Question about Ecco Electronics 3735A] Directional LED: rectangular surface mount, 12VDC, 11 flash patterns, amber
Need user guide for ecco 3735
Need to know how to connect wires and operate light
I have a Kenwood kac-628 amp and it turns on but only red lights. All wires are good and have good connections. I opened it up and there is a brass looking piece that seems broke. Maybe a piece is missing...
Disconnect the speaker wires from the amp side. Turn the amp on. Within about 5 seconds you should hear a faint click from the amp. If you don't hear the click, the amp probably has a problem. ie. Shorted outputs. If you hear the click reconnect one speaker and turn on again. If you don't hear sound disconnect that speaker and connect the other. If you have sound with either speaker the one that is disconnected is the problem. Check speaker wire carefully for frayed ends touching each other.
You can swap the speakers at the speaker end one at a time, to determine if it is the speaker or the. Wire.
Feb 02, 2015 | Kenwood Car Audio & Video
My ecco tv has been locked,it has a blue screen
Hi. Just find the user's manual. It should be explained there. Of course you need the original remot as well. Good luck.
Oct 01, 2014 | Televison & Video
Siren wiring car ALARM SIREN TO TOGGLE SWITCH/WANT TO CONNECT SO I CAN TURN ON / OFF AT A FLIP OF THE SWITCH FOR CAR HORN
The siren has two wires: connect the red wire to a fused battery source. Connect the black wire to one side of a two wire toggle switch. Connect the other wire of the two wire toggle switch to a chassis ground. Now you can control the siren by applying the ground when toggling the switch.
May 24, 2013 | 850 Back Up Alarm - 107 Db Reverse Mount
3 wires inside are detached. I do not know which is which. Help
See the SM57 User Guide. The User Guide will probably show only two wires. The third wire was used on older mics and connects to the center ground lug of the cartridge.
Dec 13, 2010 | Shure SM57-LC Professional Microphone
I can't find instructions on how to hook-up the back up alarm. Ecco must have a copy they could send me. Help me please. Thanks in advance!!!
Backup as in backing up a truck. You must locate the reverse wire which is on whens the truck is in reverse. You can follow it from the reverse light at the tail light.
Backup as in alarm siren at a different location like inside the car. I have done this before. I mounted the siern in the front under the hood facing down and the other inside the car. It was really loud. You can do the following and use the term remote for the signal output from the alarm and that will be enough to power both sirens without burning stuff out. The Fan 1 and 2 exchange for siren 1 and 2 and you should be good.
Connecting Additional Devices to the Remote Turn On Wire Using a 30 amp SPDT relay, connect terminal #87 to constant 12 volts positive with a fuse rated to the sum of the additional accessories you've added and the components you need to turn on. (If you have two fans rated at 5 amps each and a neon light rated at 10 amps, you would use a 20 amp fuse plus 200 ma for each amplifier and processor.) Connect terminal #85 to ground, terminal #86 to the remote turn on wire from the head unit, and terminal #30 to each accessory with an appropriate fuse. A fuse (not shown) could also be used between the output of the relay (#30) and the remote turn on wire of the amplifiers and/or processors for extra precaution.
Thanks
-david
Nov 10, 2010 | 850 Back Up Alarm - 107 Db Reverse Mount
I have hp deskjet f4180 all in one and do not know how to operate it
It's not simple to give all the instructions here and let you know how to operate the machine. It's best you refer the user guide/manual and follow the steps to set it up and to operate it.
Click here to download setup guide
Click here to download User guide
Click here to download basic user guide
All the files are in pdf format, you'll need pdf reader like adobe reader or foxit reader, (click here to download adobe reader)
If you need further help, let me know.
Good luck.
Thanks for using FixYa
Sep 20, 2010 | Office Equipment & Supplies
Bissell powersteamer
BISSELL User's Guides can be downloaded at www.bissell.com
On the front page under Customer Service click on User's Guides and enter the model number of your unit.
User Guide will be displayed as a PDF file.
Jul 09, 2010 | Bissell 8806 Powersteamer Upright Vacuum
I would like a users manuel for my Brother printer MFC-295CN. The only thing that came with my printer was a quick setup guide. My dealer sold me ECCO print cartridges and they were not functional. I took...
user guide and manuals available from this link http://welcome.solutions.brother.com/bsc/public/eu/gb/en/doc/manual_index.html?reg=eu&c=gb&lang=en&prod=mfc295cn_all&dlid=&flang=English&type2=-1
Direct link to user manual PDF http://welcome.solutions.brother.com/BSC/public/files/dlf/doc002480/cv_mfc255w_ukeng_usr_lx1489004.pdf
  • If this solutions solves you problem, please do not forget to rate my solution.
  • If not, then please comment back so I can help some more
Mar 31, 2010 | Office Equipment & Supplies
Need ESSID and WEP info for a Toshiba Satellite A205
The users guide for your laptop won't have information about ESSID or WEP for any wireless networks you are trying to connect to. SSID is Site Security Identification. That is the name of the wireless network you are connecting to and WEP is Wired Equivalent Privacy and is a key that is set up on the wireless network that if you don't know that key you can't use that wireless network even if you know the SSID. Each wireless network will have its own ESSID and WEP settings. If you control (I.E. you have the username and password for that router) the wireless router that you are settings up you control what the ESSID and WEP settings are. If you purchased the wireless router that you are trying to connect to, you might need a users guide for that router or if the company you get your Internet from owns your wireless router, you need to contact them concerning the setup of that wireless router.
Hope that helps.
Good Luck
Jan 08, 2009 | Toshiba Satellite A205-S4617 Notebook
Ecco Electronics 3735A] Directional LED: rectangular surface mount, 12VDC, 11 flash patterns, amber Logo
29 people viewed this question
Top Ecco Electronics Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Ecco Electronics Audio Player and Recorder Expert? Answer questions, earn points and help others
