Question about Troy Garden
Fuel line size for troy built TB20CS weed eater
I cant find this info in the manual anywhere. Does anyone know what size the fuel line for troy built weed trimmer? I purchased the 3/32'' x 3/16'' and it the fuel just pours out now.
You probably have found the solution by now I would assume... TB won't tell you this because they want you to buy their stuff..
You probably are looking at the 0.08" diameter that's just a bit smaller than the 3/32". Hope this helps....
Posted on Apr 09, 2010
Show fuel line routing on weed eater by troy built.
Many Parts manuals don't show the actual fuel line routing.. The pipes have to go from the tank to the carb or primer bulb, generally a direct route without being trapped or rubbing. If you're referring to what pipes go to which part, then that's another question I could answer if asked. Thank you
May 15, 2016 | Troy Garden
Troy built 90bc weed eater will not prime after new fuel lines
Could there be the possibility that the lines may of been put on the wrong way i would try swap them around first, also the primer bulbs do not like air make sure all the fuel lines are all on tight and that there is heaps of fuel in the tank
Jul 30, 2014 | Garden
Troy built trimmer fuel lines
normally the one nearest to fuel pump /primeer bulb is the inlet and the lower one is return
WHY can't you just connect hose to one and pump primer bulb to see what direction it goes ?
Jul 28, 2014 | Troy Bilt Tb20cs 2 Cycle 31cc Gas String...
Troy bilt weed eater
I have a troy built 2 cycle pro-line tb90bc spring assist trimer.
its getting fuel and it wouldn't start I took out the spark plug and it was wet with fuel. pls fwd any info to ss.beepat@hotmail.com
May 06, 2013 | Troy-Bilt Tb90bc 17-inch 31cc 2-cycle Gas...
Troy-Bilt weed eater, Model TB90BC, had rotten fuel lines and primer bulb, I replaced but may have hooked them up wrong. How do I hook them up?
Prime and watch the fuel move up to the carb. This is the fuel line and it should be long. Make sure it goes to the bottom of the fuel tank.
Apr 04, 2010 | Troy -Bilt String Trimmer/Blower...
Troy built weed eater won't feed line
Check the size of the line,(OD), make sure you are using the correct size, sometimes cheap line will be problematic, also, you said you are re-stringing it, try a new batch of string, the old string inside the hub can get chaffed and will stick to itself...
Aug 22, 2009 | Troy Bilt Tb70ss Gas Trimmer
TB20CS gas trimmer, primmer bubble won't pull in gas
The carburator has a sereis of one way check valves that get cloged very easily.
If you remove the carburator and clean it out with a simple cleaning solution you should be able to clean it up.Do not use compressed air.
Aug 03, 2009 | Troy Bilt 17 Inch 29 Cc Gas Powered...
Tryingto replace my troy built weed eater's head
Replacement head can be purchased from amazon, here Amazon com troy built head. I hope this helped you. Have a nice day. Vince
Jul 12, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
My Troy Built weed eater wont keep string going.
troy built is pure trash ill never waste money on any of thier trash agin i have a weed eater 5 months old it wont even crank pure china trash
May 09, 2009 | Troy Bilt Tb70ss Gas Trimmer
Fuel hoses routed wrong on weed eater fuel tank
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=358795190&productCategoryId=1503820&brandId=0247&modelName=TRIMMER&diagramPageId=00002&componentDescription=CYLINDER/FAN%20HOUSING/CRANKCASE&documentId=P0303202&backToLink=Return%20to%20Sub%20Components%20list
Apr 04, 2009 | Garden
Garden Logo
1,265 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
