Question about Yamaha RX-V793
When turning the volume up to the mid level spot on the dial the power on my yamaha rx-v793 clicks off. Apon turning the power back on,the unit will stay on as along as the volume is below the mid range. Since the unit is stored in an enclosed stereo cabinet I beleived that it might be over heating and it was certainly quite warm. I allowed the unit to cool over night and tried the volume setting while it was cool and the same thing happened. I also removed the cover to see if the fan was functioning and to clear any vent blockages. Everything seemed clear and although the fan did not come on most likely due to the cool temp, the unit shut dowm immediately when raising the volume to the mid range area. Also the I did not notice any distortion to the sound quality at any time. thanks TH
  • tfhealy Jun 18, 2009
    Thanks I will give this a try this weekend.
    Thanks again
  • tfhealy Jun 23, 2009
    I found a crack in the wire covering of one of the speaker wires.
    Once repaired the problem was solved. Thanks for the advice it worked perfectly.
    TH
    President:
  • Yamaha Master
  • 1,114 Answers
Check your speaker connections, the unit is shorting out. Best way to make sure it's not the receiver is to disconnect all speakers then turn on your receiver,turn on a source like cable or dvd and turn up the volume on the receiver. If it stays on, you know it's not a problem with the receiver.
Now to find the problem; re connect speakers one by one, each time, turn on the receiver and turn up the volume, when you get to the wire causing the problem, it will shut off. At this point, disconnect the speaker wire at the speaker causing the problem to make sure it's not the wire itself. Make sure the loose wires do not touch each other as this will cause the unit to short or worse! If it still plays, then look at the speakers internal connections if possible. Look for the obvious, burn marks on a crossover or wires touching, if you find none, use a multimeter if you know how to read one and set it to resistance. If it reads 1... you've got a bad voice coil and the speaker needs to be replaced. Most often, however, is that a partial part of a speaker wire braid has touched the other. + to - and does not have enough of a load to short out until you turn up the volume. The other scenerio is if your wiring was "pre-wired" in your home for surround and there is a nail or screw in the wire and doing the same thing. If you still have issues beyond this, post a comment and I will help some more. Hope this helps
Posted on Jun 15, 2009
Yamaha RX-V793 The volume changes from low to high by itself. Is this a blown channel?
You have a bad Rotary Encoder(what you think of as a volume control) It is not a variable resistor, as in decades past. It is an input to a microprocessor(a computer within your Yamaha). If you require additional assistance, or would like to inquire about repairing your Yamaha, please visit my website at audioserviceclinic.com. You may contact me there. Thank you.
Dec 18, 2014 | Yamaha Audio Players & Recorders
Yamaha RX-V793 receiver shuts down when I turn up volume. Checked the speaker wires and they seem okay. I then hooked it up to an older DVD player I had and it works fine. Don't know if it's 5.1 bu
My first thought would be that when you moved the receiver to connect another DVD, the problem quit since the speaker wires moved. The best way to test would be to re connect the original unit the same way as the new unit and test again. If it still cuts out, disconnect the speaker wires and re test. if it still cuts out, try the new player and test again. if it does not cut out, there may be a problem with the old units audio output. Generally if its a problem with the receiver it would not matter what source you are using, even the tuner on the receiver, if there was a short in the receiver it would cut out. Let me know what your results are and I will help more if needed. Best of luck!
Nov 24, 2011 | Yamaha Audio Players & Recorders
Dear Sirs, I have a Yamaha Rx- v363 receiver 2008 yr. model. I'm looking for help in programing the volume control on this unit. When I turn the unit off and then back on the volume it stuck on its highest...
Page 48 under Set Menu:
Initial volume INI.VOL.
Use this feature to set the volume level when the power of this unit is turned on.
Choices: Off, -80 dB to +16 dB
Control step: 1 dB
Feb 20, 2011 | Yamaha RX-V363 Receiver
Volume on Tv/dbs mode extremely low......volume works fine on tuner any ideas? This is a Yamaha RX-V793 thanks
I have the same problem, I'm thinking that the equipment is old and I need a new one. need an answer too!!!!
Nov 05, 2009 | Audio Players & Recorders
My Yamaha RX-V661 shuts off at moderate volumes.
Try to disconnect speakers one by one and see if any of them causes the problem.
Nov 05, 2009 | Yamaha RX-V661 Receiver
Yamaha RX-V390
Try reseting the Yamaha-Shut the power off, and while holding down presets 1,2 and 3 press power on.
Nov 24, 2008 | Motorola Mobility DRC800 Universal Remote...
Receiver turns on and clicks off when volume is raised over 8 or 9 on the dial
I had the same problem with my Yamaha amp. It turned out to be a shorting speaker wire. When I resoldered the speaker wall outlet connection it worked fine!
Feb 27, 2008 | Yamaha RX-V659 Receiver
Yamaha RX-V793 flashing light on volume control and no volume
Per Yamaha support page: The volume light on my Yamaha AV receiver is flashing, what does this mean ? The "MUTE" function on your remote control has been activated. The reason that you can still hear a very low sound is that the muting circuit within your stereo is not a full mute, but rather a -20dB mute. To deactivate the "MUTE" function, simply press the "MUTE" button on your remote control. (Make sure the volume control is turned down to avoid damage to your system.) If you misplace or lose your remote control, you will have to purchase a new remote control unit, as there is no duplicate function on the front panel of your stereo. Unplugging the stereo will not deactivate the muting circuit, as the microprocessor "remembers" if the muting circuit was active prior to being turned off or unplugged. If you need to purchase a remote control, you may order one directly from our parts office. You may reach them by dialing (714) 522-9888 from 8 am to 3 p.m. Pacific Time, Monday through Friday. If you have any other questions, please contact our customer service department by dialing (800) 292-2982 Monday through Friday from 8:00 a.m. to 4:00 p.m.
Sep 03, 2006 | Yamaha RX-V793
Yamaha RX-V793 Logo
134 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
