Question about Brother MFC 7420 All-In-One Laser Printer
MFC 7420 CONTROL CENTER FOR WINDOWS 8
I CAN'T FIND THE BROTHER CONTROL CENTER ON MY NEW WINDOWS 8 COMPUTER
  • Brother Master
  • 783 Answers
Go To Below official Brother Printer Page For Your problem, MFC 6490CW Others Brother Solutions Center Hope It's resolve all Your Printer Problem,
Or Still having Problem Then follow Us For
Brother Printer Support
Posted on Apr 01, 2014
SOURCE: brother mfc control center.
ok so its a common problem just take it to the store it won't cost you a dime.
Posted on May 14, 2008
SOURCE: I can't find the back door sensor on Brother MFC-7420
I have the answer. I just fixed mine. The sensor is not really on the door. You have to remove the door by openning it all the way and carefully sliding it out ( one of the pegs holding the door is hourglass shaped. This will slide out first. The other is round. You will see a black flap that covers a red drum. Pull the flap down carefully. There will be a six inch long rod it's about 1/8 of an inch in diameter. It extends from the middle of the flap all the way to the right side. This probably popped out of place. Make sure that it is all the way to the right as this is where the sensor is. There is a little spring on the bar on the left side. This should be straight up and down. if it is not, then you need to fiddle with the bar.
The trick was that the sensor is NOT on the door, but on this inner flap. When the door closes it pushes this flap agains the drum and the little bar activates the sensor.
Please do not applaud so loud, you are ambarrazing me!!! hehehe. Good luck!.
Posted on Aug 11, 2008
  • 320 Answers
SOURCE: error 2001 on brother mfc 7420
please tell me more! i just checked my brother manual and i do not see a error code 2001????????????
Posted on Feb 16, 2009
leroyal
  • 2120 Answers
SOURCE: mfc-7420 Black Line horizontal across paper in 3 places
try moving the small blue slider on top of the drum cartridge side to side 10 times.
Posted on Mar 10, 2009
pineworks
  • 4041 Answers
SOURCE: brother mfc-7420 - unable to print
OK Try
Solution:
  • Machine off
  • Switch on the machine while holding down the “menu”button until all the leds are flashing on/off. Now you are in “maintenance” mode.
  • Press 80
  • Press the “mono start” button several times until you see “purge: xxxx”
  • Press “2783” in order to reset the purge counter. You will see: “purge:0000”
  • Press the "stop" button.
  • Press “99” to exit the maintenance mode.
All the best
Posted on Jan 30, 2010
HOW DO I un-lock the scanner on a Brother MFC 7420?
Unfortunately, the MFC-7420 doesn't have a physical lock switch. You need to turn off the all-in-one and wait for the unit to clear its memory. If the error recurs after you press the power button again, wait 30 minutes and try again. (Note: you will lose any faxes that are in memory. See the User Guide page 11-5 to save this information.) You can find the manual on the Brother support page for the MFC-7420: https://www.brother-usa.com/support/ModelInfo.aspx?R3ModelID=MFC7420 . Click on the Manuals & Documents tab. Then click on the Manuals on our Online Solution Center for the English version of the manual. The direct link to the User Guide is currently: http://download.brother.com/welcome/doc000387/ALLFB_UsaEngUsr_B.pdf .
You can also try unplugging the all-in-one for several minutes to reset the error codes. If the error persists, contact Brother if the MFC-7420 is still under warranty (1 year). If it isn't under warranty, consider replacing the unit. The repair costs may be unreasonable.
I hope this helps.
Jan 09, 2017 | Brother MFC-7420 Printer
Drive hp brother 7420 for win 7
If you are searching for drivers i.e. Multifunctional Brother 7420 model, check out this LINK.
On the link Page " Brother Models compatibility between Windows® 7", scroll to the "MFC Model" scroll down to "MFC-7420" & click on "Download" to get the Win 7 driver for your Printer.
Hope it helps.
Jun 15, 2011 | Office Equipment & Supplies
How do we connect Windows 7 HP to Brother MFC-7420?
you can 1. connect it directly to your computer and let your computer recognize it. or 2 use the install Cd and install it on your computer.
May 15, 2011 | Brother MFC 7420 All-In-One Laser Printer
I have a printer brother mfc-7420 but i cannot scan my documents so i can attach to emails. can you please give me a solutions.
You must have the Brother printer control center installed on the the computer you wish to scan to. If you do not have the original software disk that came with the printer, you can download it from the brother web site (www.brother.com).
Feb 08, 2010 | Brother MFC 7420 All-In-One Laser Printer
Need to download installation software for Brother MFC-7420 printer.
You can download the printer driver from the Brother WEB site.
Make sure you download the driver for your model printer and the Windows version that is installed on your computer.
Use this link to the Brother WEB site :-
www.brother.com/html/download/index.htm
Sep 27, 2009 | Brother MFC-7420 Printer
I want to scan an multiple images and save it to a PFD format.
You , nor anyone else,cannot scan and save as an ADOBY PDF file. To creat a PDF file requires either the ADOBY writting software of another software that saves  in the PDF file format.    Scanners take a picture of what ever is layed on them and copies then by breaking them into  millions of dots and then saving as a picture in a format such as JPEG.   Sorry
Mar 12, 2009 | Brother MFC 7420 All-In-One Laser Printer
Brother MFC 7420 all in one Scanner not working
sorry but is the 7420 compatible with Vista? what does the box say?
Nov 08, 2007 | Brother MFC 7420 All-In-One Laser Printer
Brother MFC-7420
I need to down load driver for Brother MFC-7420
Sep 03, 2007 | Brother MFC 7420 All-In-One Laser Printer
Brother MFC 7420 All-In-One Laser Printer Logo
257 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
