Question about JVC Televison & Video
Hd55g466 lamp timer
I have two lamps that seem to be burned out. They look fine. Are looks deceiving?
  • JVC Master
  • 3,320 Answers
Nope. They are burned out.
Posted on Apr 01, 2014
  • 579 Answers
SOURCE: How to change lamp on Hitach 60vg825
Yes, you are due for a lamp. Save yourself some money by ordering just the bulb p/n UX21516 (instead of the whole lamp assy), install it yourself. There are lots of us that sell these bulbs far below what the assy costs. Make sure it is an OSRAM bulb though.
Posted on Dec 31, 2007
  • 579 Answers
SOURCE: projection lamp burn out
Projection TV makers charge an arm and a leg for their replacement lamps. They make it easy to do but as a result the custom lamp assy is expensive. The trick is to just buy the bulb for your model TV from any number of us aftermarket sources at a fraction of the lamp price and install it in the old lamp yourself. really easy. Some models are real bulb hogs though. Look them up on the net (include the word complaint or repair) before you buy, or you might be sorry. Many class action lawsuits out there - even against some of the name brand makers.
Hope ya fix it!
Posted on Jan 07, 2008
SOURCE: Lamp Replacement Problems for Hitachi 50V500A
I'll tell you what I tran into and how it got resolved...
I experienced the same problem , with the blinking light...
Purchased a replacement lamp..
It didn't work(After market Universal supposably)..
Well..Come to find out.The Replacement lamp's housing looks similar, but the connecters that come out the back of the housing weren't quite long enough to trigger the microbe that activates the lamp in the Television.
Luckily I had the original lamp and it's housing that came with the television..
Took the bulb out of the new replacement lamp
Placed it in the original housing , and BINGO..It worked and is still working...
Posted on Jan 16, 2008
SOURCE: How to reset lamp timer
Go to the menu and you'll find lamp timer section.
Posted on Sep 30, 2008
SOURCE: projection lamp timer reset
I need help resetting the lamp timer. Is there a way to reset the timer w/o the remote? We bought this tv as a floor model 4 yrs ago and they didn't have the actual remote that came with it, so they gave us another remote that works. We replaced the lamp but we keep getting the message that the lamp needs to be replaced and the timer reset. Plus the red lamp indicator is still on. We even used a friend's remote (he has the exact same tv) and it still will not reset the timer.
Posted on Oct 02, 2008
Okay, so my Panasonic PT-43LC14 went black in mid show last night. The bulb is approximately 18 months old. The LED indicators upon Power On are; Power LED blinks green for approximately 70 seconds; Then...
Check the bulb again and look at the root of where the main stem comes out inside and be sure you don't see any bubble like appearence around the stem at the bottom there. If you do see this then the bulb is bad. Otherwise try this: Hold volume down on front of unit and pip on remote for about 5 seconds. Message will come on screen that timer has been reset to zero. This sets the lamp timer to 0
May 17, 2011 | Panasonic PT-43LC14 43" Rear Projection...
I have a jvc tv model HD61z575 It just went out and the led lights are blinking fast at the same time I checked the lamp it looks fine any suggestions
Looks can be deceiving. The lamp is gone. I've had the same tv since 2006. Mine just blew out again. Replace the lamp and all will be well.
Jan 02, 2011 | JVC HD-61Z575 61" Rear Projection...
JVC DLP MOD#HD55G466 what is the voltage from power supply to ballast and into the lamp.I have no voltage to the lamp could it be ballast?
Ballast board gets voltage from power supply connector CN90BL and volts readings are as follows:
Pin-1 = 380V DC
Pin-2 = Ground
Pin-3 = 15V DC
and output of ballast board would be 12,000 volts AC that goes to lamp to generate spark in its electrodes to produce high bright light.
If you get volts on input of ballast board but still lamp does not fire up then ballast board is not working.
Ballast board part number is QAL0765-001 and available with tv-part.com for $125
Hope these info will help you.
Thanks.
Nov 16, 2010 | Televison & Video
Having trouble setting timer o ML200RT
Set on-off times by setting trippers
-Insert trippers
-Red tripper is ON
-Black tripper is OFF
-New timer has 2 sets of trippers
Set time
-Plug-in & turn-on power pack
Turn dial clockwise to set time of day
Manual override:
Turn manual-on-off switch counterclockwise
Troubleshoot:
-Power pack not turned on
-Plug does not have power > try hair dryer in plug to see if it turns on, check GFI breaker in bathroom, replace plug
-Manual-on-off is set to OFF > rotate to ON
-Outdoor lamp burned out > test with another lamp
-Important to replace burned out lamps promptly, or other lamps burn out quickly
-High household voltage will reduce life of timer
-Timer designed to last for many years under normal conditions
Sep 22, 2010 | Malibu ML200RT - Low Voltage Power Pack...
TY-LA1001-K I replaced the lamp and didnt restet
I have searched and searched on how to reset the timer. Most solutions say you have to press and hold the volume down button on the tv while also holding down the zero button on the remote, or the pip or split button on the remote until the screen display reads that the timer has been reset to zero or the lamp and power button both flash.
I have tried every combination and cannot seem to reset my lamp timer. If you figure it out, please share it with us!! I'm frustrated and can't get it to work!!
May 07, 2010 | Panasonic PT-52LCX66 Projection Television
Burned out lamp?
First. Turn on the set and see if the Lamp Illuminates, If so then you have a bad Color Wheel. If the Lamp does not light up, you have a bad lamp.
Take out the lamp and look to the center of the lamp. If you see broken glass inside you have a bad lamp.
Apr 08, 2010 | Samsung HLR6178W 61" HDTV
Lamp burned out on X1 infocus projector, Replaced lamp, new lamp stopped working in about 5 hours, got another new lamp and it does not light at all. Still blinking 3 red blinks(saying the bulb is bad)
make sure the colorwheel is spinning. if it is not, replace it. also, blow the dust out of it with canned air. excessive dust kills lamps quickly. you'll also need to reset the lamp timer. are you using an sp-lamp-009? the sp-lamp-018 looks exactly like it, but is used in th x1a and x2. the x1 only uses the sp-lamp-009. if all else fails, replace the power supply.
Jan 08, 2010 | InFocus X1 Multimedia Projector
Need a lamp door/cover for a JVC Projection TV Model HD55G466. Need to find a parts list somewhere. Can you give me a location?
center cover is hopefully what you are looking for try part number LC21590-001C-A
encompass parts does have an exploited view pdf file but i am not sure if you can go into their website without an account number.
their phone number is 410-676-7300
Sep 18, 2009 | Televison & Video
How Do I Reset the lamp Timer?
I have replaced many lamps in LG TV's and have NEVER heard that. The lamp is meant to be replaced by the consumer but the timer on LG's is ONLY resettable by a special service remote that technicians usually have. The timer has no effect on the voltage to the lamp.
Jul 23, 2009 | LG RU-44SZ61 44" Rear Projection...
Can I reset my lamp timer without replacing the lamp?
That should be fine to do. Even if the projector did alter the current based on lamp life, the worst that could happen in the lamp would burn out completely. A good projector should have a safety circuit with a fuse to prevent damage to any internal components. You should be fine.
Mar 25, 2009 | InFocus IN72 Multimedia Projector
Televison & Video Logo
53 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
