Question about Refrigerators
Kenmore Elite Freezer model #25324092102 how to change temp from celsius to fahrenheit
    Prodigy:
    An expert who has answered 500 questions.
  • Refrigerators Expert
  • 650 Answers
Have you tried the Sears website searspartsdirect.com. you should be able to download the users manual and it should give you the procedure
Posted on Apr 13, 2014
catriver
  • 878 Answers
SOURCE: changing panel from fahrenheit to celsius
Dawn, press the refrigerator key and freezer key together for 5 seconds. It should toggle between them. Catriver.
Posted on Dec 25, 2007
SOURCE: kenmore elite refrigerator, model # 59676534500
I went ahead and signed up for Sears' service warranty since I knew I had to get someone to come out.  IT costs $200/yr.  They say it covers everything, but when the technician came out, he told me that it just covers $500 per visit.  He said that a new motherboard and the labor alone was going to make it $498.  Anyway,   he had ordered a new motherboard. Apparently the motherboard wasn't working.  It is located in the back bottom left side of the refrigerator behind the panel.  There is a compartment on the lefthand side that slides out and houses the motherboard.  He put that in and also had to fix the fan that is in the back of the freezer.  That fan is the one that sends cool air up to the refrigerator part. When I had looked at the fan before the repair man came, it was not moving at all.  So at least take a look at the fan in the freezer.  Just take out the freezer drawers, and the fan is located in the top center of the freezer behind the compartment cover.  Maybe that's the problem with your refrigerator, the fan.  Hope that's all it is. Good luck!
Posted on Jun 25, 2008
SOURCE: I have a frigidaire sisde
Success!! I just bought a Frigidaire Gallery series side by side model # GLHS39EPJW0, in Canada. My temp readout was in F and I would like Celcius. The hidden button between the readouts I could feel, but it didn't work. However, holding the Fridge readout "up" and then pushing the Freezer readout "up" three times switched me from F to C on the fridge side. I repeated this but pushed the freezer "up" twice and the freezer readout changed to C. Thanks for the info - it helped out when Frigidaire couldn't.
Eden in Canada
Posted on Aug 09, 2008
SOURCE: Kenmore Elite bottom freezer refridgerator
I just went through this with my refridgerator and actually posted one of the questions. Here is what I found ........
In the freezer compartment behind the panel there is an evaporator fan which pulls cold air from the freezer and pushes it up into the refrridgerator compartment. If the fan is not working it is one of three things.. 1) there is so much frost in the fan area the fan blade is stopped and cannot push the cold air into the refridgerator compartment or the air channel is blocked. 2) there is no electricity going to the fan (usually tied to the door switch of the refirdgerator compartment, and 3) the motor is dead and will have to be replaced.
Solution to #1 - defrost but there is another problem in the "frost-free" part of the system which must be addressed or the frost will return and it will happen again in the future.
Solution #2 - check to see there is power to the fan. (most are 110VAC but some are 100VDC. Use a meter and check)
Solution #3 - If there is power, the motor is dead. Replace the motor. Be aware that AC and DC motors are different and replace per manufacture's specifications.
Posted on Nov 23, 2008
blueextc3221
  • 15935 Answers
SOURCE: Temp control is displaying Er and FF code
This is an error code that pertains to the evaporator motor but could also be the main board.
If the evaporator motor is running, the main board will probably need to be replaced.
It could be a wiring problem but it's not very likely.
If the motor is not running, some voltage checks will need to be made, at the motor and board, to determine which component has failed.
These checks require a meter and can be difficult to make, even for a technician.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 25, 2010
Change celsius to fahrenheit
Hello deskds - To change Celsius to Fahrenheit for the model number posted above, press and hold the Fresh Food up arrow while at the same time pressing the Freezer up arrow three times in five seconds.
Mar 16, 2013 | Frigidaire Professional Series PHS68EJSB...
Subzero 850 freezer temp reads minus 20 degrees
Is it possible your unit is set to celsius rather than fahrenheit? I ran the -20c though a converter and is this is true your unit is running at -4 degrees fahrenheit and this would be a little cold but ok at this temperature. I would personally check settings before going further in to any repair. I was reaching the model you gave me and found the number you gave was incorrect. But try this; turn the whole unit off for a couple of minutes. Turn it back on, then push and hold the alarm and unit power button for 5 sec. this can only be done within the first 5 minutes of power up. This should confirm your display setting is correct, I am assuming you want fahrenheit rather then celsius. If this doesn't work for you, I will need to confirm model number so I can send you a digital version of the service manual if you need it.
Good Luck
Oct 15, 2011 | Sub-Zero 650 / O Bottom Freezer...
The freezer on my Kenmore Elite Trio has stopped freezing. All my food is thawing. How do I set the freezer temperture at the coldest setting?
If the temperature is the problem this could be the solution
Problems with Temperature
If the refrigerator or freezer is not cooling properly, check temperature settings and air vents and ensure there is adequate room for proper airflow. Factory-recommended temperature settings are 0 degrees Fahrenheit (-18 degrees Celsius) for the refrigerator; and 37 degrees Fahrenheit (3 degrees Celsius) for the freezer.
If you need to adjust the temperature, do it one degree at a time and wait 24 hours before making additional adjustments. Check the air vents and make sure nothing is blocking them. Finally, if your refrigerator or freezer is too full, there will not be adequate room for air to circulate and cool properly. If these all check out, the problem could be with one or more compressor components and will require professional repair.
Hope this will help you.
Thanks for using FixYa : )
Sep 08, 2011 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
Hi my name is veronica my problem of my kenmore elite refrigertor is not cold enought...i want to know what is the tempertaure that need to be on
Have a nice day : )
Sep 05, 2011 | Refrigerators
How to change celceuis to fahrenheit ?
Convert Fahrenheit to Celsius
Tc = (5/9)*(Tf-32)
Convert Celsius to Fahrenheit
Tf = (9/5)*Tc+32
where Tc is Temp in Celsius and Tf is temp in fahrenheit
Aug 18, 2010 | Hyundai Motor 2004 Sonata
What is ideal freezer temp setting ?
dear sir /madam
the ideal freezer temperature is 0 fahrenheit(-18 celsius) for storing food. and - 10 fahrenheit (-23 celsius) is recommend when freezing food.
and generally 3 to 5 celsius (37 to 41 fahrenheit) is ideal for refrigerator
hope answer the question
thank you
please vote!
Aug 17, 2010 | Frigidaire 14.1 cu. ft. Upright Freezer...
How to set temp in the freezer box
dear sir/madam
please find out temperature control switch on control panel then make it on ideal setting. for freezer 0 Fahrenheit (-18 celsius) for storing food and -10 fahrenheit (-23 celsius) is recommend when freezing food. please set on ideal setting.
thank you
please vote!
Aug 13, 2010 | Traulsen 24.2 cu. ft. / 685 liter...
Change from celsius to fahrenheit
You can switch the temperature mode between Fahrenheit to Celsius as follows:
While depressing the AUTO button, depress the OFF button for 3 seconds or more. The display will change from Fahrenheit to Celsius, or from Celsius to Fahrenheit."
Jun 02, 2009 | 2003 Kia Sorento
Refrigerators Logo
124 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
