Question about Dishwashers
Zanussi ls6ea error code c8
3 Suggested Answers
  • 7 Answers
SOURCE: Zanussi LS 14
for remove C8 error on zanussi LS14 you must press on/off and press cycle2 key and you get FAC press cycle2 key again 8 times and you get CFG enter on family of this paremeter pressing ifinity key go to parameter ALR and you get ALR= 1 change to ALR=0 AND FIX THE PROBLEM.
Posted on Jan 28, 2011
  • 246 Answers
SOURCE: DISHWASHWER WT 65 EIM:ERROR CODE C8.WHAT DOES IT MEAN?
according to the manual...error code 8 indicates a problem with the control panel. here is the link to this manual...page 21 of the pdf http://manuals.electroluxusa.com/prodinfo_pdf/Kinston/154671101en.pdf
Hope this helps you! PS, this model number in the link may or not be similar to yours I had a problem locating your exact machine..so let me know if it isn't the right one and I'll go look some more. meantime...is there another model number on the inside side of the washer door?
Posted on Jun 21, 2012
C8 SHOWING AND NOT WORKING.I have reconnected the burnt connection on main heating element. Unable to re-set.
C8 - During rinse phase boiler doesn't empty:
  • Rinse pump not efficient.
  • Rinse arms obstructed.
  • Boiler level sensor out of order.
Dado
Feb 03, 2016 | Zanussi Dishwashers
Dishwasher electrolux wt30 error code c8
Hello Said Raji - Are you certain the error code is C8? Could it possibly be CE? If so, it typically indicates that the dishwasher has detected a configuration error. A professional will need to check the wiring connections between keypad and main control board.
Jan 16, 2013 | Electrolux WT30H240DU Dishwasher
Zanussi dishwasher LS9 AD/G1 reading code C8 and not working
Dado
Jun 25, 2012 | Zanussi 29 in. LS14 Free-standing...
Warning C 08 how to reset?
Hold down on/off and prog 2 for 5 sec.
display ``fac``
Press prog 2 until display ``ron``
Press prog 3 until ``c8 / 1 or c8/3.``
Press prog 1 until ``c8/0``
Press prog 3 until ``ron ``
switch off -switch on and o.k.
General
C8 caused from glogged jets or rinse pump problem or bad luck.
If there is a problem at the dishwasher then c8 will appear again
Hope I helped you
kostas
Jan 26, 2011 | Zanussi 24 in. LS6E Free-standing...
PALOMA PTG-74PVN-1 Code C8 12 my water heater
C8 is the last stop in the point of burner ignition and a total of eight error codes. Error code 12 is a supplemental code that means your LP gas supply is too low...have your LP tank service and try again.
HTH,
Mike...
Dec 06, 2009 | Rheem Paloma Tankless Water Heaters...
New Richmond tankless water heater C8 error
I think error code C8 is #13
It has to do with air quality, lack of sufficient air, or lack of venting or dirty air filter.
Check following links to see if they have information:
Check following link for recall list:
http://www.tankless-recall.com/tanklessSearch.aspx
Manual shows error 05 or 13:
http://waterheatertimer.org/pdf/Rheem-RTG74IndoorOutdoor_owners.pdf
Sep 01, 2009 | Rheem Tankless Hot Water Heater...
Zanussi LS 14
Feb 28, 2009 | Zanussi 29 in. LS14 Free-standing...
Zanussi LS9 Dishwash error message
c3 means that the temperature of the water inside the tank is higher than 60 degrees celcious.may be you have already connect the dishwasher with to much hot water or the rele inside the pcb is stuck.
waiting for answer
Nov 16, 2007 | Zanussi 29 in. LS14 Free-standing...
Dishwashers Logo
147 people viewed this question
Top Dishwashers Experts
