Question about Electrolux Ovens
Thermostat broken top oven thermostat broken
  • Official Brand Answer
  • 2,267 Answers
Good Morning a_t_pearson, this is Z. Thank you for your post! I understand that the thermostat is broken on your top Frigidaire oven; therefore I'm assuming that you have a double-wall oven. If so, please help me understand what you are referring to by thermostat? Is your oven not preheating or reaching desire temperature? Are you speaking about the bake and/or broil elements not heating? May I please have your model number? The serial tag, which lists your model number, is typically located on the front of the oven, on the left side, as you open the door. With this information I can better address the issue at hand. Thank you!
Posted on Apr 03, 2014
Thermostat broken?
If your oven has a dial that is used to set the temperature instead of a digital control then yes, the thermostat has gone bad and is not shutting the heat off at the appropriate time.
May 17, 2012 | Smeg S20XMF.1 Stainless Steel Electric...
Hi Top oven only gets warm no matter where you set
I have a 720ef and the top oven is not that good. The wattage rating is low, from memory about 750 watts and it takes a month of Sundays to warm up. I bought an oven thermometer from Lakeland a little while ago and when the top oven is turned on the Lakeland thermometer is showing that the oven thermomostat is running the oven at 20 degrees below what it is set to. If the thermostat neon is clicking off and on, then the thermostat/oven is working, albeit not as we expect.
Oct 30, 2010 | Stoves Premier 720EMa Electric Double Oven
The main oven, fan assisted, blew the fan element. I replaced the element but the oven will not heat up. I have replaced the timer assy. & the thermostat assy. but it still will not heat up. When the...
You to check the element with a meter to ensure if you are getting a sapply to it, if you are, then the new element is faulty, if no supply, then probably ythe thermostat is faulty, also check for broken or bad conn ections.
Aug 14, 2010 | Hotpoint Ovens
Oven keeps switching off
Hello
First double-check the gas supply. Look over the gas valves on the back of the oven to make sure gas is able to flow into the oven. If those look OK, call the gas company to see if there has been an interruption in service to the area or to the house.
If the oven grows too warm, the thermostat might malfunction and the thermostat is probably to blame for what you are experiencing.
The thermostat is the part of the oven that tells it when it has reached the desired temperature, shutting off the heating process. If one of the thermostat's components is broken or dirty, this can render the thermostat useless.
Cleaning and replacing the thermostat components is a process best left to professionals because untrained hands can easily break a thermostat that simply needed cleaning. If you suspect this is the issue, contact your local gas company. Sometimes, gas companies offer oven thermostat repair services.
Apr 16, 2010 | Thermador SC302T Electric Double Oven
My Delonghi DE60PYROS needs a new thermostat, are
Ok get a Service Manual, and the Sensor, and it is not too hard.
Mar 29, 2010 | DeLonghi AS1070 Electric Single Oven
Friidaire model fef367cata electric oven. Both the broil and bake heat up at the same time and are overheating. thermostat is good, don't see any burnt or broken wires. Any help? Boards?
The thermostat's job is to open the circuit when the temperature of the oven has reached a specified point. If the thermostat is working properly, what is the problem?
Mar 14, 2010 | Frigidaire FEB27S7FC Electric Oven
Zanussi electric double oven. Top oven not working.
It sounds like a faulty thermostat, because when you turn the thermostat on it should supply the oven element and the neon light, so even if the element is faulty, the neon light should still come on regardless of the element working or not.
Hope this helps.
Feb 10, 2010 | Ovens
The bottom heating element won't heat up
If the new element is good then the next thing to check is the selector knob (COOK/BROIL) and the thermostat for the oven.
To check the thermostat, turn the selector to BROIL and turn the thermostat up until the top element begins to heat. Let it heat up a little then turn the thermostat down until it clicks off. If this works then your thermostat is working.
The problem then must be your selector control. Remove and replace (turn power off at circuit breaker box first!).
Of course, if the thermostat won't turn on the upper element either then it must be the thermostat.
There is a possibility also that a loose/broken/burned wire is causing the problem. You should check for this when you open up the control panel (after turning off the circuit breaker!).
Oct 28, 2009 | Ovens
Grill faulty on my double oven
Creda reflection double oven had the same issue, both ovens work but the grill was either hot or cold, no temp control. I changed the thermostat first, due to being a novice and not fully understanding how things worked. it didn't help so I have changed the grill regulator,( bit that the knob fits onto) and it has solved the issue. I expect this to be the same with most top oven and grill combinations with the oven working but the grill only being hot or off.
Apr 07, 2008 | Ovens
Ovens Logo
102 people viewed this question
Top Electrolux Ovens Experts
ashburton
Mack Baxter
Are you an Electrolux Oven Expert? Answer questions, earn points and help others
