Question about ZTE Warp
The screen doesnt turn on but everything else does
I dropped it in the toilet, it still works, turns on, rings, just the screen is fried
    Scholar:
  • 91 Answers
I m sorry to say u but there is no other way except changing ur screen to fix ur problem.
thank u !
Posted on Apr 02, 2014
  • Alexis Swigert
    Alexis Swigert May 28, 2014
    how could i switch the screen out if i had 2 phones exactly alike ... both ZTE Warp
"I HAVE A SAMSUNG GLINT
I'm afraid that since you turned it on it's probably fried at this point. You can try putting it in a bag of rice which should draw out some of the water however since it was turned on I can't guarantee that the rice method will work.
May 10, 2011 | Samsung Cell Phones
Water swirls but does not siphon
A few things to check.....
Is enough water dropping... maybe the flapper is not working right or the tank is not filling properly..
Are the holes in the ring under the seat filled with ****??? or dirt???
Is the toilet vented properly??? maybe the vent is plugged... no air... no flush...
Is something stuck in the trap of the toilet so the water cannot get out quickly...use a toilet auger to check....
Drain pipe is plugged under toilet...
heatman101
May 05, 2011 | Home
My fone dropped in the toilet and i dried it and everything and now it just has a white screen
If you didn't take out the battery immediately it might have fried the circuits. I suggest you go get it fixed because an average person doesn't have the knowledge or the tools needed.
Dec 13, 2010 | LG enV3 VX9200 Cell Phone
When you sit on the ring it veers off to the left and you are left sitting there crooked. How do we adjust it?
See if nuts on studs on bottom where it mounts to the floor & flange are loose. If they are loose tighten both of them evenly. If they are tight you will need to replace wax ring that is between toilet & floor.Turn off shutoff water valve to toilet. Flush once holding down handle to let tank drain. Remove both nuts & lift toilet off flange. Remove wax ring. Scrape all old wax off toilet & floor flange. Install new wax ring. Set down toilet on ring & snug nuts evenly. Sit on seat & apply your weight evenly to distribute wax & level. Retighten nuts. Turn water back on. Allow tank to refill. Flush toilet & check for leaks.
Sep 30, 2010 | Jacuzzi Bath Perfecta EZ33 959 White round...
My toto toilet was installed with the seal which came with it. A leak started in the downstairs suite and when the plumber lifted the toilet off the floor he said it needed a wax seal as well as the rubber...
That should work. Sometimes if the space between the bottom of the fixture and the top of the collector ring is too large, (ie: the addition of flooring) one can double up on the wax rings also.
Sep 24, 2010 | Toto Aquia II Dual Flush Toilet
Dropped the camera in a toilet - takes pix with "lines" - can we do anything
If you tried to turn it on while any water was still in it, you probably already fried the circuits.
Jul 26, 2010 | Nikon COOLPIX P5100 Digital Camera
My phone screen went blank after dropping in the toilet
You should have left it dry instead of turning it on, you probably have corrosion now, find a local place that works on phones to see if they'd work on it.
If you want to try to completely dry it, put it in rice for 24 hours minimum to draw out all moisture.
Aug 03, 2017 | Motorola Mobility RAZR V3
I dropped my LG VIEW in the toilet and everytime i turn it on it says "emergency download". what should i do??
I would take it to your phone service provider...you will probably will have to get a new phone.
Sep 02, 2009 | LG CU400 Cellular Phone
G1 in the toilet
Let it dry for a longer period. As, if the water has gone into the screen area, draining the water is a real issue. If it still doesnt respond, get it to a service station before the condition worsens.
Jul 27, 2009 | HTC G1
I have the same problem!!!! I just dropped mine 2 hours ago!!
http://www.fixya.com/support/r3771170-phone_water_damage
Jun 04, 2009 | LG Vu CU920 Cellular Phone
ZTE Warp Logo
87 people viewed this question
Top ZTE Cell Phones Experts
john smith
Nyte_Ryder
vince
Are you a ZTE Cell Phone Expert? Answer questions, earn points and help others
