position to see if it comes on. If you amy have a bad fan relay ot fan capacitor. Need to call service tech sorry
Posted on Jun 16, 2009
2003 ford zx2 air conditioning not blowing cold air
Check and see if there is any Ice on the copper line that runs from condenser (outside unit) to air handler (inside) if so you need a charge. You can also make sure the fan is working on the condenser unit outside it should spin when you have the air on. If it is not you have a bad fan motor. there are other things it could be but these you can see.
May 25, 2015 | 2003 Ford ZX2
My air handler fan does not come on, the outside unit turns on fine. Is their a way to reset the fan?
Check for fan operation by turning the fan control at the thermostat to "on". If the fan blows, it works. If not, check a circuit breaker or fuse.
If the fan blows when forcing it on with the thermostat but not in automatic, check the fan control circuit in the air handler. Danger: high voltage, beware! There should be a system wiring diagram inside the air handler somewhere.
Mar 30, 2014 | Rheem 4 Ton Air Handler - RHLLHM4821JA
Heat pump problems
Some heat pumps have high and low pressure swiches installed to keep compressor from running when unsafe conditions occur that can damage the compressor. If the outside fan is not turing on, the unit is cycling on high pressure, if you see ice forming on the big refrigerant line coming from the air handler, then the compressor is shutting down on low pressure. Low pressure can be cause by lack of air flow through air handler or from a low refrigerant charge.
Feb 13, 2014 | Intertherm Heating & Cooling
Fan wont kick on
a bad fan motor they will go bad is the blower on your inside unit or the condenser assembly outside either could be a bad motor
Jul 13, 2012 | Intertherm Heating & Cooling
My Friends Unit is not working properly. He has a Interthermal AC unit. Model # S38C 060KA . He tells me the unit just blows air not cold air like it should.
Hello my name is Heath it will be my pleasure to assist you. The first thing to check is the filter in the furnace or air handler. Also check the inside coil to be sure its not frozen up. Does the air coming out feel cold? It sounds like the unit could be low on charge which means it has a leak and should be leak checked repaired and properly charged. You would need refrigeration gauges to put on the system in order to properly check the refrigerant charge in the system. One other thing could be a dirty condenser coil. Turn the power off to the unit and use a garden hose with a strong nozzle and spray water through the whole coil to try and blow any dirt or debris through the condenser coil in the outside unit.
Sep 01, 2011 | Intertherm Heating & Cooling
Intertherm 13 SEER split air conditioner fans wont turn on?
OUTSIDE FAN OR INSIDE FAN OR BOTH. IF BOTH CHECK THERMOSTAT WIRE HOOK UP. IF YOU INSTALLED NEW TSTAT CHECK FOR JUMPER ON RH-RC TERMINALS ON TSTAT BACK PLATE. IF INSIDE FAN COMES ON WITH FAN IN ON SETTING AT FAN ON AUTO LEVER THAN PROBLEM IS AT OUTSIDE UNIT. CHECK FUSES IN BOX ON OUTSIDE WALL. SHUT OFF BREAKER FIRST.
Apr 21, 2010 | Intertherm P3RA-060K Air Conditioner
I have a heat pump and it freeze up
If you are referring to the outside unit freezing up, the issue is in the defrost cycle. The defrost cycle works something like this: The unit reverses the flow of freon causing the inside coil to blow cold air into the conditioned space and the outside coil is now working like an a/c unit, it gets warm to melt the frost/ice. The inside unit electric heat strips come on so you do not notice the cold air being blown in. The fan on the outside unit stops running to allow the coil to get good and warm.
Now the unit should go into the defrost cycle every 90 minutes or so. It should not terminate the cycle untill the coil is clear of frost. There is an "Klixon" type termostat that measures the temperature of the outside coil. This is most likely the problem. It is prematurely terminating the defrost cycle. I'd start there first.
Hope this helps, Let me know if I can be of any further help.
Dec 29, 2009 | Intertherm P3RC-030K Air Conditioner
I have a Intertherm heat Pump. Everything turns on inside the house. Blows warm air and the outside Fan wont turn on. Both the outside copper pipes are same temp, neither hot nor cold. Don't know the modle...
If the fan outside doesn't work the compresor will overheat and shut off by the thermal protection inside the compressor , to fixed this you have to replace the fan motor and its capacitor.
Aug 26, 2009 | Heating & Cooling
Bryant air condition fan outside not coming on
Check breaker for outside unit Also check to see if you ahve afloat switch on the inside air handler. Located under or in front of unit. It may be full of water and tripped. Blow out drain if tripped.
Jun 15, 2009 | Ruud UBHC Air Conditioner
WONT COOL OUTSIDE UNIT DOES NOT COME ON FAN BLOWS INSIDE
if the fan outside is turning on and inside fan is blowing too, then you have a compressor problem. could be a capacitor gone bad (or needing a hard start kit) to the entire compressor failure
May 03, 2009 | Intertherm P3RA-036K Air Conditioner
Heating & Cooling Logo
97 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Mack Baxter
Marvin
Marvin
