Question about Toshiba Computers & Internet
Uninstall verizon windows live and have original verizon
  • 476 Answers
The original version came with your operating system,I'm assuming you have XP loaded???
Windows Mail has security issues Windows Live Mail has over come,
y
Windows Live has lots of functions the other doesnt,
Would advise reading the help section to understand the differences and functionalities
www.windowslive.com
Cheers Misterdj
Posted on Jun 17, 2009
Why cant i install windows updates-it shows error0x80040609
Uninstall windows Live Essentials
Below are the steps on how to uninstall Windows Live Essentials via CMD line parameter.
a. Go to Start ->All Programs ->Accessories
b. Right click onCommand Promptand select Run as Administrator
c. Run the following commands to uninstall Windows Live Essentials:
· (64 bit) "c:\program files (x86)\windows live\installer\wlarp.exe" /cleanup:all /q
· (32 bit) "c:\program files\windows live\installer\wlarp.exe" /cleanup:all /q
d. A dialog box shows status until uninstallation has completed
The uninstaller for Windows Live Essentials 2011 can also be downloaded
May 13, 2014 | Microsoft Windows 7 Ultimate for PC
Message states msn toolbar has error code 400. how do i fix this
I would suggest you to uninstall the toolbar and check. Follow the steps mentioned below.
a.Close all Internet browsers.
b.Uninstall the toolbar through your "Add/Remove Programs" utility. Choose the "Start" button in the lower left-hand corner of your computer screen, and then click "Control Panel." Choose "Add/Remove Programs" and the programs that are installed on your PC will be listed. Choose "MSN toolbar" and then "Change/Remove." You will be instructed to verify if you wish to continue with the uninstall. Choose "OK" and continue to follow the instructions by choosing "Next" until the uninstall completes.
c.Uninstall the toolbar by using the "Run" utility if you are running Windows XP. Click "Start" and then "Run" and type "appwiz.cpl" in the text box. Press "Enter" and the programs that are installed on your PC will be listed. Choose "MSN toolbar" and click "Remove." You will be instructed to verify if you wish to continue with uninstall. Choose "OK" and continue to follow the instructions until uninstall completes.
d.Open a browser and verify that the MSN toolbar is no longer displayed. You may need to restart your PC after uninstall is complete.
May 17, 2011 | Microsoft Internet Explorer 7
Cannot readf my E-MNail in Verizon Message Center; would like to uninstall the verizon message center
go to control panel
if you use windows xp go to "add remove program" click and at E-MNail in Verizon Message Center then click remove/change program, process will uninstall your E-MNail in Verizon Message Center wait until finish and your E-MNail in Verizon Message Center will uninstalled
if you use windows xp/vista at control panel double click "program and features" right click and at E-MNail in Verizon Message Center then click uninstall program, process will uninstall your E-MNail in Verizon Message Center, wait until finish and your E-MNail in Verizon Message Center will uninstalled
i hope this helpful
thank you for using fixya
Feb 11, 2011 | Dell Computers & Internet
Why cant I fwd a page or email out of windows live with my verizon email address?....Is this an HP exclusive? I miss using microsft outlook? Can this be done? I did create a hotmail address, But it comes...
can you email out of windows live with other email addresses other than verizone? I do not use verizone but it could have something to do with the setup verizone requires... I can send thru gmail server and hotmail with no probs... for hotmail address, let WLM set the account up itself... Or right-click on hotmail account you created (visible in the leftmost panel); open up properties and take a look at the server URL... This one works on mine: http://mail.services.live.com/DeltaSync_v2.0.0/sync.aspx
again for hotmail, you need to use a full login name i.e. johndoe@hotmail.com or whatever; and of course, check yr password...
If you have a google account, you need to set it up yourself. servers are imap.gmail.com and smtp.gmail.com... Also, under advanced tab; for outgoing smtp, SSL must be selected with port no 465; and for incoming, again with SSL selected port (for pop3) should be 995... Incomings are correctly selected by WLM when you choose SSL but you need to correct outgoing by hand....
And one last thing, if you are trying to send something out of your browser, in order for WLM to open up automatically, under browser's tools tab, under internet optins, under programs; you need to assign WLM as the default e-mail program...
Although these do not adress yr verizone question directly; hope the tips will help you along...
Feb 20, 2010 | Microsoft Windows Live Messanger
Windows live quicktime control host failures
Since the quicktime would not update properly, you probably have a bad install of it, so you'll also have a bad uninstall. Restart your computer with the Windows disk in the CD. When it asks you to press a key to boot from CD, press the space bar (or any other key). Let the files set up, then when it asks you to press "R" to repair the system, press that, and let the system do a repair from the original disk. That should fix the system.
Feb 13, 2010 | Microsoft Windows? Vista Home Premium...
Hey I have a bog problem because the windows live messenger is always temporary unavailable and i am sure that it is installed correctly. Solve it !!!
Well we'll uninstall and re-install the WINDOWS LIVE MESSENGER and then everything would be done. plz follow these steps
Uninstall the windows messenger using a UNINSTALLER SOFTWARE UTILITY dont uninstall it from add or remove programs.
Uninstaller software link
http://wugnet.com/shareware/spow.asp?ID=638
then in the same window which shows u all the software installed on your machine go ahead and uninstall the REVO UNINSTALLER so that all leftover is out.
Start > Run > %temp% > delete all the files.
Start > Run > prefetch > delete all the files.
Restart your system and DOWNLOAD AND INSTALL fresh copy of WINDOWS LIVE MESSENGER FROM THIS LINK BELOW...
http://download.live.com/
Dec 20, 2008 | Microsoft Office Professional 2007 Full...
When i am on msn and want to put on webcam a message appears in a conversation saying Messenger is not available right now. Please try again later. (0x8ac70202)
This might be a compatibility problem between your webcam drivers with the new Windows Live Messenger program. You may want to:
1. Update your webcam drivers and see if Windows Live Messenger can detect it when you run the Audio Video setup from its Tools menu.
2. Or you can downgrade back to the older version of Windows Live Messenger which is compatible for your camera. Doing this however also requires that you uninstall all the Windows Live Beta products from your computer.
Note: You will not see a separate Windows Live Messenger on your Add/Remove programs, instead you will either see there Windows Live Beta products or Windows Live Essentials.
You can download the older versions of Windows Live Messenger from:
Windows Live Messenger 8.1:
http://www.microsoft.com/downloads/details.aspx?familyid=d78f2ff1-79ea-4066-8ba0-ddbed94864fc&displaylang=en
Windows Live Messenger 8.5:
http://www.microsoft.com/downloads/details.aspx?FamilyID=7a1aae73-48cc-4f7a-b445-0487bd5e84ef&displaylang=en
~ Carlos
Nov 10, 2008 | Computers & Internet
Windows Live Messenger Error 80004005
To fix Windows Live Messenger error 80004005, you have to reinstall the latest version of Windows Live Messenger From here - http://get.live.com/messenger/overview
In case you are curious, the cause of this error is the Microsoft .NET Passport account is blocked by the .NET Messenger Service because your computer may be running a non Microsoft program that is not licensed by Microsoft this is a violation of the MSN Messenger Terms of Use.
Error 80004005 was originally created by MSN Messenger maintenance procedures. In order to stop users from using non Microsoft add-on's, that may harm Microsoft's service.
Have a good day.
Nov 10, 2008 | Microsoft Windows Live Messanger
Windows live messenger. Display picture always reverts to original after I've changed it.
You might be having problems with your Windows Live software, try uninstalling it and reinstalling it from messenger.live.com.
If this does not solve your problem, it could be your account on Windows Live, in which case you may be out of luck!
Nov 03, 2008 | Computers & Internet
Computers & Internet Logo
50 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
