Question about Hotpoint WMA11 Front Load Washer
How to change brushes on wma11, mainly how to i get the top off?
  • 909 Answers
There are two screws on the rear of the lid, one near each corner, undo these and lift the rear of the lid a little and pull back to release the front from its clips. ( but first, if I am correct in thinking the motor is underneath on these, tilt back the machine and lean it against a wall or cabinet, and look to see if it's underneath.
Posted on Jun 15, 2009
Machine starts then program end light flashes constantly and has done nothing?
I had similar problem and Eventually replaced motor brushes which solved the problem
Feb 26, 2012 | Hotpoint WMA11 Front Load Washer
Wma11 starts to load water then goes to end program within seconds
hi try another program like spin cycle if is still the same the programmer timer control could be the fault
regards
shaun
Dec 05, 2011 | Hotpoint WMA11 Front Load Washer
My Hotpoint first edition WMA11 will not start as it does not recognise that the door is closed.
check to see if you can use a small object to simulate close door if works switch needs to be adjusted
or replaced
Jun 09, 2011 | Hotpoint WMA11 Front Load Washer
How do you change the belt?
First you will have to remove the top cover where the brush roller is. I cannot remember off the top of my head, but I believe that there are 2 possibly 3 screws on the top cover. As you look at the machine from the front, they should be just behind the brush roller on both the left and the right. The 3rd screw is an optional thing on some models. It will be at the back of the machine between the hose and the main body. To access it easier lay the machine down on the floor. Once you have the top cover off, and can see the broken/worn belt and the brush roller, there should be a black and yellow sticker with detailed instructions there on how to change the belt.
Nov 05, 2010 | Eureka Altima Upright Vacuum Model 2996AVS...
Hotpoint wma11 where is the filter?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Power off the mains. The filter is located behind the silver plate at the back of the machine at the bottom. Four screws hold it on. Drain out all the water. The filter is inside the big black rubber hose attached between the pump and the main drum. Remove the plastic clip holding it to the pump unit and then the metal cir clip holding it to the main drum. Inside is a white molded cone and a big white ball which floats. You will find a lot of junk here, clean out thoroughly. To refit put white cone back inside just as you found it, at the bottom, fit ball back into the cone. Attach to the bottom to the drum and re-fasten the cir clip. Finally reconnect the gator to the pump unit and tighten the plastic clip. Check out the pump too before reconnecting.
And rate me nice pl for the free help!
May 21, 2010 | Hotpoint Aquarius WF000 Front Load Washer
How to change belt on Hoover DM6227T
Hi Diane
There are two options here; Go to the Hoover UK website and download the user manual (http://service.hoover.co.uk/manuals/Manuals.aspx?Section=6) and add in the DM6227 code and number without the T letter. The pdf downloadable (and free) user manual will upload to your computer.
Or follow this method:
There are two rear screws on the top of the hood of which you'll have to swing the handle all the way down to reveal both screws at the back of the top hood. Undo these screws and put them in a safe place. Then gently prise off the main control selector height dial and the top hood should be able to pop off easily. Then you'll main roller brush should be revealed as well as the broken belt.
Once the belt is removed, clean the brush roll of any threads or hairs that have stuck the bristles down. Then fit new belt, align the roller bar properly including the new drive belt and then refit the top hood back on, snap fitting down, two screws in and gently refit the control dial height adjuster back on making sure the front raised part of the dial knob is facing the Hoover.
Anything else don't hesitate to contact.
Nov 13, 2009 | Vacuums
Water continues to flow into the detergent box,albeit slowly,until the drum is full to overflowing Model no, WMA10
in the sump hose there is a plastic tube about 6 inches long and it gets blocked.make sure the hose on top of this tube is connected to pswitch in the top.
Sep 14, 2009 | Hotpoint WMA11 Front Load Washer
Washer does not agitate, everythiung else works fine.
hi there.......you havent stated whether this is a top laoder or front loading automatic...so im assuming its the latter.im also assuming that when you say everything else works you mean it takes water in heats.. pumps water out ....the problem is usually caused by a broken drive belt.....or worn brushes in the main drive motor....loose wiring connection to main motor....TOC blown in main motor
soloution replace broken drive belt......check brushes in main motor and relpace if badly worn......if the latter items are ok...relace or substitute main motor
regards Sir Galahad
Aug 12, 2009 | Washing Machines
Hotpoint WMA11
If the motor is not getting power when it is called for spin. Then check the computer and the timer. Also check the balance sensor
Feb 14, 2009 | Hotpoint WMA11 Front Load Washer
Electrolux vacuum making a clicking sound when the brush is engaged
Check that there is nothing lodged between the roller brush and the main dirt channel. You may have to take off the sole plate by either locating the cross head screws underneath or if the hood pops off the top - some Electrolux models have screws now located on the top. Once the roller brush is open to your eyes, look at the drive belt and check its condition - it may be on its way out and needs replacing OR the brush roller has clogged up OR the caps which hold the roller brush in both ends of the roller are loose and need a slight tap to lock them back in.
Dont forget to rate this solution. Ty
Jul 30, 2008 | Electrolux Vacuums
Hotpoint WMA11 Front Load Washer Logo
103 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
