Question about Timex 1440 Prizefighter 53032 Sports Wristwatch
Setting a timex wr50m watch
How t set digital date and time
How to set a Timex 1440 ports watch WR50M
Buttons are numbered as followed:
Start/Stop is button 1
Lap/Rst is button 2
Indiglo is button 3
Mode is button 4
a) Press 4 to select "TIME" mode
b) Press 2 and hold for 2 sec to select "SET" mode, second digits blink.
c) Press 1 to reset digits to 00.
d) Press 4. Minute digits blink
e) Press 1 to set minutes.
f) Press 4. Hour digits blink.
g) Press 1 to set hours.
h) Follow same patter to set day of month, month, etc...
i) Press 2 at any time to retain set values and exit procedureSource(s):Timex instruction manual
Oct 08, 2012 | Timex 1440 Digital Sports Watch - Green
Set time on wr50m watch
Hi capttimpcb,
To set the digital time and date on your Timex, please follow the steps below.
1. Press and hold the "Set" button for 2 seconds. The "Set" button is on the lower right side.
2. Press the "Date Advance" button on the upper right side. This will reset the seconds.
3. Press the "Change Mode" button on the lower left to set the hour. The hour will flash. Press the "Date Advance" button until the correct hour is displayed.
4. Press the "Change Mode" button again to set the correct 10s unit (first digit 1 or 0) for the minutes. Press the "Date Advance" button until the correct first digit of the minutes is displayed. Repeat this step to set the second digit of the minutes.
5. Repeat Steps 1 through 4 of this section to set the year, month, date and day and whether to use 12- or 24-hour time for your watch.
6. When finished, press the "Set" button (on the lower right) to return to the current time view and lock in your settings.
Hope it helps.
Thank you for using FixYa.
Dec 01, 2010 | Timex 1440 Nylon watch
I have a timex wr50m. How do I set the time zone?
Hi johnmonks,
Please follow the instructions below.
Hope it helps.
Nov 16, 2010 | Timex 1440 Nylon watch
I have a Timex WR50M HOW DO I SET THE DATE . The date is auto.
mcdevito75 here, If your Timex is digital (has buttons) press the MODE button once, see the screen flashing, then press set as you set each function press MODE to move to the next function, when done press MODE again for steady screen. If your Timex has a stem (winder) slip your fingernail just under the stem and lift it to it"s first notch or position, this will allow you to change the date without haveing to turn the hands so many times.
Jun 22, 2010 | Watches
How do i set the time on the timex wr50m?
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all TIMEX watch manuals.Rate me, please.
Mar 28, 2010 | Timex Watches
I would need to set the time on my timex WR50M watch and I have missed place my instruction sheet. I would need th instructions Thank You
Hi fuscoromeo,
Timex Digital Watch
Hope it helps.
Nov 02, 2009 | Timex 1440 Nylon watch
Can't change time
Try to pull the roll handle up a little until it clicks, then, usually anti ~ clockwise will set time only, clock ~ wise will set date. This should solve 'em. :)
May 05, 2009 | Timex 27191 Wristwatch
I need set up instructions for a wr50m 1440 sports watch
Visit www.timex.com/ - 12k - Cached - Similar pages
Choose: SPORTS, then SPORTS1440 and download manual.
Dec 20, 2008 | Timex 1440 Nylon watch
Timex 1440 Prizefighter 53032 Sports Wristwatch Logo
Top Timex Watches Experts
Ross Keen
freddyfox
Jerry Greenberg
Jerry Greenberg
Are you a Timex Watch Expert? Answer questions, earn points and help others
