Question about Canon imageRUNNER 1023iF Black and White Copier
Error E 354
Turn on machine and get error code E354
2 Suggested Answers
  • 149 Answers
SOURCE: error code 354-0002 ir7200 serial number pcb
when you changed the main controller for the copier did you use the counter board that was on the old main controller or did you put the counter board from the old one on the new one.... if you don't use the old counter board with the new main controller then that problem will occure
Posted on Jun 12, 2010
Getting error e354. What is it?
sounds like a pcb h/w problem - can u say expensive to repair?
Oct 17, 2013 | Canon lc-710 - Laserclass 710 Super G3 Fax...
E354 error
Oct 17, 2013 | Canon Office Equipment & Supplies
Hoo.comi want to solve the problem in my copier canon ir 2016, error code e354
this is error code that isn't stated in service manual and doesn't have description. When this error occures the procedure is to report to Canon service center. The same errors were on ir1600/2000 series, but without some good explanations.
So, call authorised CANON service partner!
Sep 13, 2011 | Canon iR 2016i Black and White Copier
Error E354-0002 ir 8500
Error E354 in Canon iR 2016
error e354 code appear when you replace PCB controller board.
Please note. Before replace your PCB board with other one.
Pull out a small (FRAM COUNTER) chip from your old PCB board you can found it right side of the PCB board near a battery cell the chip attached with screw open screw and pull it out and attached it with your new PCB board .install your PCB board in the machine and turn on power error e354 will go off.
Aug 27, 2011 | Canon imageRUNNER 8500 Copier
Code erreur system E246 E354 canon IR1600 problem:
CANON IR 1600 ERR CODE 354 IT CAME AFTER REPLACING
MAIN BOARD HOW CAN I CORRECT THIS PROBLEM
Dec 27, 2010 | Office Equipment & Supplies
Canon ir2020-seystm err e354 please tel me what ido tanvir gillani
E354
•When turning ON the power, inconsistency of the serial No. of
the serial number PCB and that of the controller PCB
(SRAM)/counter memory is detected.
•When turning ON the power, it is detected that no serial
numbers are assigned to the serial number PCB and the
controller PCB (SRAM)/ counter memory.are you trying to change the counter board this not possible bec the serial no of the machine is embedded on the counter board so no counter tampering allowed
Oct 01, 2009 | Canon imageCLASS D320 Digital Copier
Error-9-354
User Interface (UI) DIAGNOSTIC ENTRY:
Turn on the power… then while holding down the ‘0’ button, press ‘Start’.
The screen will prompt you for an “Access Number”… use the keypad to enter ‘6789’ which is the Default Access Number.
This should bring you to a menu of options to choose from:
• NVM Reset (Non Volatile Memory) / NVM Initialization
• NVM Read / Write (memory adjustments) you will need to know which codes do what
• Component Control (for testing sensors, motors, etc.)
• Print (for running Test Patterns from Diagnostics)
• Subsystem Check (for fuser nip measurement check out, and developer unit check out)
• Max Setup (for setting up copy quality)
Set NVM to 776-060=0 and 776-372=0
Hope that helps
Mike
Sep 23, 2009 | Xerox DocuColor 12 Color Copier
Error 354
E354
controller PCB (SRAM)/ counter memory , if you are try to change the counter pcb to get rid of high meter reading this error is possible, this a security measure of canon to prevent meter tampering
Jul 15, 2009 | Canon Office Equipment & Supplies
Canon IR-3300, error 354
E354
Jul 14, 2009 | Canon Office Equipment & Supplies
Canon imageRUNNER 1023iF Black and White Copier Logo
123 people viewed this question
old marine
old marine
