Question about Sony DSBK-1803 i.LINK/DV I/O Board for DSR-1800/1600 DSBK1803
Frame accurate I.link firewire export to tape DV/DVCAM
We are using a sony DSR-1800 with an I.link / firewire board.
On a adobe premiere CS3 windows machine.
Now we try to make a frame accurate edit at say 00:03:00:00.
Does anybody know the correct settings for this? We can't seem to make it happen.
We set the DSR TC at preset / regenerate, black the tape to 00:03:10:00 and then assemble edit in export to tape.
If we change the pre-roll settings, nothing different seems to happen. Strange?
Also only assemble edit is possible? Not the insert edits?
Any ideas?
Thank you for your time,
Steve Pittoors
I have the same problem.
Posted on Jan 08, 2008
DSR-1800A DVcam TAPE EJECT ERROR 21
This error means the reel position motor is not moving the reels either together for mini DV or appart for large tapes. Usually because the sliders or gears have run out of lubrication and have seized due to not being serviced periodically. Otherwise there may be a foreign object stuck in there like a torn label etc.
Try a different size cassette tape, it may be ok on large if you are trying small or vice-versa, because it is already in that position.
Jul 12, 2012 | Sony DSR-1800 DV/Mini DV VCR
Error 91-455 show in sony dsr-1800p dvcam get a service manualfor this model. pleas.
Error 91:455 i means: Communication error between servo main and servo sub microprocessors.Dose it take the tape in?if can tell me more.mail me in Pemring@gmail.com
Nov 26, 2010 | Sony DSR-1800 DV/Mini DV VCR
DSR 11 won't record DV tape to its end
You need to use longer tapes. The DER-11 is a DVCAM deck which when recording, uses a faster tape speed then mini DV. Think of your older VCR's. They had SP, two hours, and EP or SLP, which would be six hours. The SP speed would give a better picture. DVCAM is more like an SP recording except digital and a lot better. More information is laid down on the tape.
You'll have to jump up to the full size DVCAM tapes in order to record the full hour.
Apr 10, 2009 | Sony DSR-11 DV / Mini DV VCR
Sony DSR-1800
these errors mean the folowing:
02-291: failed to complete winding a tape.
02-275: detected T reel FG during threading.
02-696: Detected abnormal detectiion of S and T reel rotation during play and Rec.
The second and third faults indicate a fault with the board containing the driver for the reel motors. Unless you have the service manual i suggest you buy and replace the board.
It is the DR-428 board.
good luck
Luwangula
Apr 08, 2009 | Sony DSR-1800 DV/Mini DV VCR
Dvcam dsr 45 firewire problem
if you can use your computer and cable firewire for other device. it means that your ic firewire in your dsr 45 is defect/broken,if you want to capture without firewire dsr45 , you need video and aodio in card for your computer.note ic firewire easy to defect/ broken if you plug/ uplug it when the device and the cumputer are on.
Aug 26, 2008 | Sony Dvcam DSR-PD170 DV Digital Camcorder
Import dv-cam via camcorder to pc - which software?
try to download or use ulead movie maker or nero movie maker and install it to your pc. its easy to use, save it to your computer and return the camera that youve rented. you can change the quality of your choice. im using ulead and nero as my editing and movie making. burn it to nero just like a pro :) im not familiar with the firewire because im using usb only. but i think theres no problem about it. hope that helps
CHARCOIS
Jul 23, 2008 | Sony Dvcam DSR-PD170 DV Digital Camcorder
DSR-1800 Lost Lock
This error 07.042 means Detected the abnormal capstan speed.here what u have to do go to maintanence menu.and check the capstan speed
Sep 28, 2007 | Sony DSR-1800 DV/Mini DV VCR
Sony DSR-1800 Lost Lock
check the condition of the pinch roller. a bad pinch roller can cause this problem - a tape plays for several minutes, then has problems. what happens is the tape slowly moves up or down on the roller instead of traveling in a straight path. this is caused by the roller becoming worn or glazed and not being able to provide traction to pull the tape through.
Sep 24, 2007 | Sony DSR-1800 DV/Mini DV VCR
Televison & Video Logo
156 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
