Question about HP dvd740i DVD±RW Dual Layer Burner
How to fix a hp dvd740 that sat for awhile after a pop was spilled on it. I need to know how to set the internal adjustments
It had a pop spilled on it and sat for long time i took it apart to clean the sticky off. i want a diagram of how one works
    Sergeant:
  • 376 Answers
You need to stay away from adjustments as that will render it completely useless. Concentrate on cleaning the goo out of the drive (especially from around the drive motor and lense) and retest.
Posted on Jul 04, 2014
2 Suggested Answers
SOURCE: i have a hp dvd740 problem
Ill try it thank you.
Posted on Feb 12, 2008
WHY DOES MY CRAFTSMAN BRIGGS POP LOUD WHEN I TRY TO START IT. iT WONT START NOW
sounds like you need to adjust the valves. do a google search with your engine model number and "valve adjustment".
Jun 14, 2014 | Craftsman 20 hp 42 in. Deck Yard Tractor
HP dvd740x manual
HP link at bottom should take you to Hp's dvd740 manual page. If it doesn't, here is the actual address.
http://support.hp.com/us-en/product/HP-Brand-License-DVD-Writer-dvd700-series/502027/model/502025/manuals
HP Support
Apr 08, 2014 | HP Computers & Internet
Hp pavillion 9700 had pop spilled on it and need to replace motherboard, is that all I need to replace or do other elements need to be replaced as well. thanks
It depends on how much "pop" you spilled on it. If it wasn't much you might be able to just repair the liquid damage. I would suggest you have a local laptop tech check it out. The key to getting your machine fixed on the cheap is finding a tech that specializes in laptop repair.
DV9700 motherboards aren't cheap btw and if you're not familiar with fixing laptops I wouldn't recommend you trying to swap a motherboard out, it's not for the average user.
Dec 31, 2010 | HP Pavilion dv9000z Notebook
Auto adjustment in progress popping up and
Right click on your desktop, go to properties, and navigate to the settings tab. There, try to set the monitors resolution to the largest available. That should fix your problem. If it doesn't just try some other resolutions until ou find one that works. I hope this helps, Yannick.
Jun 09, 2009 | HP w1907 LCD Monitor
1995 Ford vdan rear passenger door won't open (unlocked).
I just delt with this situation myself. I don't know if this is the same solution, but I had the same problem. If you take the panel off the door, you can probably push the rod that opens the door by hand. it's likely the handle isn't engaging the rod enough to open it. if that's true, just pop out the plastic bushing and screw it out (toward the front of the vehicle). Also, you probably want to lube up the latching mechanism. I had to actually cut a hole in the door to get mine to open (had sat for a couple of years). These handles just need adjusted after awhile.
May 11, 2009 | 1995 Ford Aerostar
My hp officejet 9130 will not print in color.
Try runing the printer test and see if colors print. If they don't your color cartridge is cloged. You can try to set the print head(copper strip on bottom of cartridge) on a damp paper towel for a while to try and unclog the head. You should see the colors on the towel. Dry head off and try again. Hp uses water base ink and it will dry up after setting for awhile. The printer knows it has ink in the cartridge, because it will try to print, so it has to be the print head.
The print head has two lines of holes or jet for each color and if some of them are cloged, it will look striped or missing colors.
Mar 05, 2009 | HP OfficeJet 9130 All-In-One Thermal...
Hp zv5346us audio problem
Try to look for the sound icon in your task bar. select properties then try to check options then select all settings that are supposedly running in your system uncheck those settings that are set to mute then adjust the volume lever to higher level.ex. Right Click sound icon,-open volume control, When volume controls appear click on the properties,-then select all settings that you might be using then close the volume control panel. then try to run again. if possible it needs restart to take effect the new settings.
Oct 08, 2008 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
I have a hp dvd740 problem
It would sound like a buffer under run issue, in plain engluish set your drive to record at a SLOWER ( MUCH ) rate and see if you still have the problem also you need to use GOOD quality media, cheap disks act like cheap disks buy good dvd r
Feb 11, 2008 | HP EXT DVD BURN HP|DVD740E LS BK R...
Hp dvd740
try downloading this dvd player you can test drive it fro 20days for free it writes rewrites and reads any dvd or cdrw's www.slysoft.com
lala linda
Jan 12, 2008 | Computers & Internet
HP dvd740i DVD±RW Dual Layer Burner Logo
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
