Question about Watchdog Breathalyzer Watchdog Breathalyser
Under-appreciating Mine is not working. my friend had 6 12 oz beers at 145 lbs. in the span of an hour and a half. It read .020. What the hell guys. If he drove, you would have a lawsuit on your hands. I switched to you guys from a backtrack because y'all have nothing but good reviews. help?
  • 15,557 Answers
There are a lot of things that impact the accuracy of a testing device like that, especially when it is in an uncontrolled environment. Start with the test subject:
1. What kind of beer?
2. How much did the subject eat while drinking?
3. What medical conditions does the subject have?
The testing machine"
1. How is it stored?
2. How old is it?
3. Exposed to anything harsh like high humidity? Temp?
4. What environment was it used in? Cold Hot?
The only real way to know is to test it against another testing instrument or use a known solution of alcohol and water
Posted on Jun 03, 2014
Beer system won't pour properly
Most of the time this reason is the beer temp and co2 is not right. first you dont go buy box temp but need to get beer temp. first make sure you have a calibrated thermometer. check your thermometer by mixing up a glass of ice and water let it stand a couple Min to achieve 32deg. put thermometer in water let stand 2 min to make sure it reads 32 deg. now draw a couple of glasses of beer in the same cup pour each in a pitcher. now draw a 3rd glass of beer in the same glass put the thermometer in it you wont the beer at 38 deg if to cold turn your box thermostat up or if to hot turn your box thermostat down to achieve a 38 deg beer. now it is time to check the CO2 pressure, you wont it at 12 psi. first drink a couple glasses with your friends this will let your keg pressure equalize. Now it is time to do a test poor. If the faucet gives a spurt of foam when you open it or the beer runs foamy-clear-foamy-clear than the pressure is too low, bump the pressure up 2 LB and let the pressure equalize a few min. If the beer runs to fast, turn off the co2 at the shut off where the tubing connects to the regulator (Always turn off the shut off when adjusting the regulator). Release some pressure from the keg by pulling the pressure relief valve on the keg coupler. Drop the co2 pressure 2 lbs. Turn the co2 line back on and let the pressure equalize. Often you can tell if the pressure is too low by looking at the beer line at where it connects at the keg coupler. If you see bubbles rising up the beer line from the coupler the pressure is to low or the seal on the keg or coupler is bad. Over many years of trouble shooting 3/16" bore shanks and fittings can cause a burst effect releasing carbonation from the liquid. The beer flow looks good but you end up with a glass half full of beer and half foam. For this reason 1/4" bore shanks and fittings should always used on the liquid side.
Mar 04, 2014 | Scotsman Kitchen Appliances - Others
To convert 15:3 to kg
"15:3" is a ratio, "kg" is a measure of mass (or weight). Your question is like asking how to convert one-half to pounds.
Do you want to convert 15 lbs to kg? That would be about 6.80 kg.
Or do you mean 15 lbs 3 ozs? That would be about 6.89 kg.
Or do you mean 15.3 lbs? That would be about 6.94 kg.
Or, since 15:3 is 5, do you mean 5 lbs? That would be about 2.27 kgs.
Dec 05, 2013 | Office Equipment & Supplies
What is the R134A capacity on a 2003 Toyota Camry with a 4 cylinder engine? A repair shop billed me for 4 pounds.
It should be on a sticker under the hood
I will guess,maybe 24 oz ,less than 2 lbs
The most I have every seen since 1967
doing it, was 36 oz (2.25 lbs) back in the
1980's,since 1993 & the use of R134, the
systems have gotten smaller
Jun 13, 2011 | 2003 Toyota Camry
System error 00200060 NO SYSTEM FOUND ON HDD ona Toshiba MEGF40. I tried firmware upgrade, reformatting but not working hellp me
Okay, here's what you need to do. I'm assuming at some point yours like mine was formatted under windows. This is bad for them lol. Locate your copy of gigabeat room, and install it. This comes with a extra program in the start menu titled formatting utility for gigabeat. Format with this program, and then look under program files/toshiba/gigabeatroom/GBsystem. Copy GBsystem to the gigabeat, then turn the battery off with the switch on the bottom for thirty seconds. That should do it.
IMPORTANT NOTE!!!!!!!!!!!
This can only be done with a computer running USB 1.0. My newer computers could not "see" the gigabeat properly. I used an old machine with outdated USB to get mine to work again :) you can also check for aftermarket firmware called Rock Box, just installed that one mine, no more converting music to *.sat, it'll take straight mp3s now just like it should :) uploaded 20 gigs to it in less than half an hour :) beats the hell out of waiting ten hours for 8 gigs lol!
Jun 14, 2010 | Toshiba Gigabeat F40 40 GB MP3 Player
1996 chevy silverado is hesitating..it starts and everyhting when driving it hesitates and back fires what could it be?
HI. LOOK YOU COULD BE PLAYING AROUND WITH IT, LISTING TO YOUR FRIENDS TO WHAT TO DO. STOP!!!! GO AND GET IT PUT ON A SCAN IT WILL ONLY COST YOU 30 OR 40 BUCKS HELL MAN YOUR GOING TO SPEND THAT BUYING BEER FOR YOUR FRIENDS THAT KNOW JUST WHATS WRONG WITH IT. GOOD LUCK. JIMBO
Aug 24, 2009 | 1999 Chevrolet Silverado 1500
Kenmore fridge not get cold enough and coils icing again
check all heaters on frezer side and check coil under unit to make sure clean ajust timer at the top of icebox side behind plastic plate where light bulb is it shold be onthe right side top turn until unit turns off then turn one half this is the timer for defrosting cycle.
Jul 23, 2009 | Kenmore Refrigerators
How long will one pound propane tank last
The 16.4 oz propane bottle contains 1.02 pounds of propane.
1.02 lbs propane equals 16.320 oz
16.320 oz equals 22.032 BTU’s.
The RMC-8001SS has two settings, maximum and minimum
The Max setting is rated at 8,000 BTU hour.
22.032 divided by 8,000 equals 2.754 or 2-3/4 hours
The Min setting is rated at 4,500 BTU hour.
22.032 divided by 4,500 equals 4.896 or 4.8 hours
One 16.4 ounce bottle will burn 22.032 BTU’s @8,000 BTU’s per hour for a period of approximately 2-3/4 hours and @ 4,500 BTU’s per hour for a period of approximately 4.8 hours.
Jan 18, 2009 | Dyna-Glo RMC-8001SS Heater
Waterproof
yeah i was in Hong Kong and i was having a good time and my camera fell in a cup of beer ever since, it has the same symptoms mentioned above! i have washed it in my pants, its been dropped in snow, tumbled half way down a mountain but one cup of beer was the breaking point for mine. Now i was trying to see any troubleshooting tips for it because i am climbing Mt. Fuji tomorrow! damn So i am screwed! NOT BEER PROOF! MY suggestion, GO BUY A NEW ONE! Haha! The new model they came out with is great i bought one for my wife and she has used the hell out of it and it kicks ***! Feels cheap and not as tough as the 720 but it is tougher!
Apr 26, 2008 | Olympus Stylus 720 SW Digital Camera
Watchdog Breathalyzer Watchdog Breathalyser Logo
461 people viewed this question
Top Watchdog Breathalyzer Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Watchdog Breathalyzer Health and Beauty Expert? Answer questions, earn points and help others
