Can't change source on proscan tv
Cant switch source on tv seems to still be reading a cable box that is no longer attached
SOURCE: says no signal when switched to hdmi when there is one.
Have the same problem with a 532H - but here is what I did to resolve the issue:
1) Click your Menu button on the TV remote.
2) Go to Screen (click the right button)
3) Go to Main Picture Source (click the right button)
4) Select HDMI (click the Menu button when done)
Posted on Oct 13, 2008
  • 48 Answers
SOURCE: Stuck on a video mode
Some TV's disable inputs if there is no signal. I suggest confirming cables are connected properly, and accessing the system menu, and perform an autoscan for channels
Posted on Apr 27, 2009
roety
  • 585 Answers
SOURCE: Westinghouse TV no stereo
Hi my name is Roety,
I can help you with your issue ,
Why don't you simply run the cable box and DVD stereo outputs direct to the receiver. Thats what most people do. TVs do not passthrough stereo signal very well do to DHCP compliance requirements .
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
Posted on Nov 11, 2009
Testimonial: "A very good solution, right under my nose. Thanks!!!"
budmrtn
  • 11361 Answers
SOURCE: ordered proscan 32LB30QD from Costco. The coaxile
Costco has very good return policy within 180 days, I would try to get the exchange unit instead.
Posted on Jan 06, 2010
SOURCE: Toshiba 40RV525U goes into green screen mode when
Try updating the firmware to version 1.05 from this website http://support.toshiba.ca/support/ceg/downloads/all/view.asp?docid=D000020
Posted on Mar 26, 2010
Testimonial: "daubuchon..thanks for the info! That might have done the trick. The problem is much less prevalent now. Excellent!!"
I have a Proscan TV model PLED-26616a and I've connect a DVD on HDMI 2 input. When I select this from source panel, a panel of configuratioon appear and I don't see the DVD content
You may care to use another HDMI port to see if it works at all. Change the cords around. If you like using one HDMI source, get an HDMI Switch box from MonoJet.com.
For about 10 bucks, the switch box solves a lot of problems.
Feb 05, 2018 | Proscan Televison & Video
Proscan - model pldedv3292a - cannot get any channels
If you are on cable, make sure you didn't inadvertently switch off the cable box or switch the TV to HDMI if you are not set up fo it, or unset the chanel 3 setting on the TV so that the cable box can make the chanel selections....Check the owner's nanual, please!
Dec 26, 2012 | Proscan Televison & Video
What channel should the tv be on to be hooked up to Direct TV?
There is usually a switch on the device if it is connected through coax cable that changes it between 3 and 4 but if you are using AV cables or a HDMI cable you just need to change the source on your television.
Oct 24, 2011 | Proscan 26LB30QD 26 in. LCD HDTV
Proscan PS8682P dvd player. It has been over a
so you have two problems: how to connect to (ex: tv),so for this. the cable box has a scart port? if so use a scart/rca adapter available on the market, use on VCR out (Cable Box) and select IN the adapter to IN/OUT switch. and connect to dvd player. The other Scart Port labeled TV connect to TV set with a scart cable. Now u can see tv, and switch automatic to dvd if DVD is on.
The Bad Disc error is a Laser DVD lens defective, needs to be replaced, send to repair.
Dec 28, 2009 | Proscan PS8682P
New Proscan 40 goes to green screen when using HDMI cables
I have the same problem with a 40" Toshiba LCD, Component cables work fine with FIOS but not HMDI, goes in and out then blank. HDMI with DVD player works fine. Best buy reported this same problem from users with this toshiba lcd but no solution.
Dec 26, 2009 | Proscan PS50700 50" Rear Projection...
Why won't my tv pick up any cable channels?
If you have the cable box connected through the coax or RF connection on TV. (from the wall to the input of the cable box and output of the cable box to the in or RF in on the TV). Then in the menu on the TV you need to select the input source. It will say cable(CATV) or antenna. You should be set on cable.
Jul 18, 2009 | Proscan Televison & Video
Tv screen is white; sound is ok
Need more information about you problem. Does the white screen appear on all functions.Does any input signal like a dvd or vcr show picture. If so, then you have a problem with signal connection coming from the television signal source, like a cable or satellite box. You need to check the connecting cables to see if they are outputting signal. Try using different cables to connect the signal source to the television. If this does not work. Try hooking up the signal source to another television to make sure you are receiving signal from them.If all this seems to be working fine and you are sure that you are using the remote control inputs correctly, you may have a problem the video input signal board on the television. You can contact PROSCAN at this web address. www.oncorpus.com. Go to customer support and ask for their technical assistance with your problem. The telephone number for PROSCAN service is 1-888-977-6722. I hope this has been of help with your problem.
Apr 08, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
No Picture
check your connection between digital box and yout tv replace it and try again then check input to be plugged good i mean ferm connection
Do that if your digital box work on other tv
Dec 10, 2008 | Proscan PS56700 56" Rear Projection...
Have cable tv and wanting to tape a certain channel
I would suggest that you disconnect the VCR from any signal source. UNPLUG the VCR from the power source [a/c] for at least one hour, more if possible. Before you are ready to plug the machine into a/c attach an antenna to the antenna INPUT, the VCR output goes to input of tv. [ DON'T attach cable box, or any such machine to the input of VCR.] Plug vcr into outlet and turn ON. Place TV-VCR switch on TV. [no remote control??] Change the channel MANUALLY, one channel at a time. If you see tv stations as you change the channel [KEEP changing until you have reached the " end of the line " of broadcast channels.] then you are good.Connecting the vcr to a cable box[ANY KIND!] you can only RECORD through the vcr what you watch on cable.
Dec 09, 2008 | Sanyo VWM-900 VHS VCR
No channels
are you plugging it into the actuall cable or is it an arial socket if it is the cable you need a cable box as you change the channels on this if it is the arial then it should have a self scan mode in the setup you wont get cable channels without a cable box because they opperate at different frequency and the newer tellt are made not to pick up these frequency so you have to purchase the cable box this should be plugged into your telly via a scart lead then you change the channels on the cable box the only channel maybe it is different as i live in the uk sorry i couldnt bbe any more help
Oct 31, 2007 | Proscan PS32600 32" TV
Televison & Video Logo
11 people viewed this question
Top Televison & Video Experts
