Question about HP Officejet 6700 Premium E-All-In-One
Scanner lid hinge broken or missing
Opened the scanner lid, heard a pop and hinge on the right is either broken or missing. Can this be replaced/repaired?
  • HP Master
  • 783 Answers
If you read through the posts, there are many ideas on what to do. The cheapest and easiest way I found to fix a broken hinge is to follow one the ideas in the posts. I wrote a detailed post step-by-step. In quick summary, I broke the other hinge and removed all the broken pieces to both, so the lid would lay flat again. Printer doesn't care if the hinges are not there. The manual is on line:http://h10025.www1.hp.com/ewfrf/wc/manualCategory?cc=us&lc=en&dlc=en&document=&product=3635378 Hope It's resolve all Your Printer Problem,
Or Still having Problem Then follow Us For
HP Support
Posted on Apr 01, 2014
2 Suggested Answers
Puppet03
  • 172 Answers
SOURCE: Hinge for the Cartridge Door will not latch. Seems
good old duck tape ;) or go to a print repair shop and see if they have and parts for you.Ink shops sometimes do there own repairs too so try there
Posted on Oct 24, 2009
Testimonial: "Thanks I did not know the Ink shops could do repair. "
The left hinge is broken on my pro905 how do you fix it
My 905 left hinge is broken too. Scanner lid/paper feed is now out of alignment and consistently jams paper being fed through it.
Oct 02, 2012 | Lexmark Platinum Pro905 multifunction...
Strut on Thule Atlantis 1600XT popped off. How do I re-attach it?
Put your carrier on a pair of saw horses and clamp down firmly then open the lid as it now stable and clamp your strut with a wide jaw wood clamp. Apply just enough pressut to start the ball into the socket and finish with your hands. Steve Parks
Jun 23, 2012 | Thule 686 Atlantis 1600 Cartop Carriers
Mu laptop hinges are broken. I wanted to know what problems this may cause? Sometimes when I tipe words, it doesn't work in the screen. This could be related with the broken hinges?
Laptop hinges are generally made of low-cost metal alloys, or "pot metal yeah this may cause problem you can fix your broken hinges easily by spending little time ." Pot metal is not particularly durable, and over the course of a laptop's life cycle, repeated opening and closing of the computer's lid can cause wear that prevents the lid from staying in an open position. Hinges can also wear to the point that they break at the point of attachment, either on the lid or the computer's body.
Hinges are usually attached to the computer's frame via machine screws. In order to get the most life out of your computer's hinges, it is not a bad idea to perform a yearly inspection. Remove the hinge covers and check that the machine screws that secure the hinges are tightened fully. If screws are missing, contact the computer's manufacturer to order replacement screws; hinges missing screws are subjected to additional stress and can wear out faster if steps are not taken to replace the screw.
Lubrication of the hinge is possible, but not recommended; if the wrong type of lubricant is used, it could damage the computer's case or seep into the electrical components and further damage the computer. Consult a professional technician if you feel that your hinges require lubrication.
o Hinges can also be damaged when the computer is picked up by its lid, dropped from various heights or opened beyond the angle at which it should stop. In these situations, damage to the hinges may be of secondary concern, as component damage and data loss might have occurred. Depending on the amount of damage and warranty status, the computer may require complete replacement.
Laptop hinges are not indestructible, but their coverings and trim may show wear long before the hinges are actually in any danger of failure. Most laptops on the market include plastic hinge covers. The hinge covers can develop stress fractures from repeated wear; most of the time, this is not indicative of a hinge problem.
Some laptop hinges are housed within the bezel or trim of the computer's monitor or body. This, too, is generally made of plastic, and might develop stress cracks after a few years of use. Hinge covers and bezels are usually modular, and replacements are generally easy to find at low to moderate costs.
Repair
o Hinge problems can be mitigated with adjustments to the hinge's tension or additional hardware installation by the user. Brackets can be installed on the outer case to allow for hinge-like performance, or the screen can be mounted in a fixed position. If the screen is left permanently open, care should be taken to prevent damage to the screen and to prevent dust accumulation in the keyboard.
The lid and screen assembly can also be replaced, if the correct parts can be found. Replacement of the lid and screen can be cost-prohibitive, with parts and labor sometimes exceeding the cost of the computer.
Sep 01, 2011 | Computers & Internet
The scanner lid won't close properly. I see the right back corner of the lid has popped out of it's socket. how can I fix this?
I have a Lexmark X6570 All In One Wi-Fi model. Just had the problem where I went to print and received an error message saying that the cover was open (when it wasn't). I noticed that the back right hand corner had slightly popped out of place for no apparent reason. Tried to pus it back into place with no luck.
Here's what happened and how to fix it:
There are two plastic hinges at the back of the 6500 series printers that allow the top cover to open for access to the ink cartridge carriage. The lower ends of the hinges are cylindrical shaped and each contains a very stiff steel spring inside. They are designed to prop the cover of the printer up and hold it open when opened. As the plastic material ages, it may weaken and the tension of the internal spring may break the round end of the hinge off. This causes the printer cover to not fully close (even though it may appear so). There is a switch in the main printer body that detects when the top cover it open (even partially), and the printer won't work in this condition.
To fix this, open the top cover and carefully disconnect the 3 wire harnesses and the ribbon cable that run from the top cover to the base of the printer. Then remove the 'paper jam' hatch cover from the back of the printer. There are two phillips screws on the back panel of the pinter (one is located behind the paper jam hatch cover). Remove these screws (they secure the plastic hinges in place). You should now be able to lift the complete top cover/ scanner table assembly off the rest of the printer. Look for a steel spring about 3 inches long...remove this along with the round base of the hinge which may have broken off and remained down inside the printer. Glue this piece back onto the end of the hinge, but leave the spring out. Now reassemble the printer in the reverse order of disassembly and you should be good to go. Note that the top cover or the printer will not stay propped open on it's own with the spring removed, but this is not really an issue.
I am not sure if new replacement hinges are readily available from Lexmark or other sources.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/john_472b46f833fc3109
Aug 26, 2011 | Lexmark X3470 All-In-One InkJet Printer
Paper gets jammed everytime it copies, it would not go through. There's no paper stuck either. Canon MF6530
I am assuming its jamming in the ADF when you are attempting to make a copy, if so open the top lid of the scanner and check both hinges and make sure they are not broken or cracked. The slightest crack in a hinge will offset the paper path and cause jams. If the hinges look good check for a clear plastic mylar strip under the lid, it will be on the left side. If that plastic strip is missing that will also cause jams.
Apr 11, 2011 | Canon imageCLASS MF6530 Monochrome Laser...
Washer wont drain or spin
assuming urs is a top load machine.....Top load washers are designed with an interlock switch that stops the machine if the lid is opened during a spin cycle. This switch is operated by a post mounted on the lid that goes into a hole in the rim of the machine and pushes down on the switch, or a bump on the side of the lid right by the hinge that presses against a switch when the lid is closed, or as on new whirlpool models, by the hinge itself inside the machine under the top panel.
Determine which type you have. If it is the type with a hole and post, get a screwdriver and stick it into the hole with the machine in the spin cycle and the knob pulled out. If the machine starts, then the post is missing or broken. I have seen people replace perfectly good washers for the sake of this $2.00 part.
if it doesnt work... please get back to us with the make and model number of ur unit...
regards iversh
Sep 21, 2009 | Whirlpool Washing Machines
Lid support broke
Not much info but if you mean the lid on your DS falls backward when opened then one of two things has happened either the small barrel lock in the hinge has broken, this is rare. Or you have broken the hinge allowing the barrel lock to rotate in the case.
The barrel is cheap and a very easy fix by opening the case removing the led lens holder then change the lock. If you have broken the hinge you will need to replace the case, tricky job requiring patience especially when transfering the top screen to the new case. Watch a few you tube instruction videos to get a better idea of whats involved.
Jun 10, 2009 | Nintendo DS Lite Console
The lid on my top loading admiral mega 22 plus washing machion is
These are plastic and will need to be replaced with new.
Once you have sourced new hinges then the machine top needs to be opened,
Electrically Isolate the machine, then at the joint between the machine front panel and top insert a flat blade 4" from each side to release the lid catches, tilt back the top to access the screws on the hinges and replace with new.
Mar 03, 2009 | Admiral AW22 Top Load Washer
Unable to close Lid
Sounds like the hing on back is broken. Look on the back of the cover, there will be 2 hinges holding the scanner on. Probably a piece of plactic broke and is hanging up one of the hinges.
Possibly a small spring.
Feb 28, 2008 | HP Photosmart 3310 Printer
HP Officejet 6700 Premium E-All-In-One Logo
182 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
