Question about Whirlpool Ovens
No temperature dials
Hygena multi turbo
2 Suggested Answers
  • 417 Answers
SOURCE: Replacement knob for Hygena Turbo electric oven
You should be able to get a replacement fairly readily, try www.appliance-parts.co.uk or www.cooker-parts.co.uk.
Posted on Jan 04, 2010
I have an hygena classic built in oven. The turbo cooking option heats up slightly and the fan works but doesn't get to temperature. The grill and convection oven work fine. Any ideas. The oven is about...
The problem is usually down to the thermostat - sometimes it can be moved and end up touching the grill and burning out - other than that they just wear out after time with the heat.
Have a look here for a spare - its easy to replace if your husband is half competent with fixing things.http://www.espares.co.uk
May 11, 2014 | Ovens
Hygena ahy3120 manual
i need a manual for deluxe hygena oven cooker
Feb 20, 2013 | Ovens
Is it dangerest when your oven beeps f2
Typically an oven beeps when the interior temperature macthes the temperature where you set the dial. This is an audible signal to that fact and particularly helpful when you need to pre-heat the oven. For example it you want to cook something at 350 degrees, you set the dial at 350. When your oven reaches that temperature it beeps to let you know. Some cooking directions tell you to preheat your oven. In that case, when you set the dial to 350 and wait for the beep...you know you are safe to start your cooking process because the oven is now pre-heated to the temperature you set. If your recipe requires a pre-heated oven, and you don't wait for the beep, your taking a guess at what temperature you're cooking your food. Additionally, if you want to know what the internal temperature of oven is and your oven is heated...you simply turn you dial setting and listen for the beep. Again, if you set your oven at 350 and you want to know how hot your oven is... slowly turn the dial setting. If the oven beeps at 275 then that's how hot your oven has gotten. To let it finish heating to 350 just reset the dial and wait for the beep.
Jan 13, 2012 | Stoves 600GR Gas Single Oven
The lowest setting on the dial of our Imperial oven is 175 degrees F. If we set the dial below the 175 mark, could we get the oven to level out at a lower temperature? We're looking to achieve a stable...
The temperature figures on the dial are a guide only. Play with the dial, you will pick up where the thermostat cuts in and out. 130 deg. is rather low, but it could be achievable. You will only find out through experimentation - nothing will be damaged.
Jan 31, 2011 | Imperial ICV-1 Turbo-Flow Single Oven
Need a user manual for a Hygena diplomat oven model AHY 3420 any ideas please?
I have a manual for AHY3420, it's a very generic manual which covers different ovens. I am happy to send you a scanned copy if you send me an e-mail address.
I have the same oven and all the symbols have disappeared on the third dial (the one which switches on the oven), so I still haven't worked out which setting does what - I can just about make out a grill symbol, but that's about it. Is there any chance you could tell me what the symbols are on the 3rd dial?
Thanks very much.
Sigrun
Feb 10, 2010 | Ovens
Door hinge on hygena single electric oven broken
You neede to replace both door hinges.
To get more detailed instructions on how to do this, go to the following site.
WWW.YOUTUBE.CO.UK
In the search box enter FITTING OVEN DOOR HINGES.
You should then click on the appropiate link, and follow the instructions.
Please rate my solution.
Thankyou.
Feb 03, 2010 | Ovens
Jan 04, 2010 | Ovens
I DON'T KNOW HOW TO SET THE OVEN TEMPERATURE.
Normally you just turn the dial to the required temperature as indicated on the dial.
Usually the oven dial will say 'main oven' or have a symbol indicating which it is.
Sometimes it is a digital display and you have to press a button until the required temperature is displayed.
Dec 22, 2009 | Kenmore Ovens
My Whirlpool oven no longer heats to the set temperature.
Temp probe/thermometer inside oven dirty, or off attachment, or defective. On some models, a small screw head adjustment is provided to calibrate thermometer under dial knob. Else, I would just set dial 50 degrees higher rather than expense of new thermometer or dial.
Mar 02, 2009 | Ovens
Ovens Logo
13 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
