Question about Frigidaire PLCS389DC Dual Fuel (Electric and Gas) Kitchen Range
Oven shuts off while baking and will not restart till oven cools off??? thanks mark
  • Official Brand Answer
  • 4,342 Answers
Good Afternoon Mark,
I see that you're having trouble with your Frigidaire range, model# PLCS389DC, shutting off in mid-baking, and will not restart until the oven has cooled. It sounds like it is either the temperature sensor, that is sensing a runaway oven temperature, or the control board itself that might need replacing. I suggest contacting you local authorized technician for further assistance. They will be able to determine what exactly is causing your oven to cut off in mid-baking.
-Best Regards-
WP
Posted on Apr 04, 2014
Oven shuts off while baking will not come back on until it cools off
sounds like ur oven sensor to me check with a multi meter
Sep 11, 2014 | GE Ovens
Oven shuts down while baking
thermostat my be brokenit thinks its hot so it shuts the heat off....
Apr 21, 2014 | KitchenAid KERS807SSS Electric Kitchen...
When trying to thermal/radiant bake, convection fan at the rear does not stop turning after the preheat. Why doesn't this happen? Isn't it then convection baking?
Most wall ovens have a cooling fan that comes on when the oven has been on for some time. It is separate from the convection operation. It should shut off after the oven has been off for a time.
Nov 12, 2013 | KitchenAid KEBS279BWH 27" Double Electric...
Frigidaire Self-Cleaning Oven Model FEF353BFW and F1 Error Code.
I just had the same problem! If I ever see that f9 again and hear that annoying constant beep....I will pick up and dispose of that oven on the front lawn. Lol. Took a pair of pliers and turned the lock clock wise till the light went out. Silence!
May 02, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
My GE Mod #JBP65GS1AD oven recently started acting up. The bake element had a small glowing area 1/4" long even with the oven turned off. We used it a few times, shutting off the power in between...
The way it can be tested is access the back panel so you can get to the oven control(its the clock asm) find a wire terminal on the clock marked as BA for bake and use a volt meter and see if 120 vac is coming from that terminal when the oven is off. The wire must be removed from that terminal so you not getting back feed and has isolated the test just to that. IF it has 120 vac or actually and voltage higher than about 5 vac when the oven is supposed to off the relay board (aka clock) is bad. UNPLUG OR TURN OFF BREAKER TILL WIRE IS OFF OF BA AND READY TO TEST then restore power make sure its marked as BA their is another marked BR thats for the broil element.
Good luck, i hope this helps
Gene
Aug 01, 2011 | GE Ovens
Oven shuts off in middle of cooking/baking. stove top burners work just fine.
GE oven - SHUTS OFF ON IT'S OWN
I have a built-in GE Electric oven - model #JTP20B0F7BB. It shuts off in the middle of cooking sometimes, but not all of the time. It does it about 1 out of 4 times that I use the oven. Any help would be appreciated?
Apr 17, 2011 | Jenn-Air Ovens
GE Oven JTP15BW Broil Element on, Bake Element off during baking.
I have the same problem. Just swap the 2 wires that are marked as 'broil' and 'bake' on the controller board. But sometimes it switches back, then I have to swap the wires again.
You might want to leave the 'broil' post unconnected to prevent burning food..
Nov 21, 2008 | Jenn-Air JJW8530C Expressions Collection...
Oven shuts off by itself
When your oven reaches the desired temp. it shuts down then turns back on again after it cools down a couple of degrees and cycles like this during the complete baking cycle. If your ignitor or oven valve is getting weak it would cause this symptom.
Oct 31, 2007 | GE JGRP20 Gas Single Oven
Whirlpool oven issue
Usually, when an oven won't bake, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
Oct 26, 2007 | Whirlpool RBS305PDS Electric Single Oven
Frigidaire PLCS389DC Dual Fuel (Electric and Gas) Kitchen Range Logo
133 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
