Question about Lexmark Office Equipment & Supplies
Lamp warning We have a X463 copier with the message "Lamp Warning" on the screen. Copies look fine, as do prints.
techman
  • 3130 Answers
SOURCE: Lamp Light Red - No Screen Image
It could be the a problem with the lamp ballist circuit, or just a bad lamp socket, or simply a bad lamp. The only way to tell is to call out a servicer as that would be alot less expensive then to get a new lamp and then that not be the problem. These problems can be a little hair pulling at times, thats why i have no hair left!! LOL Good Luck
Posted on Mar 21, 2007
  • 2072 Answers
SOURCE: Copystar 1635 copier/printer set up problem
What the problem sounds like is that the machine and print driver are set to diifferent paper types.
One says plain paper and the other bond paper.
Or something like that, the machine says bond and the printer plain paper.
Chech the size setting and paper orinentation.
Most of the time the paper type is wrong. Also check paper color etc etc. Something between the machine and driver is mismtached.
Posted on Feb 12, 2008
Slinteriors
  • 8617 Answers
SOURCE: Lamp Hour Meter
This proceedure should work for your model to reset the lamp meter.
Lamp Time Reset Procedure:
Be sure to reset the Lamp time to "0" after replacing the new
Lamp.
1. Plug in the AC Cord, and turn on the power by pressing the
POWER button.
2. Press and hold the VOLUME DOWN button on the unit and
the SPLIT key on the remote together for over 5 seconds
in power on condition.
When the reset is finished, the display will indicate that the lamp hrs have been reset to 0 and the LAMP LED goes out.
Posted on Apr 01, 2008
SOURCE: My Sagem DLP HTD 501,
Ok...this is only a theory. Did u replace bulb..or lamp unit?
To cut along story short the tv has a timing device in it set to about 8000 hours. When u look at a picture (google) of the new replacement lamp unit, there is an additional circuit board on the housing, this aligns to two tiny contacts inside the tv. (you can see it when u look inside the socket. its green and about 10mm by 20mm and labeled lamp saftey). this circuit board (on the lamp unit) is absent on the one that comes with a new htd501. I believe the replacement lamp housings circuit board is a 500Ma fuse, which momentarily sends a current to reset the timing device then immediately blows, leaving your timing device reset to 0hrs.
As i say this is only theory based on reading other materials online, however my friend has this problem and i am waiting for him to give me the go-ahead and try it.
What I will do is make a plasic board with bean tin contacts aligned to the contacts inside the tv, and solder a fuse housing to the home made contacts and use a 500ma fuse. this should reset the timer!!
I cannot guarantee or even recomend this unless u r sure and confident about making the above gadget. however i will return to this page and tell u if i was successful in a week or two.
Posted on Jul 07, 2008
SOURCE: replace lamp warning light goes on after raplacing it with the new lamp
I had the same problem. There is an internal reset button just above the lamp that needs to be reset. You have to take the cover off, which would void your warrantee, but it's quite easy. My lamp only had 660 hrs, and I bought a new one too. So now I have an extra. My guess is that my filter was getting clogged causing an overheating situation and tripping this reset button which I'm guessing is a heat sensor.
Posted on Aug 26, 2008
7 dings and a beep when starting 2000 ford explorer? what does that mean
NOTE: The generic electronic module/central timer module (GEM/CTM) is connected to the ISO link and is diagnosed through the data link connector (DLC) with a scan tool.
There are five warning chimes and lamps the GEM/CTM controls: headlamps operating without the ignition on (chime only), door ajar (chime and lamp), key-in-ignition (chime only), driver seat belt warning (chime and lamp), and message center.
Audible Warnings Warning Condition Lamp Duration Audible Duration Audible Output Safety Belt 60 Seconds 6 Seconds Chime, 60/Min. 740 Hz Key In Ignition - Continuous Chime, 120/Min. 740 Hz Headlamps On - Continuous Chime, 240/Min. 740 Hz Door Ajar Continuous 1 Second Single Tone, 1000 Hz Message Center (Tone Request) - 1 Second Single Tone, 1000 Hz
When the is turned to RUN or START from OFF or ACC, the chime will sound for six seconds or until the safety belt is buckled.
The will turn on for 60 seconds or until the driver safety belt is fastened. Both the chime and the lamp turn on at the same time.
If the safety belt is buckled before the ignition switch is turned to RUN or START, from OFF or ACC, neither the chime nor lamp will be activated.
Anytime the is changed to RUN from START while the safety belt warning indicator is activated, the safety belt warning indicator will remain activated until either the timing sequence has been executed or the safety belt is buckled.
When at least one door is ajar and the key is in the RUN position, the door ajar cluster lamp is activated and remains on until all doors are closed. A warning tone will sound once any time the key is in the ignition switch and any door is open.
The key-in-ignition warning will sound when the driver side is opened with the key in the and the in OFF or ACC. It will continue to sound until the key is removed, the is closed, or the is in RUN or START.
The headlamp-on reminder chime will be activated if the headlamps or parking lamps are on, the key is not in the ignition switch, and the driver door is opened.
A single tone will be provided each time a ground signal is received from the message center. A one-second tone will sound for warning indications from the message center. A 100 milli-second tone will sound for each message center button depressed.
Feb 12, 2015 | 2000 Ford Explorer Eddie Bauer
Warning message for lamp replacement appears at each power up!
After replacing the lamp, make sure the lamp cover is securely closed. Select the Lamp Replacement option in the menu, (MENU > Settings > Setup menu) and follow the on-screen procedure.
Apr 20, 2017 | Sony LMP-H130 Projector Lamp Projector...
A "final warning to replace
Did you reset timer after replacing lamp?
Aug 23, 2011 | Vivitek Replacement Lamp
How long do I have after the lamp replacement warning comes up before I have to replace the lamp?
You can use the Lamp even if the TV displays the message to replace the lamp. However, the performance of the TV, i.e the picture may become dark, entire screen may display in black after some time. If you can view the videos normally even after displaying the message, you may continue using it.
Thanks for understanding.
Feb 02, 2011 | Sony KDF-50E2000 50" HDTV
Minolta CSPro copier is not printing
Change the transfer/separator corona holders,corona wires and clean the optics(mirrors,lens exposure lamp),and make a copies.
May 24, 2010 | Minolta EP4000/5000 CS/PRO Copier
The person I purchased this t.v from is saying the lamp was just replaced, but the FINAL WARNING REPLACE BULB AND RESET TIMER message pops up every time I power the tv on. She said she forgot to reset the...
If the timer has not been reset telling the unit it has a new lamp you will get that message. Call a servicer to find out how to reset the timer if you don't have the owners manual. If the message continues after that you will need to purchace a new lamp. There are problems that accur with some aftermarket lamps.
Sep 21, 2009 | Televison & Video
Working but lamp warning on screen,lamp led flashing
Press < and > and Power buttons at the
same time on the projector to reset the
lamp hours counter
May 12, 2009 | Mitsubishi SL1U Multimedia Projector
Mitsubishi HC900 Projector shuts down after 5 minutes.
You have 1 of 2 possible problems.
(1) You need a new lamp.
(2) You have an overheating problem.
Just a quick couple of notes about your projector. It is a DLP projector (not LCD) and as such the machine as no air filters to clean. It does have air intake and air exhaust grilles, but no air filters to clean. This next part comes directly from the owner' manual for your projector:
When the lamp operation time exceeds 2000 hours*1 *2, the projector automatically shuts off and can’t be used until the lamp is replaced and the lamp operation time is reset.
Your machine is designed to give visual warning messages at 1500 hours used, and 1900 hours used. Did you see any visual warning about lamp life over the past few months?
If you were experiencing an overheating problem, a "TEMPERATURE!!" message would flash up on the screen just before the unit shuts down. If there is no warning, you don't have a heat problem.
If you have a replacement lamp available, install it and reset the lmap hours according to your user manual. If you don't have the manual, google it on the web (it available).
Apr 01, 2009 | Mitsubishi HC900 Multimedia Projector
Lamp Hour Meter
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Lamp hour reset to many popular projection TVs are given.
Mar 03, 2017 | Televison & Video
Removing the "lamp needs replacing" warning message
Hi guys
Firstly you need the remote to reset the lamp timer.
Hold down the left and right scroll buttons on the remote and press menu. That will reset your lamp timer.
Jul 31, 2007 | Sony VPL-EX1 Multimedia Projector
190 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
