On X-15 Series II, Play button does not work. FF & Rewind are fine
Play button engages, but does not turn the spindles.
JUSTOLDJIM
  • 453 Answers
SOURCE: IBM Wheelwriter 15 Series II
Do any lights stay on or blink if so make sure the printwheel is in correctly, make sure the ribbon and correction tape cassetts are installed correctly, Turn the typewriter off wait 30 seconds then turn it back on if the same thing happens try another printwheel if the same thing happens take in in for repairs.
Posted on Nov 27, 2007
robotek
  • 1512 Answers
SOURCE: TEAC V770 3head tape deck.
Hi saabangerman
The unit sounds like it has a take up clutch or takeup idler problem. Check all the drive assemblies in the unit. Remove the cover from the front of the transport inside the cassette well, and check the condition of the idlers and reel base drives. The counter belt can also gatherup and prevent the takeup reel from working correctly, or fire the auto stop mechanism preventing it from playing, although that sounds to be ok in this case as the unit will FF and REW ok. The takeup drive is supplied by a different drive idler as it requires much lower and more controlled torque. This unit was always considered to be a great tape deck and is well worth a bit of attention for restoration. You can get a new belt kit for $19.00 from here
I am more than happy to answer any other questions you may have about it, just give me a hoy :) Thanks for using FixYa, If you consider the advice I have given you as sound, a FixYa rating is a great reward for my efforts to help you. Cheers.
regards
robotek
Posted on May 29, 2008
  • 3594 Answers
SOURCE: Wheelwriter 15 series II 6783-2
Check to see if the flat ketboard connectors are fully plugged in. If they are you probably need a keyboard.
DickyO
Posted on Oct 04, 2008
Marcos_Ce
  • 71 Answers
SOURCE: Won`t Rewind
Do you still have the remote control? Try with the remote. If this works, the button of the camera is broken and have to be replace by a qualified technician. Good luck!
Posted on Nov 24, 2008
Grubhead
  • 5126 Answers
SOURCE: TEAC CX-370 Cassete Deck
Could be a worn out belt? The cassette loads it the drive down too much. Hence why it turns with no tape.
Posted on Jan 21, 2009
Harmon kardon dc520
Dual cassette deck are often poorly built and full of problem with age. They are typically not worth repair. Get a good deck like the Tascam 122 Mk II as these can be repairs.
I have consulted with clients that have dual decks and the cost to repair will get you a Tascam 122 Mk II in restored condition and it works much much better. I should know as I have been repairing decks for 40 years so far.
Sep 20, 2016 | Audio Players & Recorders
Pioneer rt707 ...ff & rewind buttons work...play
I have not seen a RT707 but in the RT909 there are reel settings for the reel motors as far as torque goes. A copy of the service manual will tell you how to set these tensions. I suspect that you have a setting that favors one direction.
Feb 01, 2013 | Audio Players & Recorders
Hi, I am seeking the region free code for a Samsung DVD-D530? Thanks!
I tried the above steps, but each time when restarting the DVD player, it said 'reset' and asked for the language to be selected again. Pressing the "Fast Forward Fast Rewind Fast Forward Up Down" sequence caused the player to lock up and require powering off at the wall.
I found on another web site that there are different initial sequences. Once I use the one for Region 2, it worked fine.
I found the instructions below on another web site, but it worked for me...
  • Make sure there is no disc in the player.
  • Turn on the player (you can use remote control or front panel, it doesn't matter)
  • Wait for "No Disc" message to appear on the TV screen.
  • Press the Repeat button on remote (plain, not A-B).
  • Press the correct sequence of buttons of remote according to the original region code of your player (it's on the sticker on the back panel of the player). FF = fast forward, FR = fast rewind.
    • Region 2 players: FF, FR, FF, UP, DOWN
    • Region 3 players: FF, PLAY, FR, UP, LEFT
    • Region 4 players: FR, PLAY, DOWN, DOWN, RIGHT
    • Region 5 players: FF, UP, DOWN, STOP, RIGHT
    • Region 6 players: LEFT, RIGHT, RIGHT, PLAY, LEFT
  • If you pressed the correct sequence, a small white number 0 will appear somewhere on the top right of the screen. The white number 0 of the same font and size as the "No Disc" message, so don't confuse with the red "not allowed" sign that would appear when you press a function that's not available.
  • Turn the player off and on again, then you can pop in a DVD of any region and watch immediately.
Apr 30, 2011 | Samsung Televison & Video
How do you turn the volumbe up and down on my camnex mp3 player [t850 4g]
push the play button (V on the top of the unit - other end is pause II) until the volume level (number in the lower left corner beside the speaker icon) turns green (2 or 3 seconds), then push the FF button >>I to raise the level or the REWIND I<< to lower the level
Oct 20, 2009 | Mach Speed TRIO Onyx MP3 Player
Tape won't play, FF, or eject.
sorry to say that none.no trip button for that.i assumed that the magnetic strip of the tape is already wind up inside.you'll need to open the unit up and gently rotate the flywheel of the tape player until you can open the door of the tape compartment.no need to force or it will just break.
Jun 22, 2009 | Sony EVC100 Hi8 VCR
The power is on but the motor will not turn the tape drive. Does anyone know a good repair shop?
Hmm, when you press play, can you feel the motor turning, do the spindles turn on fast forward or rewind? If so you may have one of two problems. First check to see if the cue button is is depressed. If it is jammed, the deck will FF and RR but won't play. If it's not that, but the motor still spins, the motor is no longer making contact with the flywheel. If you have a repair manual, dismantle the deck and check out the motor contact
May 10, 2009 | Sony Walkman WM-D6C Personal Cassette...
Jul 04, 2008 | Teac DUAL CASSETTE A/R 110/220 Single Dual...
Lanier Transcriber unit will not play
Most likley it is a bad motor or a broken belt. There is a seperate motor or FF and Rewind.. If the motor is bad it is likly that the motor control circuit board is bad also (motor shorts and takes out the board also). If there is no "click" when play is selected it could be the play solenoid is dirty and not engaging. I have repaired thousand of these units through the years and in spite of these issues they were a great sounding unit.
BTW this is true for the VW-210, VW-260, p-139 and simular units.
Mar 02, 2008 | Lanier 260T Desktop Cassette Voice...
Denon DRM 740 tape does not play
Just bought a unit from a thrift store. Found same problem; FF & RW OK, but play engages then stops. Also noticed buzzing noise when power turned on. Opened unit, found broken capstan drive belt. FF & RW driven from different motor. Buzz was drive motor running freely with no load - when power is on, capstan is driven all the time for fast play/record start. Replaced with rubber band, and it works --- now looking for replacement belt.
Apr 12, 2007 | Denon DRM-740 Single Dual Cassette Deck
jasbo
jasbo
