I have the safe boot on and cant get back into misconfig.to undo it. so when it restarts its always in safe mode how do i get back to reg. view?
Please help
  • 3,320 Answers
Press F8
Posted on Apr 02, 2014
Stuck in safe mode on my old gateway
Everything is messed up Trying to correct will only drive you insane
Do a clean install
Apr 01, 2014 | Computers & Internet
I have my laptop stuck in safe mode. i checked safe boot by mistake, now why cant i get back to undo it?
Hi Steven-
Laptops should return to normal mode upon subsequent start-up. If it does not, when you (re)start your computer, begin tapping the F8 key repeatedly (like a woodpecker). After a few moments, this will bring up a manual start screen (white letters on a black background)-you will see an option to Start Using Windows Normally down toward the bottom of the screen. Using your arrow keys, scroll down to that choice and hit ENTER. Your PC will then boot up in regular mode.
Apr 01, 2014 | Gateway Computers & Internet
Disable safe mode
Which operating system and do you have Norton antivirus ???
Turn Off Safe Mode
You rebooted your PC at least 10 times now, and still it refuses to start in anything other than Safe Mode.
Your many attempts to perform a system restore have yet to be victorious. It just will not boot up normally.
According to Microsoft, if you have Norton Antivirus 2001 installed on your computer, it is the root of the problem. Microsoft suggests you disable it.
Restart your computer. Let it load completely in Safe Mode.
Press "Run" on your Start menu.
Once you see the Open box, enter into the provided text box: misconfig.
Then press "Enter" or Select "OK."
Select on the new dialog box that has appeared "Selective Startup."
Select "NAVAP.VxD" on the Static VxD tab.
Remove the check in the check box you now see.
Select "OK."
Remove the check in the check box next to Norton Auto Protect.
Select "OK."
Reboot your system and it will be in Normal Mode.
Turn Off Safe Mode in Windows XP
The purpose of booting your computer in safe mode is to resolve issues.
Only your basic, most dire drivers and programs will run to block viruses and surreptitious software from executing on your system.
But once the issue is resolved, you need to get back to the standard Windows mode. In order to turn off safe mode in Windows XP, you must go through the same steps that you took to turn it on.
Reboot your Windows system.
Press the "F8" key several times as soon as you see the first Windows XP logo appear on your screen as the computer is booting.
This will bring up a black screen that displays the "Windows Advanced Options Menu."
Press the down arrow button on your keyboard to scroll down the list.
Select "Start Windows Normally" and then hit "Enter."
Allow the system to boot.
Enter your Windows XP user password (if you set one) and log in as usual.
Nov 14, 2013 | Computers & Internet
NEED,HELP,TOTURN,OFFSAFEMODE
Select "OK."
Select "OK."
http://support.microsoft.com/kb/305671
Aug 24, 2013 | Computers & Internet
My acer travelmate 2420 is not booting. i just loaded pics from camera to print, it hang and now everytime i boot windows just keeps restarting over and over. what do i do?
Press F8 during boot this will take you to boot options select "Last Known Good Configuration" or select Safe Mode to perform a system repair.
To repair your system follow the steps below
1. Click Start and open Run on the Start menu.
2. Type (or copy and paste) C:\WINDOWS\system32\restore\rstrui.exe in the Run box.
3. This will open System Restore now select the first option (restore my computer to an earlier time) and click next.
4. Select a date when your network last worked and complete restoration.
Do not worry about selecting the wrong date you can always undo any restore within system restore you will select undo last restore.
Jan 30, 2010 | Acer TravelMate 270XV Notebook
Went to misconfig to select safe mode boot safe mode starts but window comes up stating no safe mode and is rebooting and it just does this over and over and i cannot get back to sselect misconfig to...
Hello
Thank you for using
FixYa for your problem
The reason you cant get past the restart is because by selecting safeboot on the boot.ini tab, you have now set your computer to boot straight into safe mode (even though you knew your computer couldnt boot to safe mode) :)
Were you having trouble before? Why were you trying to get into safe mode in the first place? it may help with the solution. Were you getting shutdowns or blue screens? Ram problems can cause all sorts of issues.
Do you have your windows cd? If you do then follow the instructions on the link below to replace your boot.ini. file
http://pcsupport.about.com/od/fixtheprob…
Let me know how you get on with that and we will go from there :) (just edit your original post with added detail)
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Nov 22, 2009 | Microsoft Windows XP Home Edition
Cant acess safe mode in windows xp, just cycles startup screens
Here are some steps to use MSCONFIG to force your computer into SAFE MODE
  1. Click on Start and then Run.
  2. In the text box in the Run window, type msconfig and click OK. This will open the System Configuration Utility program.
    Note: Do not make changes in the System Configuration Utility other than those outlined here to avoid causing serious system issues. This utility controls a number of startup activities other than those involved with Safe Mode.
  3. Click on the BOOT.INI tab located at the top of the System Configuration Utility window.
  4. Check the checkbox next to /SAFEBOOT and click OK.
  5. You will then be prompted to either Restart, which will restart the PC immediately, or Exit Without Restart, which will close the window and allow you to restart the PC manually.
  6. After the restart, the PC will automatically boot into Windows XP Safe Mode.
    Note: Windows XP will continue to boot into Safe Mode until the System Configuration Utility is configured to again boot normally.
  7. When your work in Safe Mode is complete, click on Start and then Run. Type msconfig in the text box and click OK.
    This will again open the System Configuration Utility program.
  8. Choose the Normal Startup radio button and click OK.
  9. You will then be prompted to either Restart, which will restart the PC immediately, or Exit Without Restart, which will close the window and allow you to restart the PC manually.
  10. After the restart, the PC will boot into Windows XP normally and will continue to do so.
    These instructions were written by About.com
    http://pcsupport.about.com/od/tipstricks/ht/smsysconfig.htm
May 24, 2009 | Microsoft Windows XP Media Center Edition...
Black screen with mouse comes up after i restart it
When the PC is booting , hit F8 , select safe mode from the options.
If you are able to boot in safe mode, you can go into MSconfig and turn off programs that may be giveing you trouble in normal mode.
Go to start > run , type msconfig.
Go to the startup tab and click disable all.
Restart. If you still cant get in back up your data and run your restore CDs.
Apr 22, 2009 | Dell Computers & Internet
Loggin on
1.       Boot the computer in Safe mode( To Boot in safe mode you need to keep hitting the f8 keys while the computer Restart and you will prompt a screen which reads as Advanced boot Menu . in the windows please select safe mode with network ). An then try to login . and open misconfig and disable all the thrid party services and Restart the computer .
If you still have the problem  boot the computer using vista Dvd . And select the option to startup repair option . That will fix the problem
Oct 11, 2007 | Microsoft Windows Vista Ultimate Edition
Computers & Internet Logo
David Payne
David Payne
