This fridge has 6 push buttons on the control panel, combination few at the time changes the setting- for example switching to store mode- display (is not cooling).
SOURCE: SAMSUNG RS253BAWW NOT WORKING
the ice maker wont cycle untill the temp of the ice is around 10 degrees so if the freezer is at 15 or 20 due to some other malfunction then you will see the maker full of ice but it wont harvest and make another batch. so you could have a sensor bad, control malfunction, refrigeration issue, compressor, defrost system malfunction(you mentioned ice build up)
SOURCE: Vacation button keeps on activated(refrigerator Samsung SRS20NTC)
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
Set to regular temp then lock functions.
Freezer temp + fridge temp for 3-8 sec to lock
function
SOURCE: Fridge temp set to 38 is blinking,,reset unit
I had a similar problem, paid a technician $90 to tell me to defrost the entire unit for 15-20 hours, and now it works like new. It is supposed to self defrost, but with poor circulation in the freezer (simply caused by too much stuff in there) the unit frosts up. This caused a rising temp in the freezer leading to inconsistent temps.
Anyone reading this with a similar issue, save your money and defrost it overnight. You should see a pool of water in the bottom of the freezer after defrost if this was the problem.
SOURCE: What would cause a 2 day old fridge to shift into
A power outage. If no power outage you may of had a power surge and with this model it will kick itself to the off position to help protect the unit from anymore damage.
SOURCE: My 28ft french door samsung
Hi
Please check this link to get a detailed idea and resolution about the problem that you are facing with the " OF" displayed in the temperature area:-
http://ars.samsung.com/customer/usa/jsp/faqs/faqs_view_us.jsp?SITE_ID=1&PG_ID=0&AT_ID=97268&PROD_SUB_ID=0&PROD_ID=823
Please get back to us if you have further query else please accept this "particular"suggestion. Thanks for contacting fixya.com
