Question about RCA Televison & Video
V390HJ1QYE02 WON'T TURN ON
Turned off and undid cable connect for short time, now on't go back on
  • RCA Master
  • 3,320 Answers
What else did you do? Your post makes no sense.
Posted on Apr 01, 2014
My samsund ht-c650w reciever will not turn on it will beep ,but will not turn on. What should i do?
Hi Mark
Could it be it's turning on, but then off again very rapidly?
Sometimes these systems run a check on their connections when you turn it on, and if there's a problem, turn off again.
The usual culprit is a short-circuit on one of the speaker wires - check all your cables - especially if you have any which run across walk-ways, through doors, or such... they could have degraded and cause a short.
An easy way to check this is with an 'AA' or pencil battery. Carefully disconnect the speaker wires from the back of your AV receiver, and connect each speaker across the battery in turn, just for a fraction of a second - you should hear a pop or a crackle as the speaker energizes from the battery.
Don't keep it connected for a long time - the crackle you will hear will be very short, and keeping the battery connected for a very long time could potentially over-stress or damage your speakers.
Good luck - and feel free to come back if you need more help!
Nov 28, 2016 | Samsung HT-C650W Theater System
My bike doesn't want to start. What can I do ????
Hi, Anonymous and the usual suspects are:
1. Fuel tank empty.
2. Fuel supply valve/petcock turned off.
3. Fouled spark plugs.
4. Engine flooded as a result of overuse of the enricher.
5. Vacuum hose to the fuel supply valve/petcock disconnected, broken, cracked, or pinched.
6. Fuel valve/petcock or filter clogged.
7. Discharged battery, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
8. Loose or corroded wire connection at the coil, battery or plug between ignition sensor and module.
9. Spark plug cables in bad condition and shorting, cable connections loose, or connected to the wrong cylinders.
10. Ignition timing incorrect due to a faulty ignition coil, ignition module or sensors (MAP, CMP, CKP, O2 and/or BAS).
11. Faulty fuel pump fuse or relay.
11. Security alarm needs a reset.
For more information about your issue and valuable "FREE" downloads that you will need please visit the websites below. Good luck and have a nice day.
Steps to Take When Your Motorcycle Won Start Dennis Kirk Powersports Blog
Motorcycle Won Turn On Solved
What to do When Your Motorcycle Won Start
troubleshoot motorcycle not starting
Mar 28, 2016 | Motorcycles
My 32" seiki TV has no picture but sound
Are you connecting to another device for reception, cable, dvd plyer?
Jan 27, 2015 | Seiki 32" LED TV - SE321FB
Fuel pump cycling long time bike won't fire,has good spark.
1. Fuel tank empty.
For more information about your issue and valuable free downloads that you will need please visit the websites below. Good luck and have a nice day.
1098 won start
Ducati 907 906 Paso Workshop Service Repair Manual 1988 1993 Searchable...
Ducati OEM Parts Fiche Lookup and Online Ordering
Ducati Maintenance
Mar 14, 2013 | Ducati Motorcycles
My 1997 Chevy Lumina will not turn on. I thought it was the starter since it started having difficulties turning on. The security light on the dash is permanently on. So i replaced the starter and tested...
REPLACE BATTERY CABLES THE POSITIVE BATTERY CABLE COULD BE SHORTING TO GROUND.REPLACE STARTER SOLENOID IF NOT BEEN REPLACED.BESURE TO PLACE BACK FLEXIBLE CONDUIT THAT GOES AROUND POSITIVE BATTERY KEEP FROM SHORTING TO GROUND. LAST TIME I SEEN BATTERY CABLES OVER HEAT WAS EITHER STARTER AND SOLENOID SHORTING OUT OR VERY LOOSE BATTERY CABLES CONNECTIONS. REPLACE BATTERY CABLES IF THEY ARE MELTED HAVE STARTER CHECKED OUT YOU COULD HAVE FAULTY STARTER STILL.
Sep 06, 2011 | 1997 Chevrolet Lumina
Daughter's TV was on during bad electrical storm. Screen went black and made high pitched sound. cable, internet and telephones all digital through Time Warner Cable. Now TV will not even turn on;...
Ur Main Fuses in the circuits breaker box must be to be restart it back.Turn off/on all the fuses on the main circuits breaker box to all the fuses in the box of the box to restart.All ur electical power outlets should work again.If not those power plug in outlets are shorted and dead must have to be replaced.
Aug 22, 2011 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
My 1993 mercury sable has been sitting an a garage for four years the battery was bad so I replaced.now when I go to start it it Wil clik one time but it won't turn over. Why won't it start?
Sounds like the starter is bad. The one click would be the solenoid on the starter engaging but the starter does not turn. If it does not click the next time you try to start, then that would indicate the solenoid is sticking. Also ensure that the cable to starter is good and the connections are tight. The starter will have 2 wires. 1 heavy wire that runs the starter itself and a lighter wire that runs the solenoid. The second wire seems good. Also ensure there is not an inline fuse in the starter cable. Some cable incorporate the inline fuse in case the wire shorts out to the chassis.
Jul 02, 2011 | 1993 Mercury Sable
Kodak easy share
same with my casio camera, i smacked it down after getting it stuck halfway and now i try to turn it on and it wont work. i need help.
Dec 26, 2007 | Kodak EasyShare V1003 Digital Camera
Ps3 wont turn back on
if you cant get your disk out of your ps3 turn off in back of console hold down the power button with the eject button at the same time turn on the console in back while holding both buttons keep holding until disk ejects might take few times
Oct 20, 2007 | Sony Playstation 3 (PS3) Console
Televison & Video Logo
69 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
