Question about Fujitsu Televison & Video
I need a remte control for AC unit
Model number Model No:-ABY45RGA3W
  • 306 Answers
SOURCE: Tonnage of my Carrier AC Unit
3 1/2 ton unit the 042 tells me.
Posted on Dec 11, 2008
bobotfel
  • 236 Answers
SOURCE: replace remote control unit model ar-fb2
If your remote control have display but cannot transmit signal to the unit. Confirm first if the remote is really the problem, using your camera or cellphone camera as your eyes point the remote transmitter to your camera and "on" the remote. You should see light emits in your remote control, if no emitted light then the remote control is defective. But if there is a light the defect is in the unit receiver.
Check also if there is a reset or rst button in your remote control and reset it and try.
Check also if there are error codes in the unit, reset the unit by disconnecting the power supply in the unit for 10 sec. and "on" again and try.
The unit can be operate without remote control, use the manual button located in the unit.
If the remote control have no display replacement of remote is recommended.
Posted on Jan 16, 2009
  • 905 Answers
SOURCE: Model number BM10700D.
If generator has idle control circuit on it already, then it makes job easy. You just need to add on a solenoid that pulls the governor to a slower setting. When the control circuit engages due to no load, then solenoid is engaged, governor position is altered.
Much easier to buy parts from your local distributor to finish the task. No machining, usually more economical vs. reinventing the wheel.
Posted on Nov 27, 2009
  • 674 Answers
SOURCE: We have a RUUD AC unit, model number UAMB-042JAZ. ...
Those are the low voltage wires from the thermostat and transformer. Yes he can just match up the colors and splice with wire nuts or something else to hold the tight. If the transformer got shorted out during any of this it may need to be replaced. Hook them up and if the unit runs, then no problem with the transformer.
Posted on May 23, 2010
blanchettohd
  • 143 Answers
SOURCE: i need a code for a 12 pin remote control unit for
These are available on the internet. If you were to go to google and enter in the information you would find a lot of sites, even ebay. Chamberlain does make an universal remote called a clicker that will program to this too, chamberlain.com. Thanks BB
Posted on Sep 03, 2010
I have a Armstrong air ac unit and need a capacitor. the one installed has no label. model number SCU10B36A-7
Take it with you to the ac parts store along with the model number. They should be able to match it. Most units use the same caps.
Jul 26, 2016 | Heating & Cooling
Need the model number of a fluke clamp on meter, serial number is 21530517
try looking for Invoice (it should have model) on it or ask place where you purchased unit from
Mar 25, 2014 | Fluke 321 Clamp-On Meter Electrical...
I need a master control knob. I don't know the model number of the Emerson Quiet Kool air conditioner.
Without the Model Number, it's hard to know what knob fits your model. However, the link below, may provide some help. But, having the Model Number would be a bulls eye. Remove the front of the AC unit. There may be a manufacturer's data plate inside, which would provide the model number.
http://www.appliancefactoryparts.com/airconditioners/emerson/emerson-knobs.html
Hope this helps you.
Jul 13, 2011 | Emerson Quiet Kool 6GC53 Air Conditioner
Previous tenant left ac window unit Haier HWF05XC5, but took the remote. Can I manually turn on this ac unit? when turning the power button, only the fan turns on, I'm unable to switch to AC
According to the Model Number you listed, it's a Mechanically or Manually Controlled AC unit. There is no remote control for it.Please be certain the Model Number you listed is correct and get back to me.
If it's the correct model number and it's manually controlled. You should have 2 rocker switches. One is to turn the power ON & Off. The other is to set the Fan Speed either on Low or High. Then there is a dial, numbered 1 to 10 to set the cooling level. 1 is min cool and 10 is Max Cool.
If the controls on your unit match what I described above, it's a manually controlled unit. No remote.
I hope this helped you. Please advise. Thanks.
Jul 11, 2011 | Heating & Cooling
I have a new Salem travel trailer with Dometic products. Everything appears to work fine, but when I run my furnace and it turns on, my fan blows from my AC unit. I have owned 2 other RV's but...
Yes it sure does sound like something may be wired wrong, Could you please reply with model number of your AC unit as well as thermostat model? To find your AC unit model number if you don't already have it, remove your ceiling air filter assembly, and it should be on the base of the roof unit, facing you.
The base of the roof (upper) unit will have a model and serial number, and if you see a control box where all the wiring attaches as well, get model number from that too if you will. Those numbers should make it easier to determine exactly where the problem is. Thanks.
May 28, 2011 | Dometic Rooftop RV Air Conditioner
I was just given a Haier air conditioner model HWR05XC7. It is not manual controlled. How do you operate it?
Unfortunately, the model number you listed is not a current Haier model. However, the electronic controlled unit, use a hand held remote control to operate and set the functions of the AC unit.
Call Haier America Customer Support 877-337-3639. As the may be able to help you and provide you with an Owners Manual.
Hope this helps you. Please let me know. Thanks.
May 09, 2011 | Haier Heating & Cooling
Craftsman garage door opener not working properly- car remte not working - pad on wall will open door just few inches then stopsmodel 41a5389p
You have more than one problem. Sounds like you may have a bad drive gear. Remove the cover from the motor unit and check the gear. It is white nylon and will be obvious if it is bad. 41A5389P is not a model number. It is a part number. The model number should be on the opposite end.
Mar 21, 2011 | Sears Craftsman LiftMaster Chamberlain...
My Dometic Rv ac is not cooling but, the fan does run..
Can you give me the model number of your AC unit. There should be a sticker on the bottom of the upper (roof) unit, that you can see when you take the filter down from the ceiling inside. Also need to know if it's a wall thermostat and what brand/model, or are the controls at the ceiling.
Apr 24, 2010 | Dometic Rooftop RV Air Conditioner
Need to know unit size
ckl60 5 ton about a 2003 model on most ac heat pumps the model number reflects the ton sized by 12000 btus per ton also as for the indoor unit cfm rating 400 cfm per ton
May 14, 2009 | Goodman CKL60AR60 Air Conditioner
Televison & Video Logo
27 people viewed this question
Top Fujitsu Televison & Video Experts
Electro Med Services...
Are you a Fujitsu Televison and Video Expert? Answer questions, earn points and help others
