Question about Samsung HCM4215W 42" Rear Projection Television
The sound is fading from my samsung projection tv
Bought in 2005
2 Suggested Answers
  • 1583 Answers
SOURCE: I have a Samsung rear projection 42in. tv, the
This is evidently a CRT-type projector TV (the owner's manual provides a convergence procedure and warns against operating the set near magnetic field sources - these distort the picture in CRT displays - but has no mention of changing lamps as used in other types). The first thing to check is whether the CRT coolant fluid has discolored with age or algae contamination. This can be determined by visual inspection of the top of each picture tube.
Inspection procedure
CAUTION: there are potentially lethal voltages present inside the set, even it when it is turned off. Some components, including the picture tubes, can hold a charge for a time after the set is unplugged, and some parts can be ruined by static discharge from your fingers even if the shock is too small for you to feel it. Bottom line: don't touch the circuitry unless you know what you are doing.
First, unplug the set, and remove the back. Look for the three picture tubes (sometimes called "jugs" or "cannons") pointing up towards the curved and faceted mirror in the upper section of the set. These are usually mounted on a horizontal black-painted board or panel above the electronics. At the top of each tube is a lens about 7" across. Through the lens you will see a red, green or blue colored face. Using a flashlight, look down into each picture tube. If you see a muddy yellow cast to the color, that confirms the problem. If you have trouble identifying the picture tubes, make sure all hands are outside the set, plug it in and turn it on. Look for the red, green and blue light sources, but be careful not to touch anything or put anything metallic inside the set while it is plugged in. (Some Samsung models allow you to remove the entire projector screen assembly - everything above the control panel - as one piece. These are relatively simple to work on for this problem.)
If you need to change the CRT coolant, check the link here. Plan on it as a full weekend (or two) project if you want to do it yourself. An experienced rear projection TV tech could do it more quickly since there would not be so much time spent looking for connectors, attachment points, etc.
Posted on Oct 27, 2010
Cannot figure out how to connect my new sound bar to my older TV
If your TV has audio output connectors (RCA type), you can use them as a source of input to your soundbar. This should be apparent by reviewing the installation instructions that accompanied your soundbar.
Nov 30, 2013 | Mitsubishi WD-62527 62 in. LCD Projection...
Bought Samsung dlp h-l 5667w new in 2005. Replaced lamp, fan, and color wheel in 2008. Now lamp lights up and lamp indicator on front lights up, fans turn on, but tv picture will not show. After a few...
It time to replaced the tv projection lamp again,the tv projection lamp life span have ended.The tv projection lamp life span only last 2000 hrs.Average out like 1 1/2 or 2 years max for tv on watches 4 or 5 hrs of tv every days.
Jul 07, 2011 | Samsung HLR5667W 56" Rear Projection HDTV
Screen on my HL-R5667W DLP is fading from the left
Ur tv have a convergence problems.The 2 STK convergence ICS are defective and dying.The shop will fix this for u about $300-350 for parts and labors.
May 08, 2010 | Samsung HLR5667W 56" Rear Projection HDTV
The color has faded . I replaced the bulb the problem persists!
Light Engine is Bad, If you had said TV was making loud whistling sound then it would be Bad color Wheel
Sep 27, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
48'' Rear projection picture fading
sounds like your color wheel is fading.
Mar 31, 2009 | JVC Televison & Video
Samsung pcn5425r faded blue?
You either need a new Blue CRT or the Blue CRT circuit board. You can get both those parts at the following link for a real cheap price as they have them used which cost a fraction of what they would be new. Leave them a email with your model number and what youre needing they will respond back quickly.
http://servicemanuals.vstore.ca/
Jun 10, 2008 | Samsung PCN5425R 54" Rear Projection...
Samsung HCM4215W 42" Rear Projection Television Logo
16 people viewed this question
Henry  Thomas
Henry Thomas
