Question about Frigidaire FFBD2406NS Built In Dishwashers
Frigidaire FFB240 dishwasher won't stop
My dishwasher won't stop. It will continue to run beyond 3 hours ... and still run if I don't stop it. This is on light cycle.
  • Official Brand Answer
  • 2,267 Answers
Good Morning AA1970,
I see that you are having trouble with your Frigidaire dishwasher, model# FFB240, continuing to run unless you shut it off. While I'm not familiar with this particular model number, I suggest that you give the appliance a hard reset. You will do this by shutting the power off at the circuit breaker for at least 20-30 minutes. After restoring power, run the cycle. If it is still continuing to run unless you shut it off, I suggest contacting a local authorized technician for further assistance.
-Best Regards-
WP
Posted on Apr 04, 2014
  • 35 Answers
SOURCE: frigidaire gallery dishwasher fdb949gfb2
it looks as tho.you have a touchpad problem.the touchpad is malfuntioning.
Posted on Jun 25, 2007
  • 58 Answers
SOURCE: Frigidaire Dishwasher Console/Lights Flashing
which light flashes?
Posted on Nov 02, 2007
  • 3 Answers
SOURCE: dishwasher, flashing lights, frigidaire
The steam has gotten into the keypad display and fried it. Call Fridgidaire and let them know you've seen numerous people on the internet with the same problem and that you need part# 154554401 It worked for me.
Posted on Apr 01, 2009
SOURCE: Frigidaire Ultraquiet III
I had the same problem with mine. I turned the heated dry off and it works fine.
Posted on Jun 09, 2009
tbirdfan1
  • 3051 Answers
SOURCE: Dishwasher won't stop running.
Hello there:Its possible your thermostat may be bad, you can ohm it for continuity, take the wires off it first of course.
With the wires off you can even jump it by taping the wires together with electrical tape and run it through a cycle and see if that solves the problem
if not than i would check the heating element
If your water is hot coming into the dishwasher, it should be about 120-130 degrees, and if it is not these temps this would cause the cycle take 3 times longer to finish , then its possibly a bad heating element.
You would need to ohm your heating element for continuity, a good element should show 30 ohms or less.
Make sure the breaker is off to your dishwasher first. Its likely the electrical terminals are in the very back, so you'll likely need to pull your dishwasher out to ohm the heating element. Take the heating element wires off first before testing the element for continuity.
But first feel your heating element all around inside your dishwasher, if you feel bumps on it or pits in it, its definitely your element thats
causing your problems ok
Hope this is very helpful for yo
Best regards Michael
Posted on Dec 31, 2009
Stopped in mid cycle and wont restart
Hi....I think I can help you with this. I checked a troubleshooting site for Crosley dishwashers, and there could be a couple of reasons why the cycle stopped:
1. The thermal fuse shuts off power to the dishwasher if it overheats. If the thermal fuse blows, it will prevent the dishwasher from starting. To determine if the thermal fuse is defective, use a multimeter to test the fuse for continuity. If the thermal fuse does not have continuity, replace it.
2. The door switch prevents the dishwasher from running while the door is open. If the door switch is defective, the switch will prevent the dishwasher from running even when the door is closed. To determine if the door switch is at fault, use a multimeter to test the switch for continuity. If the switch does not have continuity, replace it.
3. The door latch ensures that the dishwasher door latches shut. If the door does not latch properly, the door switch might prevent the dishwasher from running. If the door latch is broken, replace it.
You can also find more related troubleshooting here:
http://www.repairclinic.com/RepairHelp/How-To-Fix-A-Dishwasher/31---/Dishwasher-won-t-start
You'll need the model number for your particular dishwasher.
I hope this has helped you.
2. 2
Feb 05, 2016 | Crosley Dishwashers
Dishwasher runs too long
Good Morning Tessa,
I understand that your Frigidaire dishwasher, model# FDB700BFC, is running too long. I also see that it seems to be getting stuck on one particular cycle and runs continuously for hours even though the water is hot. It sounds like there is possibly a miscommunication between the different boards inside your appliance. I please ask that you try resetting your dishwasher, by either unplugging it or shutting the power off at your home's circuit breaker, for 20-30 minutes. Once power is restored, try running any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 16, 2014 | Frigidaire FDB700BFC Built-in Dishwasher
My frigidaire professional series dishwasher has no power
Hello qmainous - The issue may lie with the door latch; a door switch is used to start and stop your dishwasher. It's a safety feature that won't allow water to flow with the door open. With a faulty door switch, there is a chance your dishwasher won't start at all. Dishwasher door switches are about an inch long. They are usually black but can be red. There are metal prongs on the body of the switch called terminals. Some door switches have two terminals and some have three. If your door switch is OK, check the timer assembly. This controls when and how long power is sent to other controls on your dishwasher. If these controls don't receive power, they won't work. The timer assembly contains a motor. Check this motor as well. It is often cheaper just to replace the timer motor rather than the complete assembly. My last suggestion is to check the cycle selector switches. These switches indicate cycles for washing, drying, and setting the temperature of the water. If one of your switches is the problem your dishwasher may also prevent the unit to start. Dishwasher cycle selector switches tell the timer which cycle to run by opening and closing electrical circuits. Most selector switches are six to eight inches long. They are usually black and have terminals. By testing each one of these parts with an ohmmeter you should be able to determine why your dishwasher is not working. It is possible for other parts to fail but these are the most common parts to check. If any proves to be ineffective, I strongly suggest contacting a professional to move forward accurately.
Nov 16, 2012 | Frigidaire Dishwashers
Door latch not working on Frigidaire 18 in.
Hi -
The issue may lie with the door latch; a door switch is used to start and stop your dishwasher. It's a safety feature that won't allow water to flow with the door open. With a faulty door switch, there is a chance your dishwasher won't start at all. Dishwasher door switches are about an inch long. They are usually black but can be red. There are metal prongs on the body of the switch called terminals. Some door switches have two terminals and some have three. If your door switch is OK, check the timer assembly. This controls when and how long power is sent to other controls on your dishwasher. If these controls don't receive power, they won't work. The timer assembly contains a motor. Check this motor as well. It is often cheaper just to replace the timer motor rather than the complete assembly. My last suggestion is to check the cycle selector switches. These switches indicate cycles for washing, drying, and setting the temperature of the water. If one of your switches is the problem your dishwasher may not start. Dishwasher cycle selector switches tell the timer which cycle to run by opening and closing electrical circuits. Most selector switches are six to eight inches long. They are usually black and have terminals. By testing each one of these parts with an ohmmeter you should be able to determine why your dishwasher is not working. It is possible for other parts to fail but these are the most common parts to check. If any proves to be ineffective, I strongly suggest contacting a professional to move forward accurately.
Oct 21, 2012 | Frigidaire 18 in. FDR252RB Built-in...
Frigidaire dishwasher has no power and won't start
Hi - The issue may lie with the door latch; a door switch is used to start and stop your dishwasher. It's a safety feature that won't allow water to flow with the door open. With a faulty door switch, there is a chance your dishwasher won't start at all. Dishwasher door switches are about an inch long. They are usually black but can be red. There are metal prongs on the body of the switch called terminals. Some door switches have two terminals and some have three. If your door switch is OK, check the timer assembly. This controls when and how long power is sent to other controls on your dishwasher. If these controls don't receive power, they won't work. The timer assembly contains a motor. Check this motor as well. It is often cheaper just to replace the timer motor rather than the complete assembly. My last suggestion is to check the cycle selector switches. These switches indicate cycles for washing, drying, and setting the temperature of the water. If one of your switches is the problem your dishwasher may not start. Dishwasher cycle selector switches tell the timer which cycle to run by opening and closing electrical circuits. Most selector switches are six to eight inches long. They are usually black and have terminals. By testing each one of these parts with an ohmmeter you should be able to determine why your dishwasher is not working. It is possible for other parts to fail but these are the most common parts to check. If any proves to be ineffective, I strongly suggest contacting a professional to move forward accurately.
Oct 17, 2012 | Electrolux Fridigaire Lp Conversion Kit...
Frigidaire Affinity ATF7000E Front Load Washer won't stop spinning with 1 minute on timer- it continues until I hit cancel. I don't like to babysit a machine but have to make sure it doesn
If the unit is washing properly, as far as you can tell, but it won't stop spinning, then I would have a professional look at the control panel and timer to be diagnosed because there seems to be in miscommunication.
Sep 14, 2012 | Frigidaire Affinity ATF7000E Front Load...
Dec 31, 2009 | Frigidaire Dishwashers
Dishwasher continues to run beyond necessary time
most likely the microprocessor has failed
Good Luck!
Feb 20, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Frigidaire FFBD2406NS Built In Dishwashers Logo
373 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Robert Roath
Robert Roath
Level 1 Expert
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
