Question about Electrical Supplies
Dryer 220 Breaker Repeatedly Tripping
I have a breaker switch for my dryer outlet that repeatedly trips whenever I try to switch the power back on at the fusebox. The only thing I did was replace the 3-wire outlet with the newer 3-wire outlet required for more modern dryers. It was a pretty easy install--just connected Hots to the same place as before and then handled Neutral. I didn't see a grounding wire in my box, which was the only thing I'm suspicious of. But if that were the problem, I don't know why the circuit never tripped (dryer was working perfectly before) before I replaced the outlet. I'm meeting an electrician tomorrow, but I wanted to get some ideas beforehand. Thanks.
    Problem Solver:
  • 9 Answers
Check all your wires again make sure you have a solid connection also your dryer plug has to fit really good in to the outlet not loose
Don't forget always turn off your power before work
Posted on Apr 01, 2014
  • Azmat Hussain Apr 02, 2014
    Thanks for your help. I talked to my electrician on the phone and he said it's possible that I have the wires wedged so tightly in the box that maybe something is making contact with the box itself (which I expect is grounded). That's why my breaker is tripping right away. I'm going to unwire the plug tonight and try to flip the breaker back on, as an experiment. The breaker shouldn't trip if the circuit is left open, correct? Thanks again.
  • Azmat Hussain Apr 17, 2014
    I figured out what was wrong. The breaker had to be wiggled in order to make contact as I was flipping the switch back to on.
Dryer trips breaker after only a few mins of operation
Check to power at outlet for 220 volts
Check the breaker for the correct amperage cut off.
If the unit had an obstruction in the air flow, it would not trip the breaker.
Try running the unit with just cool air and see if it trips the breaker.
Odds are, you have a defective breaker.
Also, if the home is newly built, check the panel for loose connections at the breaker.
Or you could try a different power outlet, like the hot water heater.
If the unit continues to trip breakers on other outlets, you may have a short in unit.
Apr 29, 2014 | LG DLE2140W Dryer
I have a kenmore Elite dryer it was working fine than blew the circuit breaker, I unpluged it reset the breaker pluged it back it and it sparked and blew the breaker again. I disconnect the motor in the...
If the dryer is tripping the circuit breaker, it's possible that the circuit breaker itself is malfunctioning. or a wire is loose to breaker.
There could be a loose connection in the outlet. A loose connection in the outlet could consist of wiring that is not functioning and is unable to properly manage current. The current needed by the dryer is being mishandled by the loosely connected outlet and drawing more power from the electrical system, tripping the circuit breaker. check outlet to find out !
Mar 29, 2012 | Dryers
SHORTED THE DRYER BY TOUCHING WIRE TO BODY, THERES POWER INSIDE THE DRYER(LIGHT ON), BUT NOTHING HAPPENS WHEN SWITCH IS ON, CONTINUITYIS GOOD ON START SWITCH, WHERE DO I GO NOW
Power to the dryer is 220 volts, with half of the total voltage supplied by each of two breakers. The breakers are combined into one larger breaker, but each side of the breaker connects to a different buss bar in the breaker box. What it sounds like is that one half of your breaker is tripped, and the remedy is to trip the double breaker in order to reset the half that is tripped. If tripping the breaker off and back on does not restore the operation of the dryer, trip the breaker back off, unplug the dryer, and check for any burned wires at the terminal strip where the cord connects to the dryer. Replace any defective or burned parts.
Best regards, --W/D--
Mar 06, 2011 | GE DBXR463EBWW Electric Dryer
220 dryer CH Breaker only trips partially and dryer does not reach full heat. Is breaker problem or dryer?
I would say that the problem is in the dryer, but only tripping partially is not exactly right either. It is easy and relatiuvely less expensive to replace the breaker . $40 .. if you replace the breaker and still get it tripping after a few minutes of opperating the dryer , then it is time to call a service tech for the dryer.
IF the breaker trips immediately when connecting the dryer, then unplug the dryer and try again, to see if there is a wiring problem in the line before the dryer.
Jun 05, 2010 | Cutler Hammer Ch220gf Circuit Breaker
LG Dryer DLE2516W contiuously trips breaker but only on heat setting greater than low
Your circuit breaker may be bad. Run dryer and if breaker gets hot after 10min or so the breaker is bad.
Higher heat settings draw more amperage thus tripping the bad or undersized breaker. 30 amp 2 pole breaker required.
Ck. the power cord for signs of arching. Replace power cord or outlet if damaged.
Jan 04, 2010 | LG DLE2516 Electric Dryer
Dryer keeps tripping the circuit breaker
hello mam please change the mains breaker after tripping for several times the breaker will be defected and check the power socket outlet by removing the socket there should not be any loose connections and skinned wires.
Oct 02, 2009 | GE Profile Harmony DPGT750EC Electric...
Dryer Repeatedly tripping circuit breaker, Apartment Maintenance man said we had a defective dryer, Bought new dryer and 5 minutes after first load was put in it tripped the breaker, Maintenance man...
You probably have a bad plug connection, make sure all the wiring in there is tight, you may see signs of arcing. A bad connection causes resistance, and therefore causes the breakers to trip. It is best to replace the receptacle on the wall outlet with a new one because the problem will just resurface again soon.
Aug 12, 2009 | Dryers
The dryer will not turn on. I know I have power because the light is on. But nothing happens when I hit start
Check for a tripped circuit breaker (a ganged double breaker), sometimes only one breaker trips without tripping the other. Switch breakers off and then back on. If you have access to a voltmeter, check for 220 volts AC at the the two slanted slots in the dryer socket. Occasionally, one breaker of the pair will fail internally--replace the pair. If 220 volts is present, then problem is internal to the dryer. Usually, it is a short circuit in the heating element which causes the circuit breaker trip.
Jul 16, 2009 | Dryers
The dryer keep tripping the breaker
It sounds like the current draw is too high This would be due to overload of dryer, motor overheating binding of the drum assy.. First re level the dryer, next disconnect the power and Vacume out the lint inside around moter, try spinning the drum manually to see if it moves freely( some resistance is ok) Another possibility can be lose electrical connections on the breaker or outlet. Disconnect power before testing. Let me know if these tips helped solve issue
May 14, 2009 | Maytag PYE2300AY Electric Dryer
Whirlpool electric dryer keeps tripping main circuit breaker
First off, be sure the pigtail is wired correctly to the back of the unit. Black and red to the outside terminals, white to the middle, green to the frame or cabinet (should be a green screw close-by). If that is ok, you probably have an issue with possibly a bad pigtail, bad outlet, wiring issue, or possibly a bad circuit breaker or breaker box. Probably going to be more of a electrical problem than a appliance problem. Good Luck!!!!
Feb 02, 2008 | Whirlpool LER5636P Electric Dryer
Electrical Supplies Logo
55 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
