Heating & Cooling Logo
G
Gi Garcia Posted on Apr 01, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Blower will not shut off
Blower constantly running. will not shut off even if thermostat setting has been lowered
Tracy
Level 3:
Master:
  • Master 581 Answers
  • Posted on Sep 11, 2017
Tracy
Master
Level 3:
Master:
Answers
581
Questions
0
Helped
145244
Points
1750
A lot of units have a switch by the blower unit. It switches left or right. One way is automatic running from your thermostat and the other stay running...You can alway turn the blower off from your main breaker box..But that want fix the problem...If I had to guess..You have a small wire loose or disconnected in your thermostat...Take the cover off and look for small wires.. Sometimes these wires get broke moving the settings up and down...Find the lose wire and reconnect...You can replace the thermostat but you will still have to connect the wires to the new one...I have seen people with weed eaters cut a outside wire by the units that caused the blowers and units stay on...Hoor this helps
1 Related Answer
239gatorac
Thomas Woodburn
  • 2638 Answers
  • Posted on Mar 21, 2017
SOURCE: Coleman Evcon furnace blower runs w/ no call for heat. Temp is 5+ degrees above thermostat setting. (Programmable tstat)
When you say door are you referring to the front door or the furnace door? If the unit kicks on AND off by itself I would say it's in the tstat or the tstat wire. If it were internal I would think the blower relay or heat contactor/relay were getting stuck AND THE FAN WOULD NOT TURN OFF until you flipped the breaker. Good luck
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Coleman Presidential II Furnace: No heat and blower motor is running constantly.
This could be due to either an open safety switch such as a rollout or high limit, or the relay could be welded inside the control board constantly sending 120 volts to the blower motor. A less common cause could be a bad thermostat which can be verified by removing the face plate. If the blower stops, then the thermostat will need to be replaced.
1helpful
2answers
Should I set my thermostat fan to auto?
When you set your thermostat to auto, it will automatically shut off when it reaches the temperature you set it at. I personally set mine on auto because I don’t want it to run constantly. This will save you money on your gas or electric bill. The blower will run constantly if you set your thermostat in the on position.
Eb20b/ electric furnance/ blower wont shut-off after heat kicks out, got to kill breaker , runs all the time, installed new thermostat, no change?????? Its cold??????
Check the thermostat and make sure the fan switch is set on "Auto". If it is set on "ON" the blower will run constantly.
I have a Coleman Evcon electric furnace, the blower fan runs constantly and I have to shut the breaker off inside the front cover to turn it off. The switch is on auto and it runs even when the thermostat...
It could be a thermostat problem. Also it will seem to run constantly as it tries to heat and one of the elements are working which could be a sequencer problem.
Rheem RHQA Heater:Blower works but no heat.
Is there a setting on the thermostat for Auto or Fan? If so, make sure it is in the Auto setting. You will have a contactor that turns on the elements and a relay for the fan. Follow the wiring diagram to see which relay energizes the fan then unplug it to see if the fan stops.
1helpful
Continuos running blower
hi! there,
blower auto shutting off and on is dependent to thermostat setting,if the thermostat acquired the temperature set it will shut of your blower,checking thermostat performance switch off unit, set this to a lower setting 1 or 0 switch on this should not runof course,if you set up this to 200 this will run until temperature reached to 200 it will stop.when you set up to 1 or 0 and the blower run thermostat is defective.
fan blower relay, if the 3 contactor is short or permanently engage while themostat reached acquired temperature your blower will still running,defenitely relay is defective.relay is dependent to thermostat switching,it supply holding coil terminal is to lock the 3 contactor to supply source to your blower.
so two common option while your blower run continously
1. shut off breaker, disconnect thermostat on two leads,its like a switch.then switch on breaker and run unit.
observe if run, your relay is defective,it was shorted on 3 contactor.
thermostat is the key to run your blower.
2. if the blower not run when you switchn onunit,then switch off again and try to short or connect the two lead using alligator clip on both side,or have it clip the terminals,then switch on again if the blower run,your themostat is defective,the high volatile of filler bulb was leak it always switch on,no play at all to off and on.
have a nice day,don't forget to rate me,thank's
ideas came from actual and theoritical analysis base on experienced and my study of industrial intrumentation.this will guide you and help you,if you understant flow of current in circuit.
have a nice day
Dayton Gas Furnace - Blower will not shut off
Try national energy they are on line and carry most spares
Top Coleman Heating & Cooling Experts
Paul Carew
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
