Question about Samsung Refrigerators
RF265AB - Spring from Vertical Hinge Fell Out
There's a vertical flap or hinge on the left-side door that's supposed to slide into a track inside the fridge. Yesterday I found a small spring inside the fridge and the flap no longer resets itself to fit into the slot, it has to be manually positioned. I can't for the life of me figure out how the spring goes back onto the hinge and I can't find any drawings or videos suggesting how to repair it. Does anyone have ideas for how to get it back in, or a drawing for the proper positioning of the spring? Thanks, Dan
  • 29 Answers
SOURCE: Bottom hinge on fridge door broken
Yes, there is supposed to be a plastic bushing/washer under there. Usually 1/8 inch thick. If a dealer is not handy you may cut some out of plastic to put there. Then undo the top hinge, and carefully lift the door off (you might want to empty the shelfs). Put your spacer on the hinge pin, and replace the door and the top hinge.
Posted on Jan 28, 2008
SOURCE: Hotpoint FFA70 - Freezer door will not close properly.
The rear panel can be removed,i have done it.I removed the 4 hex head screws from the top & bottom of the panel,and firmly pulled it forward.The reason i say pulled firmly is that when panel came out the back of the freezer was solid with ice.I have defrosted the freezer,dried any water from the unit and replaced the panel.Fingers crossed,so far,so good.In my case this build up of ice was definately the reason the drawers were not sitting in the correct position,as it caused the rear panel to 'bulge' out.Hope this helps.....
Posted on Jan 12, 2009
invisiblejim
  • 7 Answers
SOURCE: I was trying to clean
I think the main problem with this machine is that the grounds fly all over inside when grinding and combine with the steam and hot water and eventually gum up the moving parts. This causes the latch for the filter basket to lose its grip sometimes and the door pops open during the brewing cycle...I was trying to take apart the slides to clean them out and made the mistake of removing the small screw underneath the left slide. Then the spring popped out and it took about an hour to get it back together, very frustrating. I ended up bending one end of the spring into a slight hook with a needle nose pliers so it would catch better on the "nub" that is connected to the side button. The best way I figured out to clean the slides so far is to blast them out with compressed air periodically for preventative maintenance. I use one of those cans normally used to dust off electronics and insert the straw into the slides.
Posted on Feb 18, 2009
peyton32034
  • 410 Answers
SOURCE: The piece that connects the vertical hinge to the door is broken.
Try partsdirect.com they have one of the best parts resources available. you will need your complete model number off of the inside of the unit it is located either on the eiling or right hand wall of the refrig section. thx Peyton
Posted on Mar 16, 2009
  • 24 Answers
SOURCE: DCS 30 inch oven door fell off
First thing is be careful them sprins are strong and will hurt your fingers bad if not careful. That said place both hinges in 1/3 open position they should stop there. if not put both all the way open then slide door back on and close. supposed to only lift off in 1/3 open position but whatever works.
Posted on Jul 25, 2009
How to remove the oven door
On many models with the door open there is a screw on either side of the door on the inside. Each screw secures the door to the hinge. Remove the screws lift the door back to the near vertical rest position and carefully lift the door out from the hinges.
Caution the door is heavy!! The door must be in the near vertical position to have the hinge in a neutral location. There is significant spring pressure on the hinges. The door should be partial open held in a neutral position before attempting to lift up.
Dec 01, 2015 | Ovens
Does anyone know how to replace the hinge DA61-04866A on a Samsung french door vertical panel
unclip the plastic cover off your door hinge and unscrew the screws on your door make sure you leave the top screw in just a bit so you can take it out with your fingers before you drop the door ok same for both sides
Jan 22, 2015 | Samsung RF263AERS - 26 cu. ft. French Door...
The seal or flap between the french doors doesn't retract
check it closely something has broke an the flap is not closing as u close the door
Jun 28, 2014 | Samsung RS2556 Side by Side Refrigerator
How to instal an oven door on an ILVE stove?
I am pretty sure the door goes on the hinges go in the bottom of the door just slide in the bottom and door comes of the same way
Jun 01, 2014 | ilve Majestic Collection UM76DMPVS 30"...
How to install spring on french door flapper/divider for Samsung RF266
On mine one end of the spring broke off in the hole on the door. It was on top of the hinge so it looked like a pivot pin. I found that this was the second hole for the spring. I pushed the end of the new spring up under the hinge and popped the broke piece of old spring out. Now I could see the 2 holes. You then need to put the spring into each hole. The hole on the flap also needs a white plastic sleeve if that is missing. that goes on the end of the spring and fits into the flap hole. Then the trick part is understanding how the spring works? If you put both ends of the spring in the holes and shut the flap, it now stays in position to close and be flipped open by the guide that swings it open to seal.
Good Luck.
Feb 03, 2014 | Samsung RF266ABRS Bottom Freezer...
How do i replace the side flap door on my mower
There is a rod that acts like a hinge pin. There is also a spring that keeps the flap door closed. The rod goes through both the flap and the spring at the same time. You need to hold the spring under tension while sliding the pin into both pieces at the same time. A little bit tricky, but do-able.
Hope this helps.
Jul 28, 2011 | Mtd Yard - Man 160cc, 21" Self - Propelled...
I need to clean between glass plate and oven door on my Zanussi electric cooker. I have drips where I've wiped the door over, also there is dust in between. Model ZBF 360W, Serial 61705615, Prod. No....
The following worked on my zbf360x built in Zanussi.
First you need to remove the oven door. To do this open the door half way. On each hinge there are two small metal flaps. Lift both of these. Now with the door still half open pull hard on the door. You will find the hinges spring and if you release the pull now it will just spring back. When the hinges spring give an extra hard pull on one side and then the other each hinge should pop out.
Once you have the door off just remove the small screws on the bottom of the door to allow it to hinge open and clean the inside glass.
Hope this helps,
B4M
Sep 29, 2009 | Ovens
Kleenmaid Stainless Steel oven door will not close properly.
The door hinge is probaly broken or could just be the spring. Open the door to the 45 degree position (halfway) and pull on the door. It should come off the hinge assembly. Slide out the oven a little to access the screws for the hinge to see what is broken or wore out.
Aug 10, 2009 | Ovens
Dishwasher ''soft drop door'' mechanism came apart - door now drops
I had a similar issue as described by mc1bean. One day my Jenair dishwasher door just fell down. The right side spring was fine. The left side spring was still hooked into the door hinge but the cable was laying on the floor in 2 pieces. Over time it wore down and broke. I ordered just the soft drop cable. Now I could not find any installation instructions how to install the soft drop cable. After a few tries I think I got it right. Here are the instructions for hooking up the right side spring with the cable. The spring has to be hooked into the door hinge at the notch closer to the door. The end of the cable with the hook has to be hooked into the other side of the spring. The cable should lead from the bottom around the pulley up to the door hinge again. Now the other end of the cable has to be hung into the door hinge on the notch further away from the door. There is some slack, but it is not quite enough for the cable to get over the pulley when in rest position and undo itself.
I hope this helps others who have the same issue.
Feb 10, 2009 | Dishwashers
HP CLJ 3000
your printer needs servicing
Apr 23, 2008 | HP LaserJet 3000n Printer
Refrigerators Logo
47 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
