Question about Dryers
Discolored heat grill in back of dryer
Kenmore electric dryer 5 months old.
SOURCE: Kenmore dryer (electric )
NOT ELITE HE4..... Model 96595400. Replaced thermistor and Hi-Limit Stat. Probably the thermistor.
Posted on Jun 29, 2008
rdial54
  • 14 Answers
replace heat relay
Posted on Sep 07, 2008
  • 19 Answers
SOURCE: kenmore dryer 400series electric not gettin hot enough to dry
you might have a open heating element. ohm out your heating elements.
Posted on Feb 21, 2009
  • 530 Answers
SOURCE: Kenmore electric dryer shuts off after 5 minutes and won't restar
when you try to start it again do you hear a humming comeing from the motor? can you jump start it by turning the drum while holding the start button? If you say yes to these questions you have a bad motor.
Posted on Jun 21, 2009
marka19
  • 1430 Answers
SOURCE: 80 series kenmore electric dryer runs but no heat
This could be the heating element or several other parts more likely the thermal fuse. There is a video on troubleshooting a similar model at www.appliancehelponline.com/servicemanual.html this will walk you thru troubleshooting your problem.
Posted on Mar 28, 2010
Dryer works but timer doesn't move. I just replaced it and still having the same problem.
Kenmore 400 6942 Dryer Heat timer - Questions - Fixya
www.fixya.com > Forum > Dryers > Kenmore > Kenmore 400 6942 Dryer
Kenmore 400 6942 Dryer, heat timer related issues. ... The timer doesn't work. ... the heat turns back on the timer stops,heat shuts off the timer will move again,if the ... not heating/timer knob not turning . the dryer works but is not heating and i ...
kenmore 400 doesn't heat, and timer doesn't move, but dryer ...
www.shopyourway.com > Manage My Life > Questions
I understand your Kenmore 400 Dryer doesn't heat up or the timer doesn't move, butit tumbles sometimes. I found the manual for your Kenmore Dryer in ...
Fixing an Electric Dryer that Doesn't Heat and the Timer ...
? 5:51
https://www.youtube.com/watch?v=0mo_gw0p2CI
Jun 29, 2013 - Uploaded by SamuraiRepairman
Although electric dryers are the simplest appliance to work on, ....and now the dryer won't heat and the timer doesn't advance, butthe motor still runs? .... Diagose a Whirlpool or Kenmore Dryerthat Keeps Running, Wont Shut ...
Dec 21, 2015 | Kenmore 400 6942 Dryer
Dryer doesnt heat up
check breaker/fuse panel first for tripped breaker or blown fuse in electrical panel. if ok, than unplug drier and remove back to check connections to cord, look for discolored burnt or loose connections.. other diagnosis will require a volt/ohm meter
Mar 15, 2014 | Kenmore Dryers
I have a kenmore elite, model# 11062952100. Everything works fine but there is no heat on any cycle. it is about 5 years old. Whats wrong, cost to fix, is it worth fixing
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 28, 2010 | Kenmore Dryers
Hi, I have a Kenmore Elite electric dryer model#
If your fuse is blown could be that your operating thermastat is not shuting off as soon as it should. Try replacing the fuse and the operating thermastat. The fuse would probaly blow before the hi limit.
Jul 16, 2010 | Kenmore 62802 Electric Dryer
Clothes get tuck on the front edge and discolors
it most probably needs to have the felt cushion on the front of the drum replaced.
Jul 09, 2010 | Kenmore 83042 Electric Dryer
I have a 5 year old Sears Kenmore dryer that won't offer heat
This is an electric heated device?
Do you use fabric softener sheets in your machine? If yes, have you tried cleaning the sensor? Look on the back wall for a sensor. Check with Sears for specific instructions.
Sep 21, 2009 | Dryers
5 Year old Kenmore Elite Electric Dryer will not heat.
limit switch either the one on the heating element or the one in the air duct they are easy to check if u know how to use a meter they should read continuity when they are cold and open up at a certain temp
Aug 24, 2009 | Kenmore Dryers
Kenmore dryer 400series electric not gettin hot enough to dry
Feb 20, 2009 | Kenmore 62602 Electric Dryer
Kenmore dryer only heats on delicate
how to install rubber belt on kenmore gas dryer number 110.72712101 ?
Jun 14, 2008 | Kenmore Dryers
Kenmore Electric dryer not heating drum
Check your vent line if it is stoped up you have no air flow bent ocrushed check the flap is not stuck
Dec 12, 2007 | Bosch Axxis WTL 5410 Electric Dryer
Dryers Logo
Top Dryers Experts
