Question about Cell Phones
FACTORY REBOOT PHONE NEED FACTORY RESET
    Scholar:
  • 91 Answers
There is four simple step to format . just follow it.
remember if ur phone memory have important data so u should be aware that i will erase ur data.but there is no other methods so..
1-
Power down your device. Before you begin the reset procedure, you will need to completely power your device off. If it is frozen, you can pull the battery out to turn it off.
2-
Press and hold the recovery buttons. The buttons vary from device to device, so you may need to look up the instructions for your particular phone. You will need to press and hold the buttons for a few seconds. Some of the more common button combinations include:
  • Volume Up + Home + Power
  • Volume Down + Power
  • Home + Power
  • If none of the above work, do a web search for your phone's model plus "recovery mode".
  • 3-
  • Select Factory Reset. Once the recovery menu opens, you can navigate the menu with the volume buttons. You may need to open the Recovery menu to find the Factory Reset mode. Use the Power button, some models use the camera button, to select your menu options.
  • You will be asked to confirm the factory reset.
  • 4--
    Wait for the restore process to compete. After your phone resets, it will be set back to factory defaults and will be like it just came out of the box.
    • thank u!
Posted on Apr 02, 2014
How do I factory reboot my phone?
Before beginning, make sure there is power to the phone
1. Go to setttings.
2. go to backup and reset. Depending on which type of samsung this can be found under accounts or "user and backup"
3. Select factory data reset (it may ask to put in pin code)
4. The phone will start the start factory reboot.
Jan 26, 2016 | Samsung Cell Phones
I need to factory reset my phone it is sgh-390g
You should:
Remove your SIM card and power up the phone.
  • Using the keypad, enter *2767*3855#
  • Wait until your phone reboots - usually around 10-30 seconds
  • Phone will reboot with the factory settings
Good luck.
Dec 13, 2014 | Cell Phones
S5600
Samsung S5600 Preston Hard Reset:
  • Press and hold Volume DOWN + Camera + POWER Until Samsung menu Appear
  • Now you see android recovery menu
  • Now select Wipe data/factory reset and press power key to confirm
  • Now select Yes -- Delete all user data and press power key to confirm
  • Now reboot device
  • hard reset done
Hard Reset By Code:
  • Enter Dial number *2767*3855#
  • Now you see Factory Format
  • wait until factory format complete
  • after factory format handset will be reboot
  • hard reset done
Apr 24, 2014 | Cell Phones
Phone locked up
To Restore to factory settings
1. From the application menu, Select Settings
2. select SD Card & Phone Storage
3. Select Factory data reset
4. Select Reset phone
5. Enter your password if required, then Select Yes to confirm
To do Hard reset if your phone is frozen:
1. Turn the power off. If your Samsung Moment is frozen, pull the battery out and put it back again
2. Hold the Volume Down button, Call and End until "Samsung" appears on the screen along with a menu
3. Select Master reset device
4. When the phone is done erasing, choose the option to reboot
Once the Samsung Moment reboot it returns back to factory-fresh default state settings.
Feb 21, 2014 | Samsung Galaxy Reverb SPH-M950 Virgin...
M950 turns on but wont go to home screen
You will need to factory data reset your phone if you are "hanging on startup" (stuck at logo) here is how:
WITH THE PHONE POWERED OFF --
Press and hold the volume up key.
Then press and hold the power key.
When the Samsung system starts release power key
When the Android system recovery appears, release the volume key.
Scroll to:
Wipe data factory reset using the volume down key.
Use the power key to select Wipe data factory reset.
When the options present scroll to "Yes."
Use the power key to select "Yes."
Use the volume down key to scroll to Reboot system now.
Use the power key to select Reboot system now.
Phone should now restart.
Nov 28, 2013 | Cell Phones
Factory reset please help me to reset my Mitel
Reboot phone and hold down the down arrow key. This will put you in the programming of the phone. Use * and # to toggle thru until you see default . Then follow screen to save and reboot
Sep 18, 2013 | Mitel 5215 IP Phone
My Cisco IP Phone 7945G keeps rebooting after I did a factory reset. Is there a way to fix this?
According to Cisco, when initiating a factory reset procedure certain information from the IP phone is erased while other information is reset to the factory default value, as shown in the list below:
Information Erased:
  • CTL File (Certificate Trust List)
  • LSC File (Locally Significant Certificate)
  • IP Phone Call History (Calls Received, Placed, Missed etc)
  • Phone application
Information Reset to Default:
  • User configuration settings (ring tone, screen brightness, sound levels etc)
  • Network configuration settings
t is highly advisable to follow the firmware upgrade procedure in a non-working environment to ensure other phones are not affected (in case of an accidental reboot), and to avoid the freshly factory reset ip phones obtaining the working environment's settings.
Please use the link below and follow the instruction http://www.firewall.cx/downloads/cisco-tools-a-applications/cisco-ip-phone-a-ata-firmware-downloads.html
Aug 28, 2012 | Cisco 7945G IP Phone
Reset zte n860
1.Power off the phone.
2.Press and hold Vol+ key and Power key simultaneously until several blue sentences appear on the screen which are reboot system now; apply update from sdcard; wipe data/factory reset; wipe cache partition.
3.Use Vol+ key and Vol- key to move the cursor to "wipe data/factory reset" and press camera key to confirm it.
4.There are many words "No" and one sentence "Yes -- delete all user data". Use Vol+ key and Vol- key to move the cursor to "Yes -- delete all user data". Press camera key to confim it.
5.The phone will finish the reseting by itselft after about 10 seconds later and then the cursor will be on "reboot system now" and press camera key to confirm it. The phone will reboot automatically.There is no unlock and password any more after the phone is on.
Note:Please remind the customer these two methods will delete all personal information in the phone.
Jun 11, 2012 | ZTE n860 warp unlocked gsm phone
If i restart my phone will i loose all my picturesc and contacts ?
If you do a factory reset, then yes, you will lose it all. If you are just doing a soft reset, then no. A factory reset returns your phone to its original "out of the box" state. A software reset, or "soft reset" just reboots the phone software, much like the way you reboot a computer.
Dec 05, 2011 | HTC Inspire 4G Smartphone
Reset to factory specs for blackberry curve 8330
how to reset the Curve back to factory state (a complete wipe-out). Please note if you just want to reboot the device, you only need to take out the battery.
To reset the phone back to factory state:
Go to Options -> Security Options -> General Settings
Press the BlackBerry Menu key and select "Wipe Handheld" and type in "blackberry"
Thanks.
Jun 04, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
Cell Phones Logo
29 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
