Question about Pacific Digital MemoryVue MV-800 Digital Picture Frame
Digital picture frame does not light up - Pacific Digital MemoryVue MV-800 Digital Picture Frame
Screen shows light with crack, cannot turn off
Internal defect needs factory service. Module inside needs replacing and you cannot do that.
Mar 25, 2014 | PANDIGITAL 7-Inch Digital Photo Frame with...
The picture frame still scrolls pictures but the pictures are very dark and unable to be seen well. Is the frame ruined?
Hi, Don't put screen in direct sun light or bright light. Bright lights will destroy LCD screen. The LCD screen has some adjustments on back. You might be able to readjust picture brightness.
Good luck.
Jun 10, 2011 | SmartParts (1DPFSP01) Digital Picture...
How to reset a smartparts digital frame
The tip of disabling the light sensor worked like a charm. Thanks a lot mhg8!
Jun 18, 2010 | SmartParts SPX8 Digital Picture Frame
My didgital frame will not turn on. ADS-18H-4 0918G
My didgital fram will not turn on. ADS-18H-4 0918G switching adapter does have a slowly pulsing green light. But will not turn on the picture frame. Where can I get a replacement or how do i get it to work
Mar 22, 2010 | SmartParts SP15MW (092566981886) Digital...
When I turn the power on, the red light close to the DC power input comes on and the picture frame flashes very quickly but it does not come on. Is LCD out?
Try to see if there is a reset switch on the frame. This is usually a small hole on the back of the frame that a paperclip can be inserted into.
Feb 27, 2010 | Westinghouse DPF-1411 Digital Picture...
Kodak EasyShare EX1011 Digital Picture Frame
Probably a loose cable or a problem with the circuits
Oct 18, 2009 | Kodak EasyShare EX1011 Digital Picture...
How to repair a digital picture frame
My photo frame comes on but the blue light on the side flashes when it stops it says Please wait on the frame and doesn't come of that :(
Anybody know how to fix it??
Thanks
Jul 25, 2009 | Westinghouse DPF-1021 Digital Picture...
Nextar photo frame won't work
Sometimes the memory card contacts develop dirty contacts. Might take a pencil eraser and lightly clean them and try again.
Jan 13, 2009 | Tao MUSIC SPECTARE 5.6 DIGITAL PICTURE...
Digital picture frame wont power back up
Test the power adapter. If the light is flashing, it may not be getting the 12 volts that it needs. You can test it w/ a voltage tester or if you don't have one, take it to Radio Shack and they can test it. If it's dead, or short, replace it and then the frame will work again.
Dec 15, 2008 | SmartParts SP15MW (092566981886) Digital...
Pacific Digital MemoryVue MV-800  Digital Picture Frame Logo
Top Pacific Digital Photography Experts
pontelemon
pontelemon
TC CAMERA REPAIR.Com...
Are you a Pacific Digital Photography Expert? Answer questions, earn points and help others
