Question about Dishwashers
Rangemaster fault finding
Hi my rangemaster dishwasher is coming up with fault e4?
  • Dishwashers Master
  • 3,247 Answers
It is possible the drain hose at the back of dishwasher is kinked or you have lifted it up too high under the kitchen sink.
Assuming you have the buzzer also beeping at the same time. See page 14 on this manual. Not sure if this is your dishwasher model number.
http://www.rangemaster.co.uk/media/1000944/u110142-03-dishwasher-rd6012fi-sf-17-04-13-.pdf
Posted on Apr 05, 2014
3 Suggested Answers
SOURCE: E4 error on new conia dishwasher
I have a Maytag MJD3000AAW dishwasher and it was showing E4 during a cycle. On checking the pressure tube from the outlet of the dishwasher to the nozzle on the u tube under the sink, I fould that the dishwasher was not draining properly as a kink have developed in the tube where it curved back to the nozzle. I slid the pressure tube into a long elbow which stopped the tube from pinching. Problem solved.
Posted on Nov 02, 2008
  • 16 Answers
SOURCE: Kenwood dishwasher KDW12SL3A
Sounds as though the drain is blocked partially. E4 is the overfill code. Try cleaning out the drain.
Posted on Jan 24, 2010
I have e4 showing
E4 error indicate an abnormal water level which means too much inlet water (E5 also is refer at this fault).
I quote other comments/solution about this same error:
I had the e4 error code and i took the outer panel off and inside behind the power button is a grey reservoir tank which measures the water that goes inside the dishwasher which actually got bunged up with **** and grease causing the floaty thing to get jammed and cause the e4 code to come on which means abnormal water level the top to the reservoir just unclips on both sides then just clean all the gooey stuff out and put it back together it worked for me.
Good luck.
May 31, 2011 | Kenwood Dishwashers
I have a gorenje gv60010 dishwasher. it has a flashing e4 fault code which does not let the dishwasher operate. can anyone tell me how to reset it
Well your all brilliant. Point 1. The filer in the bottom of the machine was full of Cra* once I cleaned out the filter, pulled the integrated machine away from the wall and (Point 2) tilted it on its back legs (you were right about the mess - as more water came out) the E4 signal went. Im just trying it now so will come back if the machine doesnt work!! Thanks for the advice!
Mar 06, 2011 | Dishwashers
Belling dishwasher IDW604 error code E4 on control panel
I found the solution myself. Underneath the machine, there is a plate. On the plate, there is a float and a microswitch, when the water leaks onto the bottom plate it raises the float and activates the microswith which shuts down the machine and shows E4 on display. To get rid of the fault, you have to pull out the dishwasher, then tilt it, and drain the water from the bottom plate. Also make sure that there is no leak in the internal piping, if there is, the fault will come back as soon as the recess in the bottom panel fills with water.Hope it helps.
Feb 25, 2010 | Dishwashers
Belling IDW604
Jan 20, 2010 | Belling 24 in. IDW603 Built-in Dishwasher
Error code e4 flashes on belling dishwasher idw604 , washer is empty cant get any programs to work
Dec 27, 2009 | Dishwashers
E4 fault code
Hi, when a dishwasher goes into overfill mode it usually means that the bottom tray has water in it that operates a float connected to a microswitch. Open the bottom panel and soak up all water then check to make sure the float is down completely.then restart dishwasher. Why it has overfilled is another problem. It could be a faulty pressure switch,pressure switch hose may have a hole in it, water valve may be faulty. Too much soap or wrong soap can cause too many suds and hence overfill.Also if rinse aid is spilt when filling. Or seals leaking. etc.
Feb 02, 2009 | Dishwashers
Baumatic BDW13
e4 code means the machine is showing a fault code for overfill,tip the machinee to a 45 degree angle and get excess water out should run ok after that
Aug 13, 2008 | Baumatic 23 in. BDW13 Built-in Dishwasher
Aug 07, 2008 | Dishwashers
I have a kenwood KDW12SL3A. The Drain got blocked at the dishwasher end, and I have now unblocked and tested the drainage but have still got an E4 error come up. how do I reset this?
Just got one of those at weekend and had e4 code-looked up on here and gor tis solutionwhich sems to work!
To clear the fault you need to remove the two baskets from the dishwasher.
Slide it out from under the worktop and lean it forward to about 45 degrees.
If it is already full of water, turn on the power whilst pushing the programme button, this sets up a pump out program
Jun 23, 2008 | Dishwashers
Kenwood Slimline Dishwasher KDW8ST2A
I have a Kenwood Kdw8st2a and have been constantly plagued by the E4 overfill error.
Lifting the front of the dishwasher and tilting it backwards seemed to clear the E4 error only for it to come back after the next wash.
I found eventually that the connection to the U bend under the sink was too narrow and was almost blocked hence the dishwasher was not emptying properly.
I disconnected the dishwasher waste pipe and ran the waste into a bucket for about 6 cycles and it worked fine.
Eventually drilled through the kitchen wall and fitted a lower direct waste pipe to the drain. Overkill maybe buit it hasn't done an E4 since.
May 21, 2008 | Dishwashers
Dishwashers Logo
205 people viewed this question
Top Dishwashers Experts
