Question about Cuisinart EM-200 Espresso Machine
I need a replacement part for my Cuisinart EM-200 espresso machine. The plastic piece which connects the steamer wand to the machine is stripped. Where can I find this part?
I believe this part would be considered an internal part, and is a plastic piece which attaches the steamer wand to the interior of the machine.
ThaMp3Doctor
  • 8596 Answers
SOURCE: can't get milk to foam
Place 1/3 part distilled white vinegar and 2/3 part water into the water reservoir. Turn the machine on and wait for the heat light to go off. Once the heat light goes off, turn the steam vs. water knob to the water drop icon, and turn the main function knob to steam/water. Make sure to have your frothing cup underneath the steam element ready to catch the water. The vinegar/water solution should clear out the calcium that clogs the steam element. Also, remove the cover to the steam element and dip it in a bowl with vinegar for about 5 minutes, and use something like a pipe cleaner to clean out that cover. Then apply vinegar and hot water to a rag and clean the calcium off the shaft of the steam element. Once you are all finished with this, run plain water through the espresso maker on the steam/water setting to clear out the bitter vinegar residue. Now, try again to make espresso and froth it.
Since milk contains calcium, the steam element has to be decalcified more often than a regular coffee maker. The EM-100 is a beautiful machine, but it is definitely high-maintenance - you will probably spend more time cleaning it than making cappuccino, etc.
-Tha Mp3 Doctor (is also a huge Cuisinart fan)
Posted on Feb 26, 2009
  • 10 Answers
How long have you had the machine? Use a straight pin and poke the opening of the wand. It may be blocked. If the bottom of the wand can be removed, use some pliers, and CAREFULLY remove it, soak it in hot water. Rinse it thoroughly, and replace it back on the machine. If you cannot remove the wand, turn the machine upside down, and check the opening to the wand. It most likely is stopped up. Run vinegar and water through your machine once a week. Calcium build up does the same thing. Good luck! Happy Lattes!
Posted on Feb 05, 2009
ThaMp3Doctor
  • 8596 Answers
SOURCE: Cuisinart EM 200
I was about to abndon pods on this machine, and then I actually used the Pod filter basket - it worked like a charm. Decalcifying is not a bad idea.
Posted on Feb 15, 2009
janzep
SOURCE: manual instruction for em-100
http://www.cuisinart.com/share/pdf/manuals/em-100.pdf
Posted on Sep 11, 2009
  • 15 Answers
SOURCE: do you know where can i find the rubber gasket that goes around the brew head of my Cuisinart EM 100 espresso machine ?
It sounds to me that your group seal is bad. Since this machine is a 15-Bar unit, it puts out quite a bit of pressure causing water to leak out around the portafilter when making espresso if your seal is old or damaged. The pressure doesn't build up as much when you are running just water through the machine - hence the reason why the machine works ok without grounds. I sell a LOT of parts and accessories for various manufacturers of espresso machines. This particular seal is extremely difficult to locate fom Cuisinart, but is rather easy to replace. Through extensive testing, I have located a replacement gasket produced by another major manufacturer that fits the Cuisinart EM-100 & EM-200 machines perfectly. I sell them for $10.99 each (or two for $19.99) which includes shipping in the continental US and I accept Paypal. If you would like to contact me via email (cowboy_romeo@yahoo.com), I will be happy to help you out.
Posted on Oct 03, 2012
Cuisnart EM-200 will not stop flashing lights
Different lights have different meanings. However I would go with the water reservoir is empty or not in place properly. It's also possible that the machine is not reaching the proper temperature and that will also cause the light to flash. (Indicates that a repair is needed). (Page 6 in the manual.)
Sep 30, 2016 | Cuisinart EM-200 Programmable Espresso...
Espresso not hot enough
CoffeeGeek - Espresso: Espresso Machines, Need help with a ...
coffeegeek.com > Discussions > Espresso > Machines
Feb 1, 2010 - 10 posts - ‎4 authors Well, I'm throwing in the towel...or my Cuisinart EM-200 actually. ... coffee and it's not hot enough to even make me pull my finger out of my flat, ... Espresso Machines, Breville BES840XL Owner ...
Aug 20, 2013
Espresso Machines, Cuisinart EM-200 ...
Nov 14, 2011
More results from coffeegeek.com
Cuisinart EM-200 Espresso Machine Coffee not hot ... - Fixya
www.fixya.com > ... > EM > Cuisinart EM-200 Espresso Machine
Cuisinart EM-200 Espresso Machine, coffee not hot related issues. ... ...to "extra hot" If still not hot enough, try zapping your coffee for a few moments in the ...
Oct 29, 2015 | Cuisinart EM200 Stainless Steel Espresso...
My Cuisinart EM-100 Espresso Machine leaks water from the bottom.
Thanks Joe received ur gasket in mail installed it in 10 minutes and no more leak! The old was caked up above and below.
Dec 03, 2012 | Cuisinart EM-200 Espresso Machine
Water will not come through.
Is the water hot? If you have hot water then I would ckeck for a solnoid valve to see if it stop up.
Mar 13, 2009 | Cuisinart EM-200 Espresso Machine
Can't get milk to foam
Feb 05, 2009 | Cuisinart EM-200 Espresso Machine
Cuisinart EM-200 Espresso Machine Logo
87 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
