Question about Kocaso M M9100 9-Inch 8 GB Tablet
My tablet usb will not work
My tablets usb will not work
  • Kocaso Master
  • 2,219 Answers
Try plugging in the USB cable between the tablet and the USB port of a PC. The PC should recognise and install the correct driver software.
On the Tablet you need to choose between "debugging" and memory flash disk. Choose the Memory flash disk option on the screen.
The Tablets internal drives will then appear as drives on the PC if successful.
Some PC's cannot install the correct driver software, so you will have to download a generic android one from the Internet.
Posted on Feb 22, 2015
How do I connect the Irulu keyboard to my tablet, besides by plugging the mini usb into the port on the side? Because my tablet doesn't recognize, that it is even plugged in.
first of all, make sure that your tablet has an On the go USB port or data port if not, it can only be used to charge. If you connect our tablet to a computer usb port, and your computer recognises it, then you have a data port.
If you plug in a usb memory stick, and your computer can not read it, it does not have a USB to go port.
Also, some Cable adapters are On the Go wired, and may not work properly.
It may also be that the USB port is not providing enough power from the tablet to the keyboard. In that case, buy a split power usb cable, and plug the red (power only) into a usb charger or powered usb hub.
Apr 20, 2016 | Irulu iulu 10.1 inch Andoid 4.0 Touchcreen...
Have a Polaroid tablet and trying to hook up a usb keyboard to it and it is not working, how can in do this?
If it is a standard USB keyboard, that is probably your problem. Tablets are not like Windows PCs, where everything USB is plug & play. Tablets usually run some version of Android as their OS, and manufacturers may or may not support keyboards. If they do, they will specify what keyboards will work with your tablet. Tablets are a lot like Apple products - not everything off the shelf will work and sometimes it must be manufacturer's products only.
Mar 16, 2015 | Polaroid Tablets & eReaders
I have an irulu 7" tablet that I got for Christmas. So far the tablet is working, however the keyboard case does not work when plugged into the USB port at the top of the tablet. It is my understanding...
Not sure on you particular model but most tablets have 2 mini USB ports one has a power supply and the other is just an I.O port .
Try your keyboard in the other port if you have one and it should work. If not it may be faulty.
HTH
Jan 01, 2015 | Irulu 7" 4gb Mid Google Android 2.3...
How do I transfer photos from eviant tablet to HP PC? The tablet plugs into the wall with no way to insert an end into my PC. The only way I've been able to transfer is thru email a few at a time.
The USER guide here http://www.qvc.com/Eviant-8-Tablet-w-8GB-Memory-Android-4.0-&-Google-Play.product.E223749.html
(Click on second set of red words below pictures to download. marked user guide in red.)
Shows you how to transfer files (photos) to your PC using a micro-usb to usb cable from your tablet to your PC.
Sep 10, 2014 | Eviant 7" 8 GB Wi-Fi Purple Tablet Android...
USB keyboard not working
The biggest problem with tablets and phones is the micro USB socket. They are easy to break if you put them in the wrong way round and it is not always easy to see if they are connected correctly.
Check the USB plug and the the tablets socket are not damaged.
Check that USB keyboard works in another device and that another USB input device works in the tablets USB socket.
I am suprised it works at all. You state you are using Android 2.2 yet USB hostmode was only introduced with Android 3.1
There are some apps in the play store like USB device info which may help. For proper debugging you need an APK which is not for the average user. http://visualgdb.com/tutorials/android/usbdebug/
But cables and plugs are 98% of the problem
Good Luck
Jul 09, 2014 | Irulu 10.1"tft Wifi 3g Android 2.2 Tablet...
Usb keyboard plugged in but not working
Your tablet is not built to accept usb keyboards.
Mar 16, 2014 | Irulu 7" 4gb Mid Google Android 2.3...
Keyboard will not work with my samsung 7" tablet
You need a USB On-The-Go adapter to connect a USB keyboard to your Samsung tablet. Preferably get one with a built-in USB hub and/or card reader. Here is one that I use: www.ebay.com/itm/271371781342
Make sure that the connector on it matches the one on your tablet.
Jan 09, 2014 | Samsung Galaxy Tab Tablet PC
USB port on docking station does not work
Power. You may find that the ower managment settings need to be changed or an external supply is needed.
May 28, 2009 | Motion Computing LE1600 Tablet PC
Kocaso M M9100 9-Inch 8 GB Tablet Logo
73 people viewed this question
Top Kocaso Tablets & eReaders Experts
CrisO
Pieter Vleeshouwers
Pieter Vleeshouwers
Lawrence Oravetz
Are you a Kocaso Tablet and eReader Expert? Answer questions, earn points and help others
