Question about Bosch KGU32124 Bottom Freezer Refrigerator
Bosch KGU32160 fridge freezer
Unit maintains correct temp in both compartments but makes a loud noise when running (like a small motor bike running in the kitchen). Also it doesn't seem to cut out when correct temperatures are reached. Help.
  • yianniskak Nov 06, 2008
    Mine makes a lot of noise too. I found out where it comes from. It comes from the fan inside the fridge which is mounted on only two screws. Could they not afford another screw for heavens sake? I am not buying an expensive fridge again. Not worth it
    Scholar:
  • 146 Answers
The compressor behind the fridge should cycle on and off as the machine maintains temperature, but the evaporator fan inside the freezer will keep running, except when the fridge goes into defrost. If the noise is coming from the fan inside the freezer, there could be some ice on the frame of the fan and the blades are touching the ice. If the noise is coming from behind the fridge it could be the condensor fan motor. This fan is situated behind the fridge in front of or next to the compressor. It keeps the condensor cool by blowing air onto it. Check this fan. The blades could be touching the pipework or something.
Posted on Nov 03, 2007
How to set temperature settings for bosch fridge freezer
Set control for temp that you wish to maintain in freezer compartment by using a digital thermometer and allowing changes to stabilize.
Aug 25, 2017 | Bosch Refrigerators
My Bosch Fridge makes a loud gurgling sound every twenty five minutes even after freezer fan &emotion were replaced.
It's a normal noise! When the liquid refrigerant becomes less pressurised, usually when the thermostat clicks off,, it still bubbles through the system until the pressure equalises.
Dec 17, 2014 | Bosch B22CS50SNS Side by Side Refrigerator
Frig is making loud noise when it turns back on to cool.
proberly ice build up around the fan motor.You may have a defrost problem.
Oct 16, 2014 | KitchenAid Whirlpool Kitchen Aid...
Kenmore bottom freezer fridge making loud noise not cooling
What is the complete model number of your unit?
Where is the sound coming from?
Dec 04, 2012 | Kenmore 73502 / 73504 / 73509 Bottom...
There is a loud noise while going through final stages of wash. Sounds like pump motor whineing.
Hello
When an appliance such as a dishwasher starts making a new noise, you need to isolate the cause of the noise so that you know whether or not it is damaging the machine. Several things can cause a noisy dishwasher.
Motor
Dishwashers are driven by an internal motor that gets quite noisy when defective. The problem occurs when a seal breaks down and allows water to access the bearings in the motor, removing the grease needed for proper lubrication and creating a loud motor noise when the dishwasher runs. The seal or bearings need to be replaced in this situation quickly or more extensive damage to the motor may occur.
Inlet Valve
If the inlet valve on your dishwasher is broken or breaking, you will hear a distinctive thumping or clattering noise whenever a load is run. A thumping noise doesn't always indicate this problem, however, depending on when you hear it. If you hear a noise like this when the water is filling up the dishwasher at the start of the cycle, the noise likely points to an inlet valve problem.
Squealing
A high-pitched squealing noise is an indication that something is wrong with the fan. Fan bearings that are worn out indicate that the fan apparatus needs to be replaced. If the noise you're hearing is in fact coming from the fan, it will only occur when the dishwasher is drying the dishes. Dishwashers use a fan to generate and distribute heat to dry the dishes quickly.
Minor Concerns
Sometimes even a minor concern can cause a great deal of noise. The thing to watch for is whether or not the noise repeats itself on multiple loads. A loud noise on a single load that doesn't repeat could be caused by things like a loose utensil or small implement rattling around loose in the dishwasher. Also inspect the bottom of your dishwasher. Hardened bits of old food can become rock hard under the heat in the dishwasher and cause noise when the unit runs.
Sep 11, 2011 | Fisher and Paykel 23 in. DD603H SS...
My 10yr old model#690 freezer is having trouble maintaining temp and when the compressor shuts off it makes a loud clunk noise. I have check to see that fan is running and have turned unit off for about...
The noise that you are hearing is in the compressor. The motor has rubber mounts that hold the motor inside the compressor. One of these mounts are broke and what you are hearing is the motor hitting against the inside of the compressor. Have you tried cleaning the coils? let me know.
Mar 06, 2011 | Sub-Zero 690 Side by Side Refrigerator
Fuel pump noise 2005 Buell xb9sx
That is the fuel pump doing its job of pumping. If it stops making noise, it stopped pumping, and no gas is getting into your motor. Your bike will not run without a running fuel pump. :)
Apr 14, 2010 | 2005 Buell Lightning CityX XB9SX
MY HOTPOINT FFA52 FRIDGE FREEZER HAS MADE A LOUD BUZZING NOISE A COUPLE OF TIMES BUT IT APPEARS TO BE WORKING OK. AT FIRST I THOUGHT THE BUZZING WAS COMING FROM THE TOP NEAR THE THERMOSTAT UNIT BUT I,M NOT...
If you can pull the unit out from the wall, find the motor compartment. There, you'll find a black can with the motor and compressor inside it. This usually creates vibration when running. Check the compressor's mounts, to see if they need tightening or have rubber grommets that have rotted away. The sound could also be coming from a fan somewhere in the machine. There might be a fan in the motor compartment. Find the vents inside the unit that blow cold air. Check the guards to see if a foreign object could have made its way into the vents and jammed a fan. Make sure you unplug the fridge before you stick any hands or tools someplace they wouldn't normally go. You may want to let the unit run while peeking in with a flashlight to locate the source of the vibration, but beware of moving parts and a shock hazard.
Apr 03, 2010 | Freezers
Freezer in the gararge redfrigerator quits working when outside temps get real cold
hello. this is a common problem. The thermostat for a refrigerator/freezer is in the refrigerator part. Normally the refrigerator is kept at around 40 degrees. The compressor turns on as required to maintain this tempearture. The evaporator coils are concentrated in the freezer side, so that the freezer stays at around 0 degrees while the fridge side is held at 40.
If the ambient temp is around 25 degrees, the refrigerator compartment will get below the setpoint of 40 degrees, and gradually continue down towards 25 degrees. The compressor will not have to run at all to maintain this. In fact, the compressor is designed not to run, once the refrigerator compartment gets below the setpoint, for fear of freezing the contents of the fridge.
The lack of circulating refrigerant due to the non-running compressor means that the freezer compartment will gradually warm up to 25 degrees.
If the unit were just a freezer, it would work fine in the unheated garage. If it were just a refrigerator, it would not run in these conditions, and the contents would eventually freeze, but it is otherwise OK.
Regards, Joe PS kindly rate my answer. Thank you.
Jan 19, 2010 | Refrigerators
Bosch KGU32124 Bottom Freezer Refrigerator Logo
1,106 people viewed this question
Top Bosch Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Bosch Refrigerator Expert? Answer questions, earn points and help others
