Question about Refrigerators
I have a Whirlpool WHKMD10 water cooler. The on button only flashes and the hot and cold water button doesn't work. What's wrong. I called Whirlpool and they told me to clean it but it doesn't work
The on/off button only flashes and the hot and cold button doesn't turn on.
  • 24 Answers
... Perhaps you should try removing the button that doesn't work, and check the connections and/or contacts.
Here is a link for the manual.
http://kitchen.manualsonline.com/manuals/mfg/whirlpool/whkmd10.html?p=1
Posted on Apr 01, 2014
3 Suggested Answers
  • 177 Answers
SOURCE: whirlpool water cooler #whkm-D40 cold push-button broken, does not release water
First, check its button properly. Second, check the circuit board properly.
Chevy Silverado Parts
Posted on Aug 27, 2012
  • 2692 Answers
SOURCE: I need a manual for
http://www.whirlpool.com/custserv/index.jsp
Posted on Jan 11, 2009
Whirlpool water cooler #whkm-D40 cold push-button broken, does not release water
Aug 27, 2012 | Refrigerators
H2low whirlpool top load washer turns on, fills with water for a second and stops...keeps making a sound on the sensing mode but does not get to wash mode to continue washing.
if the washer is only one month old contact whirlpool and they will give you a service company in your area to contact and it the repair will be free of charge as long as the problem is with the washer and not something that you are doing wrong or something wrong with the way that it is installed, the unit is under mfg. warrnty for one year from date of purchase.
things to check before calling would be, water connections correct? hot to hot cold to cold. are both the hot and cold water turned on?
kinked lines?
i would call a whirlpool certified repair company, they will send a guy out and if its broken they will fix it for free.
Nov 27, 2011 | Whirlpool Washing Machines
I just bought last week whirlpool refrigerator from best buy.week past allready and the fridge doesn't make cold water for drink water is warm and taste strange what is wrong with it?since i have...
Before you call for severcie you should run about 1/2 a gallon of water through the system to make sure the it is cleaned out and no air bubbles in the system. But if you do that and it still doesn't correct itself, then YES - call for service.
Aug 07, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water cooler problem
what is your model number is then we can get started then okay
May 29, 2010 | Whirlpool GI15NDXTSS
My new estate washer with 4 water selections actually only has 2, hot and cold. The warm water setting fills with lukewarm water for a while then shoots in cold water for a while and back and forth. In the...
Yes, this is normal. All newer washer have auto temp control fills. This is to meet energy saving requirements. The less hot water used the more energy saved. Most hot settings on washers give out basically lukewarm water. The detergent made today is made to work well with cooler temperature water, so things will still come out clean.
Feb 01, 2010 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Cold water doesn't get cold
Having same issue. Water cooler about a week old, in use in a small office with about 10 people and 2 5-gal water jugs consumed weekly.
The chiller for the cold water no longer works, and they display lights on the front and on/off switch in the back no longer light up. The hot water is working, I'm wondering if there is a potential recall issue with the unit.
May 18, 2009 | Avanti Hot and Cold Water Cooler
I purchased a whirlpool 40 gallon hot water heater model #BFG1J4040T3NOV in November of '08. since its been installed i been having a problem with the water staying hot for more than 1 shower. After about...
Will the water stay hot in the kitchen sink? Try to isolate the problem. If it is happening at all hot water locations, then it will be related to your water heater. If just in the shower then it is related to the mix of water ratio coming out of the shower hear. If its only the shower, then you are getting too much cold and not enough hot through the pipes. This can be very simple to fix by replacing the handle going to the shower. If this does not work then you may have a problem in the hot water pipes. After you isolate the problem, please post another question here.
Apr 16, 2009 | General Electric GE SmartWater Household...
My washer wont run in the hot water cycle
Sounds to me like your water valves in the back are going bad, just had it happen on mine the other day, I bought one online for like 15.00 that was new solinoid valves for both hot and cold water. took about an hour to install with no instructions (take the old one out, new one hooks up the same way) or call the washer repair people.
Mar 18, 2009 | Whirlpool Washing Machines
Water is hot on both cold and hot side of my water cooler. water bottle on cooler is extreamly hot.
are you talking about a water cooler dispenser with hot and cold valve?
if you do, the cooling side is not functioning well.
is the compressor running? if not, check the thermostat.
if the compressor tries to start but can not. check the relay of the compressor, it may be bad.
if the relay is ok then the compressor is bad.
another thing to look at is the hot water thermostat. it may no longer functioning as to the cause of the bottle to be extremely hot.
tnx 4 using fixya,
drcool
Oct 06, 2008 | Whirlpool Refrigerators
Refrigerators Logo
205 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
