Question about Craftsman 20 hp 42 in. Deck Yard Tractor
I have a yard machines rear tine tiller with a 5.5hp b/s engine. its able to start time and time again w/ full choke and throttle but dies out
You need to rebuild the carborateur, it sounds like the diaphragm has played out, when you must use the choke to pull the gas through the carborateur
Posted on Jul 19, 2009
How do you start a craftsman rear tine tiller?
The tines need to be off the ground for the rear-time model. To do so, put the lever to the “transport” selection, which raises them up a little. From there, put the choke to the “choke” position and the throttle lever to fast. It may take a few pulls from the pull cord to start. When it does, close the choke and switch it to the run selection.
Apr 21, 2018 | Craftsman Garden
I have a Yard Machine rear tine tiller that has sat unused for 4 years. I replaced the engine and while in goes forward and backward, when I engage the tines they won't rotate and the engine bogs
Transmission/differential.
Perhaps the unit sat for 4 years because the tines would not turn and your replacement engine has not solved the real problem.
I'd say disassemble the chain case to discover what's locking the tine drive.
Apr 12, 2013 | Garden
Engine runs on half choke
You probably have some buildup in the carburetor, because tillers are gernerally used seasonally it leaves plenty of opportunities for buildup to occur . Also, you should inspect throttle cables and linkage to insure that everything intact.
Sep 07, 2012 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
I have a MTD yard machine rear tine tiller. Goes forward and reverse but tines wont rotate. How do I fix?
You will have to get into the gearbox. It isn't too hard but is time consuming. Sounds like the drive for the tiller has broken. Could just be the chain in the gearbox for the tiller drive.
Apr 30, 2010 | Mtd Products Yard Machines 158CC Tiller
Engine does not continue to run
Are you laying off the choke at any point? Full choke should only be used when starting a cold engine, it should run with no choke on full throttle. If there is not enough throttle i'd first try adjusting the tiny black screw on the carb beneath your air filter while you have it idling, letting the throttle have a little bit more room. If this doesn't work and you're running it properly than you may need to make some adjustments to the H L settings for your gas/air mix. This is also done while idling mind you and only with a clean air filter.
Apr 02, 2010 | Honda 25cc 4-cycle Mini Tiller
Rototiller pull start won't pull
First thing to do, if you haven't already, change the oil, and remove all 'old' gas.
Then, after that's done, remove the plug, in order to de-pressurise the cylinder.
Then try to crank it again.
If it turns, then clearly, it's not ceased.
Remember, don't loose you're patience, just take your time.
Good luck with that:)
Jul 28, 2009 | Husqvarna PRRT850X 960920015 CA 17" Rear...
I have an old pressure washer that uses Tecumseh H30 engine. After pumping the choke bulb on the carb, it will crank, run maybe 5 seconds and quit. Thanks
When you get it started, move the choke to the middle, then let it warm up. you might have to move the choke back and forth until it warms up, keep the throttle wide open.
Jun 27, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Maxim tiller won't run
Try better quality gas. I had the same problem. Ethanol too high in lower grade gas. Buy better grade or ethanol free. Mine works fine with better gas.
Apr 06, 2009 | Maxim Garden
Need to know the kind of oil or grease that goes in transmission
engine oil is sae 30
the the gear box I think is a 90wt
Mar 10, 2009 | Mtd Garden
Craftsman 20 hp 42 in. Deck Yard Tractor Logo
95 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
