Question about Royal 29043x Alpha 1000 Ml Cash Register
Royal alpha 1000ml
I was doing monthly report an ran out of paper so when i put new roll in wont print ink on paper
    Master:
  • 415 Answers
That has a thermal printer.. did you buy thermal paper? Did you insert it in the correct direction?
Posted on Apr 13, 2014
2 Suggested Answers
Electroboy
  • 1648 Answers
SOURCE: royal 1000ml user manual
This one is the full operation and programming manual.
It can help you to program date, time, receipt, tax, departments, reports and more
http://the-checkout-tech.com/manuals/cashregisters/Royal_Alpha-1000ML_operation_and_programming_manual.html
Posted on Dec 05, 2012
How do i change the print size on my register
Edit>Preferences>quicken preferences>register and then click on Fonts
May 06, 2016 | Royal Alpha 1000ML Cash Register
How clear memory royal 1000ml cashier
In order to clear the memory of a Royal 1000ml cash register, you would do the following:
1. First turn off the cash register without unplugging it and slide the control switch to the "off" position.
2. Open and remove the printer cover and put it to the side. Take out the paper roll and put it to the side as well. Open and remove the battery compartment cover and set it to the side.
3. Notice where the batteries are in the slots and note the orientation of the batteries, such as the positive and negative marks and then pull out the batteries.
4. Now unplug the cash register and wait at least 20 minutes to plug it in again. Slide the control switch to either the R1 or R2 position.
5. Put the batteries back as they were before and put back the battery cover, along with the paper roll and printer cover.
6. Select a mode using the control switch and then reprogram the register as needed with your settings.
May 23, 2015 | Retail Supplies
Royal cash register Alpha 1000ml electronic journal cleared
Royal don't tend to give out this info. and this model is rare to find. You will need the code for Journal clearing. I've found that it varies too much between registers to guess it by other ones. For the royal machines, I usually just send customers to buy the manual from the supplier. There is also a PDF manual on the net if you need one quickly:
https://the-checkout-tech.com/manuals/cashregisters/Royal_Alpha-1000ML_operation_and_programming_manual.html
Sorry I can't help further with this model
May 09, 2015 | Royal Alpha 1000ML Cash Register
What does sec,next code mean
The 1000ML is quite rare. Royal don't give out this info. I ended up sending my last few customers to this site:
Hope it helps.
Apr 28, 2015 | Royal Alpha 1000ML Cash Register
Light printing
Go to print option and select print-density and increase it
Mar 30, 2014 | Royal Alpha 1000ML Cash Register
Royal alpha 1000ml
Make sure you are using the right paper
Jan 08, 2014 | Retail Supplies
How do i install ink cartridge in royal alpha 1000ml
There is NO ink in your cash register.
Your cash register has a thermal printer that prints receipts for the
customer or a journal tape. Use 2¼ inch (57.5 mm) wide standard thermal register paper. Do not use bond paper because the register does not use a ribbon or ink for printing.
See installing paper roll on page 13 of the manual
Royal 1000ML Instruction Manual
Nov 24, 2013 | Royal Office Equipment & Supplies
Is the BATCH CLOSE report only for that day or is it everything you have rung up?
By default it is only for that day but you can still go to system options and select othewise
Sep 23, 2013 | Royal Alpha 1000ML Cash Register
Receipt won't print on royal alpha 1000ml
Make sure you use thermal paper and no other kind.
May 12, 2012 | Royal 29043x Alpha 1000 Ml Cash Register
Royal 29043x Alpha 1000 Ml Cash Register Logo
133 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Michael Vincent Cruz
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
