Lake norman n.c. being drained
Draining lake norman
  • 3,320 Answers
Spam
Posted on Apr 01, 2014
I have a top freezer Hotpoint refrigerator at a lake home. It's about 6 years old. I've been getting water in the refrigerator compartment. I've tried to clear the hose on the back by...
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Sep 03, 2011 | Hotpoint Refrigerators
Need to know if my refigerator maytag mtf2193ar has any kind of system to drain defrost water because all that water is just acumulating at the bottom of the fridge and is just leaking out tru the door...
Yes the auto defrost drain water should run into a drain tube and out into a pan under the refrig where it just evaporates. You have a clogged drain and will need to look for it. Move your refrig out from the wall and you should be able to see the drain hose and get it cleaned out.Hope you find this helpful.
Jun 15, 2011 | Maytag Top Mount Refrigerator w/Cool Flow...
I have a G E Model #PDE18LBPBLBS that freezes in the drain and stops the fan from working so the fridge stops also.
If you pull the evaporator coil cover off and see that there is a lake of ice blocking your fan from turning, it's probably just a clogged drain line. Let it melt, then access the drain tube from the back and clean it out with a piece of mechanics wire. you can pull the tube apart just above where it bends. Be ready with a small container to catch all the water.
Dec 11, 2010 | GE Refrigerators
HAVE A MASSIVE WATER LEAK IN MY 1989 FORD PROBE! WHEN IT RAINS MY PASSENGER SID OF THE CAR IS A LAKE! PLEASE HELP!
look under the bonnet and where the wiper motor is their is a drain pipe either side of the car ,poke them out to clean them out their blocked and the rain cannot drain away
Nov 10, 2010 | 1989 Ford Probe
2005 Toyota Camry with moonroof...drains keep clogging up and end up with ''lake'' on passanger floorboard. sick of this ! Please send help !
You need to clean the channel drains, best way is with a long piece of semirigid wire that must have a blunt end so you can work it into the forward section on the drain and unblock the channel which runs inside the front pillar between the windscreen and front door.
Be very gentle as the channels here are rubber tubes and you do not want to rip them.
Dec 19, 2009 | 1997 Honda CB 750 Nighthawk
Ac draining back into passenger side of car
plugged drain tube on fire wall needs unplugged
Oct 14, 2009 | 1998 Jeep Cherokee Grand 2WD
Clean LED constantly flashes,only function is drain
If it's a Whirlpool, and flashes seven times, then you have a heater circuit problem. You would need to diagnose which component is at fault
Affordable Appliance Reapir
Lake Forest, CA. 92630
Aug 23, 2009 | Dishwashers
Nor-Lake walk-in cooler water leak
The evaporator drains into pan with a coil from the discharge line. The design is intented to sub-cool the liquid refrigertant as well as evaporate the condensation from the coil. Unfortunately the engineer started as career a shipping clerk and never received any further training.  There isn't enough heat or running time to evaporate the condensation from the coil.
The solution is fairly simple
A plastic tube  drains water out of the evaporator in the pan. You can extend the tube and add a defrost pan handled by your refrigeration wholesaler. Wire it so it is on whenever there is power to the unit.  This should get rid of the excess water. These pans are also used on some self contained coolers and freezers. They come in either 120 volts or 220 volts. kasgirls@tds.net
Jul 12, 2009 | Nor-Lake Norlake Refrigeration 4' x 6'...
Water leaking into fridge
Open the back of the unit. There you will see a drain line. Use something to blow through it and clear blockage. If the drain is clear the drain pan may be rusted through. :)
Jun 05, 2009 | True TSSU-27-12M Refrigerator Commercial
Computers & Internet Logo
79 people viewed this question
David Payne
David Payne
