Blue stays on TV will not turn on?
Ive tried the back switch unplugging. I did use a hair dryer to warm the back of TV and that's how I got the blue light on!
    Top Expert:
  • Televison & ... Master
  • 74,136 Answers
Sounds like a main board fault. Contact any service technician.
Gopakumar Gopalan Google
Posted on Apr 02, 2014
Creda tvr 2
hi if you are looking at back of dryer take the left side panel off u will see the heater wires coming through the back orange and blue wires go to a plug close to motor unplug the plug try your dryer see if it trips then if not take heater off the back check to see if elements are still nice and straight so they dont catch the back ive seen bra wires allso go through back of drum which will short unplug will u disconect it then try
Jan 01, 2014 | Hotpoint Dryers
Blue light turns on but tv screen stays blank
The blue light indicates power is getting to your TV but there may have been failure of the internal power supply
Jul 07, 2013 | Sceptre Televison & Video
Ce32ld33 tv sanyo turns on stays on for couple hours then turns off and stays off until an hour or 2 then switches on .i try to switch it on after about 20 mins but the little blue standby light goes...
There is a high possibility that the components over a period of heating and cooling, tend to bring on a problem of dry soldering. So my advice is to check the set for some loose joints that have played on to give you these erratic shut downs or poor performance. The best way to check for loose connections is to tap lightly when the set is powered on, if there is change while tapping then it seems that there are DRY solder joints. Remove main plug, the covers - with caution of high voltage, check for dry joints, and use a good soldering iron to solder all suspected points. Sometimes the fault occurs when the set warms up; if so you can simulate the heat using a hair dryer on the suspected areas, try with the power supply, distribution, Processor controller, driver controllers on the A/V related sections. Also the use a FREEZE-IT spray can simulate the components to cool and show up the fault. It can also be related to WEAK ELECTROLYTIC capacitors as the value can reduce in time.
Oct 04, 2011 | Sanyo Televison & Video
I need to turn on&off the tv
1.) Unplug the TV, and hold in the power button while plugging it back in, this will reset the TV, and sometimes it comes on.
2.) Just warm the back of the TV with a hair dryer for 5-7 mins after you have unplugged the TV. Look for the little areas of holes in the back panel of TV. Use these as your guide at where to use hairdryer., but don't hold the dryer too close(say 5-6inches away). (Make sure the dryer is on High heat). If the TV doesn't turn on after you have heated it up (like it tries to come on but then turns off) you need to unplug the TV again, this resets it. And repeat those steps till it works. Reseting the TV after it fails to turn on is the key. Also, just leave the TV on. Don't turn in off.
Mar 03, 2011 | Insignia IS-LCDTV32 32 in. Television
LG 20LS7D TV
1. Try this - hold the menu button down for 10 seconds. TV should power up; you will have to turn off front panel buttons on menu.
2. You can also try a hard reset: Unplug TV from AC mains and remove all cables from TV. Wait about 30 minutes and replug to AC power and redo the cabling. Switch on the TV and see if it works..
3. Powering down the set or putting it in standby may have allowed the power supply to cool. Weak capacitors often go out of spec when they cool, thus preventing a section of the power supply from firing up properly again. There is a simple trick...just warm the back of the TV with a hair dryer for 5-7 mins after you have unplugged the TV. Look for the little areas of holes in the back panel of TV. Use these as your guide at where to use the hairdryer, but don't hold the dryer too close (say 5-6inches away). (Make sure the dryer is on High heat). If the TV doesn't turn on after you have heated it up (like it tries to come on but then turns off) you need to unplug the TV again, this resets it. And repeat those steps till it works. Resetting the TV after it fails to turn on is the key.
then the fly back unit is failed you need to resolder the contacts or get it serviced...............
Jun 08, 2008 | LG RE-20LA70 20 in. Analog TV LCD...
5071HD switch, power supply problem??
Pioneer recommended a firmware upgrade for the repeating twelve blue led blinking and remote issue you specifed.
Feb 29, 2008 | Pioneer PDP-5071HD 50 in. Plasma HDTV
42PF9956/37 SHUTSDOWN...
Ok. I got my tv back on.
I pulled off the back cover and found the relay that was clicking.
I have two blue relays next to each other that click when the power is pushed.
I placed a hair dryer over the relays for about a minute.
Once heated up, it only took 4 tries to get the TV to stay on.
Jan 03, 2008 | Philips 42PF9956 42 in. HD-Ready Plasma...
Insignia lcd tv 32"
have good tec replace if nessary, The inverter module
Mar 03, 2007 | Insignia IS-LCDTV32 32 in. Television
Toshiba 42wt29b. screen keeps turning blue
MMMM Hard call here. The fact that it does try to come on blue maybe an indication that the power supply regulator circuit is good. It could also be a shorted blue tube and when it comes on its overloading the screen drive and the set goes into overload protection shutdown. The real way to see Would be to pull off the blue crt socket as well as the Hi Voltage lead on the crt and see if the set comes on without blue. If it does Your gonna need a pict tube. If it dosent then troubleshooting along the switched power supplys would be neccassary.. BUT I advise you THAT IF YOU HAVE NO EXPERIENCE TROUBLESHOOTING TV SETS PLEASE SEEK A PRO TO ASSIST YOU AS THERES VERY HIGH VOLTAGE INSIDE THESE SETS EVEN IF THEY ARE UNPLUGGED. GOOD LUCK
Jun 28, 2006 | Toshiba 42H83 42" Rear Projection...
Televison & Video Logo
14 people viewed this question
Top Televison & Video Experts
Electro Med Services...
