Question about Brother MFC-8860DN Printer
8860dm how do i replace laser
Replace laser message several months
  • Brother Master
  • 783 Answers
HI RSHC,
Please watch this video
Hope It's resolve all Your Printer Problem,
Or Still having Problem Then follow Us For Brother Printer Support
Posted on Apr 01, 2014
My new pls5 laser will not light when turned on. It's only 4 months old. Never dropped or even wet. Anyone else have this problem? And can I fix it?
In my experience, on PLS found several times the power button defective after few weeks/months (especially if You work in construction sites ).
The ultimate fix is new power button (not replace the old one!) in a convenient position. I have fix several PLS3:
25648370-ud5esjubpx2k2ouh2wsyjwog-2-0.jpg Notice: if You open your PLS5, You have to break the lateral sticker and the warranty will be void!! Keep this in mind!!
Bye!
Apr 15, 2015 | Pacific Laser Systems PLS-2 Palm Laser,...
Cx 300 won't read cd it says no disc after i replaced optical laser lens
Mine did the same thing after being out of service for several months. I fired it up, ran beautifully for 6mos. Or so, then the "no disc" message appeared. The local I took it to said buy a new one...cheaper than fixing it. Sorry.
Apr 24, 2014 | Sony CDP-CX300 CD Player
I have samsung scx 4300 laser printer and after refill it show the message "toner exausted" but there is no chip on the cartridge. plz help me how to reset the chip inside and fix the problem.
This is a link to view how to reset: http://www.youtube.com/watch?v=Qzc9JImUcak
This is a link to download firmwares (version 1.13, 1.16, and 1.18_fix) and download software to update firmware files to printer: http://dox.abv.bg/files/listtree
MOST IMPORTANT:
1. Push 8 times button MENU then OK to print a report and view your version of firmware
2. REPLACE FIRMWARE VERSION 1.13 ONLY WITH 1.13_fix
3. REPLACE FIRMWARE VERSION 1.16 ONLY WITH 1.16_fix
4. REPLACE FIRMWARE VERSION 1.18 ONLY WITH 1.18_fix
5. REPLACE FIRMWARE VERSION 1.21 ONLY WITH 1.18_fix
6. DO NOT REPLACE FIRMWARE VERSION 1.23, I DON'T HAVE FIRMWARE VERSION 1.23
IF YOU REPLACE FIRMWARE VERSION WITH WRONG VERSION A "SCANNER ERROR" OCCURS AFTER SEVERAL MONTHS WHICH MEANS YOUR SCANNER MATRIX IS BURNED OUT AND MUST BE REPLACED
GOOD LUCK!
Jan 24, 2011 | Samsung SCX-4300 Monochrome Laser...
Printer keeps saying to clean the corona wire. I cleaned it several times but the message keeps popping up.
To clean the corona wire in the brother laser printer, it said to remove the drum/toner assembly from the printer. This is very easy to do, you simply pull down the front of the printer, and press a small green tab down and pull. Then the toner and drum assembly will quickly come out.
After that, it says you must clean the corona wire by moving a small green square back and forth several times. It seemed kind of strange to me, but I did it anyways. In the upper right corner of the drum/toner assembly, there is a small green/blue square that can be moved back and forth. I did this several times.
I then placed the unit inside, and the error message went away for a minute. However it still wouldn't print and the error message came right back up. I was a bit frustrated since I have only owned this printer for about 2-3 months.
But then I realized something: The toner button had been blinking for about a month. I had already purchased a high yield black toner cartridge for the brother laser printer (Tn-330/TN360). I purchased it online, and had it stored for when I eventually ran out of toner.
I thought perhaps the error message had something to do with the old toner. Maybe it was out?? So I once again opened the front of the laser printer, and removed the toner/drum assembly. I pressed a green tab, removed the old toner, and then added the brand new high yield black laser toner cartridge. The whole process was very simple (you gotta love today's technology).
I then quickly "cleaned the corona wire" a few times again just to be safe. I re-installed the toner, and the printer was up and running. So apparently it will throw this error when you are out of toner. Now the printer is running great again, and I really like this printer.
If you are still using an ink jet printer, then you are living in the stone age. I was reluctant to buy a new laser printer, but now I love it. The toner only costs $30-60 and lasts for months. I print hundreds of labels out each month-just to give you an idea of how long it lasts.or get more information Call +877 889 6859 for detail.
Jan 04, 2011 | Brother HL-4040CN Laser Printer
After flashing and reseting with v1.13 firmware,samsung scx 4300 scanner error shown on lcd.
Oct 01, 2010 | Samsung SCX-4300 Monochrome Laser...
Won't print black and white
This happend with some printer models that both cartirdge should be there for proper printing.in your case this may be due to that some printing you do may be in gray scale printing that type of printing use color cartridge for printing.thats why your color cartridge get consumed.so pls replace color cartridge or refiel it.
Aug 17, 2009 | Lexmark C530dn Laser Printer
Replace Paper Tray Message won't clear
On the right side of the tray, there are 3 rectangular holes. The "plug" goes in the top hole but, if it came out, it probably won't stay in. I've taped a piece of sheet metal in the hold before to get by. You can buy the part for a few bucks from xerox or inktechnologies. There is a lot of pressure on this plug so it takes something pretty strong to hold.
Mar 12, 2009 | Xerox Phaser 6115MFP/N Laser Printer
On my DMR-ES35 Panasonic after perfect operation for 18 months, I'm getting a NO READ message, on disks already recorded on this unit,and several new disks of different makes. The main sympton now is
Same problem. "NoREAD" after about 15 months of moderate usage. Cleaned laser eye thoroughly. Solution is a class action lawsuit against Panasonic.
Jan 21, 2008 | Panasonic DMR-ES35VS
Brother MFC-8860DN Printer Logo
22 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
